Lenovo Y50-70 - I need a bios input for the ZIVY2 LA-B111p board
fanfiction 6717 12
How can I get a BIOS file for a Lenovo Y50-70 ZIVY2 LA-B111P board that powers on for a few seconds, shows a black screen, and then shuts off?
A BIOS file was shared in the thread, but flashing it did not change the symptom, so the fault was likely not in the BIOS alone [#16305447][#16305609] The same helper then suggested checking whether the KBC had been programmed, and later said they also had a KBC batch available [#16306196][#16312981] Another reply noted that you need a programmer for the SPI memory, but programming still did not solve the issue in that case [#16496689] A later user with the same symptom found that the problem was the RAM connector, so the memory path and other hardware should be checked as well [#17064714]
  • #1 16303908
    fanfiction
    Help: 10
    Rate: 16
    The above mentioned laptop with a symptom that after pressing power, the laptop turns on for a few seconds, the keyboard backlight and one fan turn on. Black screen. After a few seconds, the laptop turns off.
    I would need a bios input for the above. plates. There are files in the competitive forum, but unfortunately I don't have any points.
    Can someone help me?
    xironeksik
    Help: 60
    Rate: 71
    In Attachment
    • Lenovo Y50-70 ZIVY2 LA-B111P.rar (3.33 MB) You must be logged in to download this attachment.
  • #3 16305609
    fanfiction
    Help: 10
    Rate: 16
    xironeksik wrote:
    In Attachment
    Thank you. Unfortunately, after uploading the batch, the laptop behaves identically.
    Then I have to look for a hardware fault.
  • #4 16306196
    xironeksik
    Help: 60
    Rate: 71
    Unfortunately, it's not a bios. Kbc did you program?
  • #5 16306231
    fanfiction
    Help: 10
    Rate: 16
    I didn't program. Do you have a batch for KBC?
    xironeksik
    Help: 60
    Rate: 71
    Hello, yes I have. Please
    • LENOVO Y50-70 COMPAL LA-B111P ZIVY2 REV 1A KB9022Q.bin (128 KB) You must be logged in to download this attachment.
  • #7 16496091
    malpa_klimek
    Hello, I have a laptop with the same symptom. How to do BIOS and KBC programming?
  • #8 16496689
    fanfiction
    Help: 10
    Rate: 16
    You must have a programmer for SPI memory.
    Unfortunately, programming did not help me. I found a CD in good money.
  • #9 17064714
    lisleon1975
    I had the same. The problem was with the RAM connector.
  • #10 17133803
    xxl245
    Help: 17
    Rate: 39
    Anyone check this bios?
    My LA-B111P ZIVY2 Rev .: 1A D23
    On the old bios, the laptop started correctly but after changing the bios settings, these did not save. When uploading the attached bios to the programmer, a message appears that the file size is too large.
    I played the original bios again and also a black screen, the memory was misread?
    Summing up the attached bios for me did not go.
    The computer fired up and works fine on the attached file
    • ZIVY2 LA-B111P REV 1 0.BIN (8 MB) You must be logged in to download this attachment.
  • Delayed image suggests BIOS or RAM issue
    #11 20508360
    sebo1_30
    Help: 11
    Rate: 18
    Hello. I had a slightly different symptom of a damaged bios. The laptop turned on and the keyboard lit up, but there was no image on the matrix. I received the laptop without RAM, hard drive and a cracked matrix. I uploaded the encore from the last post but I have a small problem. The laptop turns on properly, but the image shows up after 17 seconds. I have a question now. Damaged bios bone, incorrect batch, or wrong matrix? Substituted another instead of a cracked one, but the image displays correctly, including the system. Do memories matter? Tested on 12800s. Is something wrong with the bios settings? Please help. ZIVY2 LA-B111P REV 1.0 I5 4200H GeForce RTX.
  • #12 20508886
    xxl245
    Help: 17
    Rate: 39
    Look for a bios with a clean my region, and preferably ask someone to clean the bios on which it fires for a long time.
  • #13 20509582
    sebo1_30
    Help: 11
    Rate: 18
    Hello. Me region in the old bios and the new one were the same. But after replacing the damaged bios with the one from the forum, the laptop starts properly. Thanks for the help.
The discussion revolves around troubleshooting a Lenovo Y50-70 laptop exhibiting symptoms of powering on briefly with a black screen, indicating potential BIOS or hardware issues. Users share experiences with BIOS programming and KBC (Keyboard Controller) programming, highlighting that simply updating the BIOS may not resolve the issue. One user mentions that the RAM connector was the problem in a similar case. Others discuss the importance of using a clean BIOS file and the potential for incorrect settings or damaged components affecting performance. A successful resolution was noted when a user replaced the damaged BIOS, leading to proper laptop functionality.
