What router instead of funbox 2.0 will the current one be suitable?
Laik777 12690 20
Can my Asus 4G-AC55U replace the Orange Funbox 2.0 on Orange 300 Mb/s fiber?
Yes — your Asus 4G-AC55U can replace the Funbox 2.0 for Orange fiber, as long as you configure PPPoE and VLAN tagging correctly [#17970355][#17974001] If you do not use Orange IPTV, it should work without major problems; the router’s WAN Ethernet port is enough for the fiber connection [#17972076][#17970355] In ASUS settings, choose PPPoE in WAN, enter your login/password, then in the IPTV tab select a Custom profile and set Internet VLAN ID to 35, priority 0, with 802.1Q tagging enabled [#17974001] If you do need Orange IPTV, be aware that Orange uses two VLAN IDs, and many routers support only one; TP-Link models were mentioned as supporting two VLAN IDs [#17970355] If you want alternatives, routers that support VLAN tagging and firmware like OpenWrt/Tomato/DD-WRT were recommended, such as Netgear R6400/R7000 or Asus RT-AC68U; MikroTik was also suggested, but it needs more network knowledge [#17968107][#17969107] One user also advised enabling the MTU detection fix for Orange fiber because PPPoE needs smaller packets [#17993433]
  • #1 17967957
    Laik777
    I have a fiber from orange 300 Mb / s and funbox 2.0 which often turns off and has a weak and unstable range. I called orange but when asked if a given router would work, the question was for :D what not their great funbox, a very hard conversation which resulted in nothing. That's why I have a question for you, will the asus 4g-ac55u router work? And I am happy to hear any suggestions for other routers. thank you
  • #2 17968107
    Epic
    Level 30  
    Help: 147
    Rate: 108
    You need a router that supports VLAN tagging. For this to work, the router should rather be supported by alternative software such as LEDE / Openwrt, Tomato, DD-WRT.
    Due to the above, the right devices are not cheap.
    For example:
    -Netgear R6400 / R7000 and possibly other Rxxxx
    -Asus RT-AC68U
    I use Netgear R7000 myself and I have never had problems with the operation of the optical fiber from Orange, I have never even had IPTV from Orange on Tomato.
    The funbox is in a cardboard box on the wardrobe from the technicians' exit ;)
  • #3 17969107
    cracket
    Help: 11
    Rate: 45
    If you do not need LTE / SIM / USB and you are not afraid to configure the router yourself, I would choose mikrotik, for example:
    RB4011iGS + 5HacQ2HnD-IN
    It has faster wifi and 10 GbE ports and the price is similar
  • #4 17969163
  • #5 17969403
    Laik777
    [The funbox is in a cardboard box on the wardrobe from the technicians' exit ;) [/ quote]
    I'm not surprised :P a router that has no external antennas already gives food for thought, i.e. the router that I have asus 4g-ac55u can not do? :(
    Erbit wrote:
    cracket wrote:
    ... I would choose mikrotik, for example:
    Mikrotik is a good choice - but remember that it is a device that needs to be administered with at least basic knowledge of the network. There are various types of tutorials, but without knowledge it can be difficult.
    Unfortunately, I do not know almost at all, I will also let go of this router, I also have a question whether the current asus 4g-ac55u will do the trick or you need to sell it and buy another
  • #6 17969523
    Epic
    Level 30  
    Help: 147
    Rate: 108
    Laik777 wrote:
    that is, the router I have asus 4g-ac55u can not do? :(
    Unfortunately, it is not supported by other software. And the correct configuration for Orange fiber on the original software of this router cannot be done.
  • #7 17969627
  • #8 17969693
    Laik777
    damn it is a pity it sells and I will take one of the referrals above :) Thank you very much !
    Laik777 wrote:
    unfortunately I do not know myself almost at all, I will also give up this router, ...
    It's good that you understood the caution, however ... this router will give you very wide configuration possibilities, Much greater than OpenWrt or Tomato software.
    Simply put, in MikroTik, most of you can set yourself "off the finger" without any wizards - no wizard limitations gives you a wide range of possibilities. Maybe it's worth taking a closer look at this router? At this price, it is a very interesting item. You can have peace of mind for many years and learn something more, not to mention that you can shine among your friends. [/ Quote]
    You are a little tempting, however, I do not know if I can manage it, and I would also like a router closer to PLN 600, but thanks a lot for the opinions and the idea is still over it :)
  • #9 17969721
  • #10 17970355
    Nagus
    Help: 99
    Rate: 97
    Take some pity: my friend has a 300Mbps connector, do not crap that 2.4GHz WiFi-only is enough for him.
    The mentioned ASUS has a WAN Ethernet connection, so it can be used instead of the Funbox 2.
    It can definitely be configured to support the Internet, you need to set tagging in the IPTV tab.
    The bigger problem is with IPTV, because Orange uses two VLAN IDs, while many routers support only one. Two VLAN IDs for TV support TP-Links.
    Something-wrt can also be configured for Orange TV, but it may require e.g. manual routing creation, which for an average user may be difficult to pass.
  • #11 17970450
  • #12 17971776
    Laik777
    crap now, I have already lost it, I would like 5Ghz, two telephones use the Internet, a computer with a cable, a TV also with a cable (Netflix) and a laptop, 100m2 apartment. You mean I can use my current router? And what about this TV, the Internet on TV will not work?
  • #13 17971866
  • #14 17972076
    Nagus
    Help: 99
    Rate: 97
    Got IPTV from Orange? If not, no problem. Your ASUS will do. Internet to smartTV will also reach you.
    Newer devices with WiFi AC also support beamforming practically, so I would not demonize the range problems here. Anyway, 11ac on a poor signal can pass more than 2.4GHz on a good signal.
  • #15 17972161
  • #16 17972413
    Laik777
    Ok, then I will try to connect, although I did not manage to do it recently, I had a problem with the configuration ... I hope that this time it will work, simply on the Asus router website there are a lot of these possibilities and I do not know what to choose, so more advanced the system falls off since I can not configure this Asus :( ((maybe I can find some guides on the Internet
  • #17 17974001
    Nagus
    Help: 99
    Rate: 97
    Oh there, ASUSa positions itself like any other ...
    In the WAN settings, you choose PPPoE, enter your Neo login and password
    In the IPTV tab, select the Custom profile (because there is probably no predefined one for Orange PL) and set it
    Internet VLAN ID at 35, priority 0, you tag 802.1Q (as is). These controls may not appear until Enable IPTV is checked.
    I don't have Asus on hand, but it should look like that somehow.
  • #18 17974171
    Laik777
    I am eternally grateful, thank you for your help :D
  • #19 17993433
    cracket
    Help: 11
    Rate: 45
    If you have Orange optical fiber, do not forget to set the MTU detection fix on your router, because PPPoE requires smaller packets and some sites with not fully configured routing may "stick" when opening.
    Good luck with your setup
  • #20 17993499
    Laik777
    cracket wrote:
    If you have Orange optical fiber, do not forget to set the MTU detection fix on the router, because PPPoE requires smaller packets and some sites with not fully configured routing may "stick" when opening.
    I just tried to set up this router but couldn't even enter the WAN tab because 404 pops up ...
  • #21 17993525
    Nagus
    Help: 99
    Rate: 97
    Clear the cache in the browser.
    Router - Factory reset and start over. Sometimes when something gets confused in the settings, it won't get up.
    If you haven't done software update in the router - do it now.
    It has to work.
The discussion revolves around finding a suitable replacement for the Funbox 2.0 router provided by Orange, which is criticized for its frequent disconnections and weak range. The user inquires about the compatibility of the Asus 4G-AC55U router and seeks alternative recommendations. Responses suggest routers that support VLAN tagging and alternative firmware like OpenWrt or Tomato, with specific models such as Netgear R6400, R7000, and Asus RT-AC68U being recommended. Mikrotik routers are also mentioned as viable options, though they require more technical knowledge for configuration. The conversation highlights the importance of proper setup for IPTV services and the need for a router that can handle multiple VLAN IDs. Users discuss the necessity of 5GHz support and the potential for using existing equipment with proper configuration. Troubleshooting advice is provided for setting up the Asus router, including steps for VLAN configuration and MTU settings.
TL;DR: Orange IPTV uses two VLAN IDs; "the ASUS can be used instead of the Funbox 2." Enable VLAN tagging in the IPTV tab for Internet; IPTV needs dual‑VLAN support or specific models. [Elektroda, Nagus, post #17970355]
Why it matters: For Orange FTTH users replacing an unstable Funbox 2.0, this explains which routers work and how to configure them for Internet and TV.
Will ASUS 4G‑AC55U work with Orange fiber instead of Funbox 2.0?
Yes, for Internet access. Enable VLAN tagging in the IPTV tab and use the WAN Ethernet port. The challenge is IPTV, which uses two VLAN IDs. Many routers support only one tagged VLAN, so TV may fail. Some TP‑Link models handle two VLANs for Orange TV. Alt firmware can help with TV but may require manual routing. If you only need Internet, the ASUS can replace Funbox after proper tagging. [Elektroda, Nagus, post #17970355]
How do I configure an ASUS for Orange Internet (no IPTV)?
Set PPPoE with your Neostrada login and password. In IPTV settings, choose Custom, check Enable IPTV, and set Internet VLAN ID 35 with priority 0 and 802.1Q tagging. Apply settings and reboot the router. If fields are hidden, enabling IPTV reveals them. 1. WAN > PPPoE + credentials. 2. IPTV > Custom > VLAN ID 35, priority 0, tag 802.1Q. 3. Apply and reboot. [Elektroda, Nagus, post #17974001]
Do I need a router with VLAN tagging or alternative firmware?
Yes. “You need a router that supports VLAN tagging.” Models that accept OpenWrt/LEDE, Tomato, or DD‑WRT ease Orange FTTH setups. Examples include Netgear R6400/R7000 and ASUS RT‑AC68U. One user reports stable Orange fiber on a Netgear R7000 with third‑party firmware. Choosing VLAN‑capable hardware reduces setup friction and unlocks IPTV options. [Elektroda, Epic, post #17968107]
I don’t have Orange IPTV—will smart‑TV apps work through a third‑party router?
Yes. If you do not use Orange IPTV, Internet works after correct VLAN tagging. “Your ASUS will do. Internet to smartTV will also reach you.” Configure WAN PPPoE and tagging as needed. Netflix and similar apps run over your normal Internet connection through Ethernet or Wi‑Fi. [Elektroda, Nagus, post #17972076]
Should I use 5 GHz or 2.4 GHz Wi‑Fi in a ~100 m² flat?
5 GHz is faster but has weaker wall penetration. 2.4 GHz travels further but suffers more interference from neighbors. Use Ethernet for stationary devices when possible, and reserve Wi‑Fi for mobiles. Try both bands and prefer 5 GHz where signal is acceptable. It improves throughput and reduces congestion when properly placed. [Elektroda, Anonymous, post #17971866]
Do external antennas guarantee better Wi‑Fi range?
No. “The lack of external antennas is a wrong measure.” Many access points without visible antennas perform very well. Antenna design, radio quality, placement, and environment matter more than whether antennas are external. Focus on channel planning and location before judging by antenna style. [Elektroda, Anonymous, post #17969627]
Is MikroTik a good choice for beginners replacing Funbox 2.0?
MikroTik is powerful but expects basic networking knowledge. Tutorials exist, yet configuration can be challenging initially. If budget is tight, consider a simpler MikroTik model and add a second access point if coverage is weak. Plan wiring to complement Wi‑Fi. This path balances cost, learning, and coverage. [Elektroda, Anonymous, post #17969163]
Why consider MikroTik long‑term?
It offers wide, wizard‑free configuration options, beyond OpenWrt or Tomato. You can set most features manually and tailor the network precisely. As one expert put it, you can have “peace of mind for many years” once configured. It’s a solid platform for growth. [Elektroda, Anonymous, post #17969627]
Which consumer routers are proven with Orange FTTH?
Users report success with VLAN‑capable models like Netgear R6400/R7000 and ASUS RT‑AC68U. Alternative firmware support (OpenWrt/LEDE, Tomato, DD‑WRT) is valuable. A Netgear R7000 user notes stable Orange fiber performance after setup. These devices prioritize VLAN control required by Orange. [Elektroda, Epic, post #17968107]
What VLAN ID and priority should I set for Orange Internet?
On ASUS, select Custom in the IPTV tab. Set Internet VLAN ID to 35, priority to 0, and enable 802.1Q tagging. Enter PPPoE credentials in the WAN section. Save and reboot. These specific parameters match Orange’s Internet requirements. [Elektroda, Nagus, post #17974001]
Websites hang on Orange PPPoE—how do I fix MTU issues?
Enable the MTU detection fix on your router. PPPoE adds overhead, so effective MTU is smaller. Some paths drop large packets or block ICMP, causing pages to “stick.” Automatic MTU detection cures fragmented or black‑holed traffic. Apply and test with affected sites. [Elektroda, cracket, post #17993433]
My ASUS WAN page shows 404—how do I recover?
Clear your browser cache and reload. If the UI remains broken, perform a factory reset and reconfigure from scratch. Update the router firmware before trying again. This sequence restores a confused configuration and resolves UI glitches. “It has to work.” [Elektroda, Nagus, post #17993525]
Do I really need 5 GHz for a 300 Mb/s plan?
Yes, 2.4 GHz alone often bottlenecks 300 Mb/s service. “Do not [claim] that 2.4GHz WiFi‑only is enough.” Newer 802.11ac with beamforming can outperform 2.4 GHz even on weaker signals. Use 5 GHz where feasible to reach plan speeds. [Elektroda, Nagus, post #17970355]
Should I add a second access point to improve coverage?
If one AP does not cover your space, add a second AP. Pair a capable router with an extra AP for distant rooms or floors. This approach beats over‑powering a single AP and helps avoid neighbor interference. It also keeps costs reasonable. [Elektroda, Anonymous, post #17969163]
Why was MikroTik RB4011 recommended in the thread?
It offers faster Wi‑Fi and 10 GbE ports, making it a strong core router. If you do not need LTE/SIM/USB, it’s a capable choice. However, it assumes you can handle manual configuration. Consider needs and budget before picking it. [Elektroda, cracket, post #17969107]
