Title: Replacing Orange Funbox 3.0 Router for Stability: Questions on WAN Type & External ONT Usage
Marcinolak xD 12840 19
How do I replace an Orange fibre router with my own gigabit router that supports login/password authentication, and why was an external ONT used instead of the router’s internal ONT?
For login/password authentication on the WAN, you want PPPoE in the router’s WAN settings; most routers also support STATIC IP, DHCP, PPTP and L2TP, and a stable gigabit no-Wi‑Fi option mentioned was the Ubiquiti EdgeRouter X [#18872738] However, with Orange fibre plus IPTV, a simple router swap usually will not work because the TV service depends on VLAN configuration, and attempts with other routers (for example Mikrotik) were reported as unsuccessful [#18872886][#18872909] The external Nokia G-010G-Q ONT was likely used because the installers took the quickest path to get the service up instead of properly diagnosing the internal ONT setup, which may have been misconfigured or not tested correctly [#18873114][#18873160] The practical advice was to first complain to Orange, ask for a technician and equipment replacement, and only then consider alternative hardware [#18873718]
  • #1 18872533
    Marcinolak xD
    Help: 9
    Rate: 178
    Hello everyone.
    I have Orange 300Mbit + IPTV fiber optic service. I would like to replace the Funbox 3.0 router with my own, because it is terribly unstable, it breaks synchronization (only restart helps). I guess everyone who was (un) lucky enough to have this type of equipment knows what I mean). As part of the service, I also got ONT Nokia G-010G-Q (this equipment works perfectly - the PON diode is always on).
    Here's the question. What is the name of the WAN router type with the ability to authorize the connection by login and password? For example, Tp-Link TLWR841N has a WAN port, but no authentication function.
    Second question: Why did Orange fitters use an external ONT? Out of curiosity, I connected the fiber optic connector directly to the Funbox, reset the router and switched to "internal ONT" and never managed to establish a connection.
    I'm not going to call the hotline and advertise the equipment. at best I'll get the same crap.
    I prefer to invest in decent equipment and not have problems with the stability of the connection. I am interested in 1Gbit WAN and LAN.
    adversus
    Level 32  
    Help: 188
    Rate: 597
    My colleague was looking for something in his router :)
    Virtually every router has this authorization option, you can always choose from in the WAN settings:
    - STATIC IP access via fixed IP assigned by the provider,
    - DYNAMIC IP, where IP is assigned from DHCP by the provider,
    - PPPoE - allowing for authorization with a login and password
    - PPTP / L2TP - as above, password and login authentication
    Everything is described in the instructions of the routers and the network.
    If without Wifi, ER-X Ubiquiti - EdgeRouter X, 5-port, gigabit, once configured, works flawlessly for years.
  • #3 18872835
    Marcinolak xD
    Help: 9
    Rate: 178
    I have always used this device as an AP on a LAN with DHCP turned off, so I never rummaged in the WAN settings for a long time ... :D
    I must say that the equipment makes a good impression at first glance and is quite affordable. I don't need WiFi because I use AP TL-WA901ND.
    There is one more thing that I FORGOTTEN. I also have a landline telephone and Funbox has an integrated VoIP gateway. When I buy such a gate - for example Cisco SPA112, it rather requires configuration. Question: can I find the data for this in the contract statement, or is it not that simple?
    I don't really care about the phone. In fact, it only annoys with commercials.
  • #5 18872902
    Marcinolak xD
    Help: 9
    Rate: 178
    ... fiber optic Orange 300Mbit + IPTV ...
    Due to IPTV, you are unable to replace the router. There were some attempts in the network (for example on Mikrotik) but they were unsuccessful. The problem is with the Vlans. For example, read here -> https://trzepak.pl/viewtopic.php?f=20&t=51177
    Actually, that's correct. The decoder does not have a card, so the verification must be done in a different way (data read from the router).
    adversus
    Level 32  
    Help: 188
    Rate: 597
    Well, probably my colleague Erbit has dispelled all the author's dreams about a different router. Unfortunately, you will not get IPTV on another router, although at my client in Inea, the optical fiber on the same network (VLAN), i.e. on the port No. 1 of the LAN switch, TV and Internet are flashing. But there was a long way to deal with the change of settings after acquaintance, because vendors are very reluctant to change "deflaut" settings to other ones.
    It remains to fight with Orange and advertise the service until "you are satisfied" ;)
  • #7 18872921
    Marcinolak xD
    Help: 9
    Rate: 178
    Thanks for the answers. However, I still have a question from post # 1:
  • #8 18873097
  • #9 18873114
    adversus
    Level 32  
    Help: 188
    Rate: 597
    They probably had it set up and prepared for the ONT, but they figured out that there was still IPTV and they added a router to quickly start it up. It's normal at Orange to check off a job and push yourself away, and do another customer. Orange generally does not look at the quality of service, the customer has to be connected, it is a cycle and it is. And now you will be jostling with BOK and the service. I know it from the autopsy after assembling at clients.
    It is possible that you have an incorrectly configured router by them and therefore breaks the connection, but maybe you have something wrong. You checked the network cables (with some tester, even with the simplest diodes). How long do you have this link (because the power supply may still be released)?
    Another reason (I struggled with this at the client's because the entire network in the company was going crazy) and it turned out that the equipment in the cabinet (Draytek's router) boiled. Putting the fan in helped and everything went back to normal.
  • #10 18873134
    Marcinolak xD
    Help: 9
    Rate: 178
    Rather, I meant that neither the installer nor me the router connected to the "Internal ONT" setting with the optical fiber plugged into the socket directly in the Funbox. The only thing that was signaled by the continuous orange "Fiber optic" LED. Only when the fitter brought and installed the external ONT - everything started.
    Added after 5 [minutes]:
    Erbit wrote:
    Can you show how you have this Funbox configured on the WAN side?
    Title: Replacing Orange Funbox 3.0 Router for Stability: Questions on WAN Type & External ONT Usage Title: Replacing Orange Funbox 3.0 Router for Stability: Questions on WAN Type & External ONT Usage
    What kind of IPv4 / IPv6 connection is better in this case?
  • #11 18873160
    adversus
    Level 32  
    Help: 188
    Rate: 597
    Rather, I meant that neither the installer nor me the router connected to the "Internal ONT" setting with the optical fiber plugged into the socket directly in the Funbox. The only thing that was signaled by a continuous orange LED "Optical fiber". Only when the fitter brought and installed the external ONT - everything started.
    As I wrote earlier, the question was what level of knowledge about networks did the assemblers have. And how much time they had, because, for example, when they were in a hurry, instead of solving the problem with remote technical support, they went the easy way, plugged in the external ONT and did not play with the diagnosis, the internal ONT may as well be released (router swings do not come out of nowhere). Now it remains to advertise the service in the Customer Service Center and hope that a kumaty service technician will come.
  • #12 18873171
    Marcinolak xD
    Help: 9
    Rate: 178
    As I wrote earlier, the question was what level of knowledge about networks did the assemblers have. And how much time they had, because, for example, when they were in a hurry, instead of solving the problem with remote technical support, they went the easy way, plugged in the external ONT and did not play with the diagnosis, the internal ONT may as well be released (router swings do not come out of nowhere). Now it is BOK and kumaty service technician.
    In my opinion, the fitter who was "lucky" to visit us was, to say the least, incompetent. He didn't even have his own screwdriver. :shii:
    The mains cable tester (which I also had to borrow) was probably the first time I ever saw him.
    In addition, the whole thing took (I'm not joking) 3 hours. I am omitting the fact that Fr. each the thing called the hotline. Madness.
    The previous fitter, who viewed the connection, had to scour the street in search of a disconnected optical fiber. Only a specialist from Inea (the company that "led" the whole town) helped.
    We bought the service from Orange only because they have mobile services and we wanted to have everything on one "piece of paper".
    By the way, this Funbox is the fourth hybrid device that causes problems ... The first in the ranking is the WHD80 decoder, which could never turn on and had to be restarted every now and then.
    So far, the best device that works flawlessly is the Samsung ICU100 decoder - so far there have been no problems with it. Maybe cooperation with Samsung is good for them. :D
    And finally, Orange is probably investing more in it: https://pl.wikipedia.org/wiki/Planowane_postarzanie_produktu than in the quality of services.
  • #13 18873350
  • #14 18873467
    Marcinolak xD
    Help: 9
    Rate: 178
    Do you think I should buy the router already mentioned in the discussion and experiment?
    From what I read, the above-mentioned device has all the necessary functions:
    • EdgeRouter_X_DS[1].pdf (3.43 MB) You must be logged in to download this attachment.
  • #15 18873492
    adversus
    Level 32  
    Help: 188
    Rate: 597
    In addition, the whole thing took (I'm not kidding) 3 hours. I omit the fact that he called the hotline for every thing. Madness.
    Well, everything about the topic ... call the Customer Service first and call the technicians to a failure (constant freezing of the device, and that it does not always hang like a technician is another matter), request a replacement of the equipment ... if that does not help, then consider alternative router, but it is worth reading, because it may not start if Orange does not help.
  • #17 18875541
    markooff
    Help: 79
    Rate: 178
    Yes, by the way - I am tempted to ask - what (and how?) A colleague did that he got
    For a year I had almost fought with the Orange and they always wanted to squeeze Hujaweja on me, nothing else ...
    All negotiations ended invariably with the sentence - "we do not have such possibilities - as part of the service it is only hujawa".
    Regards
  • #18 18875688
  • #19 18876162
    Marcinolak xD
    Help: 9
    Rate: 178
    Erbit wrote:
    markooff wrote:
    ... what (and how?) a colleague did that he got
    Well, it was a coincidence.
    Exactly.
  • #20 18876466
    markooff
    Help: 79
    Rate: 178
    In that case, there are no such 'lucky' cases in my region.
    The assemblers have exactly what the company provides in the contracts.
The discussion revolves around the user's experience with the Orange Funbox 3.0 router, which is deemed unstable for their 300Mbit + IPTV fiber optic service. The user seeks to replace the Funbox with a more reliable router and inquires about WAN types that support login/password authentication, specifically mentioning the limitations of the Tp-Link TL-WR841N. Responses highlight that most routers support various WAN configurations, including PPPoE for authentication. However, challenges arise with IPTV compatibility when using alternative routers due to VLAN configurations. The user also questions the necessity of an external ONT (Nokia G-010G-Q) and shares frustrations regarding the installation quality and service from Orange. Suggestions include contacting customer service for equipment replacement and exploring other router options, while emphasizing the importance of proper configuration for successful IPTV functionality.
TL;DR: For Orange FTTH + IPTV users, replacing Funbox 3.0 is limited. A 1 Gbit EdgeRouter X — "once configured, works flawlessly for years" — with PPPoE can stabilize Internet, but IPTV VLANs block full swap. [Elektroda, adversus, post #18872738]
Why it matters: This FAQ helps you pick the right WAN type, decide on external ONT, and avoid breaking IPTV or VoIP on Orange fiber.
What WAN type do I select to authenticate with a login and password?
Select PPPoE in your router’s WAN/Internet settings. Most routers also offer Static IP, Dynamic IP (DHCP), PPTP, and L2TP. PPPoE is the mode that uses a username and password for access control. On older TP-Link menus, it appears under “WAN Connection Type.” Save and reboot after changes. [Elektroda, adversus, post #18872738]
Can I fully replace Funbox 3.0 if I have Orange IPTV?
No, not for full service. IPTV relies on ISP VLANs handled by the Funbox. Community attempts on MikroTik struggled with VLAN specifics. Without exact tagging and authentication, the decoder fails. Internet-only may work on another router, but IPTV stays on Funbox. [Elektroda, Anonymous, post #18872886]
Why did the installer use an external ONT instead of Funbox’s internal ONT?
They likely chose the fastest way to activate service. “They went the easy way, plugged in the external ONT… the internal ONT may as well be released.” If the internal ONT isn’t provisioned or is faulty, it won’t link. Ask Orange to re-provision or replace hardware. [Elektroda, adversus, post #18873160]
My fiber plugged into Funbox (internal ONT) shows solid orange and never links. Why?
In the reported case, the internal ONT never established a connection and the optical LED stayed orange. After installing an external Nokia ONT, the link came up and worked. That points to a provisioning or device issue with the internal ONT. Report it for a technician check. [Elektroda, Marcinolak xD, post #18873134]
How do I set up PPPoE on a third‑party router behind the ONT?
  1. Connect the ONT’s LAN port to your router’s WAN port.
  2. Open WAN/Internet settings and choose PPPoE.
  3. Enter your ISP login and password, save, and reboot the router. [Elektroda, adversus, post #18872738]
Is Ubiquiti EdgeRouter X a good choice for stable Internet (no Wi‑Fi)?
Yes. ER‑X provides 5 gigabit ports and strong stability after setup. “Once configured, works flawlessly for years.” Pair it with an AP like TP‑Link TL‑WA901ND for Wi‑Fi. Use PPPoE on the WAN for authentication. Keep Funbox for IPTV. [Elektroda, adversus, post #18872738]
Should I use IPv4 or IPv6 mode on Funbox?
Use IPv4 for fewer issues. The cited configuration had problems when the WAN used IPv6 while LAN stayed IPv4. That translation can break apps and services. If enabling IPv6, test thoroughly and watch client behavior. For stability, stick to IPv4-only mode. [Elektroda, Anonymous, post #18873350]
My Funbox keeps dropping sync. What should I check first?
Test Ethernet cables with a simple LED tester. Confirm the power supply is healthy. Check for overheating; adding a small fan restored stability in one case. Ask Orange to verify router configuration. If drops continue, request equipment replacement or a service visit. [Elektroda, adversus, post #18873114]
Can I use my own router and still keep Orange IPTV working?
You cannot run IPTV on a third‑party router alone. Funbox handles VLANs and decoder verification. In INEA, custom changes enabled mixed TV/Internet on one port, but vendors resist changing defaults. Keep Funbox for IPTV and use your router for Internet. [Elektroda, adversus, post #18872909]
Can I move my landline to a Cisco SPA112 or other ATA?
Funbox includes the VoIP gateway. An ATA like Cisco SPA112 needs SIP credentials and profile details. Contracts usually don’t list those. Ask Orange if they’ll provide them for your plan. Otherwise, leave the phone on Funbox or accept no landline. [Elektroda, Marcinolak xD, post #18872835]
Should I buy a new router now or wait for a proven setup?
Wait for a verified approach. “I would first see what others have already done… Only if I had a solution, I would undertake the purchase.” With a separate ONT, Internet‑only swaps look feasible. IPTV remains the barrier. [Elektroda, Anonymous, post #18873492]
Can I request a specific ONT model like Nokia G‑010G‑Q from Orange?
There’s no guarantee. A user received the Nokia by coincidence. Field teams install what logistics provides. You may ask during a visit, but availability dictates what you receive. [Elektroda, Anonymous, post #18875688]
What if the installer seems unprepared and the visit drags on?
Document the visit and escalate to Customer Service. One reported installation took 3 hours with repeated hotline calls. Request a competent technician and a device swap if needed. Push until the link is stable and IPTV works. [Elektroda, Marcinolak xD, post #18873171]
If I already have a separate ONT, can a better router handle Internet‑only?
A separate ONT increases your chances for Internet‑only replacement. One shared diagram showed ONT to a better router for data, with Funbox still handling IPTV. Enthusiasts reported solutions in community threads. Keep expectations realistic for IPTV. [Elektroda, Anonymous, post #18873350]
