Best Router for UPC 300Mbps, 5GHz & 30 Devices: Asus AC65P or Alternatives? (Budget: PLN 500)
Gandziarz88 5703 10
  • #1 18264343
    Gandziarz88
    I am devastated by the work of Connect Box from UPC and I'm sick of it.
    I'm going to switch it to modem mode and add my own router. I care about a good 5GHz (streaming services pseudo :) 4K etc.)
    Throughput as in the subject 300Mbps
    About 30 devices connected to the network, most of them I try over LAN.
    Apartment 65 meters
    Budget up to PLN 500 (but I would prefer less...)
    I'm initially thinking about Asus AC65P, but there are probably companies that offer good equipment without paying extra for the design and graphical interface ...
    I count on your help and best regards ;)
  • #2 18265842
    IC_Current
    Help: 1499
    Rate: 2509
    If you are mainly concerned with the range of the Wifi network, then buy a decent AP, not a router.
  • #3 18266771
    Gandziarz88
    The range is ok, the stability of the connection and the "time of getting along with the devices" with the UPC Router is a drama, I don't think the AP with such a "source" will give me anything.
  • #4 18266844
    IC_Current
    Help: 1499
    Rate: 2509
    Of course, there are such problems on a wired connection, because if only on a WiFi connection, the AP will pass the exam.
    If something does not work on the wired connection, you first need to get the CB in order, because it may turn out that you will buy a new device and the problem will remain (e.g. damaged power supply and unstable voltage).
  • #5 18268276
    Gandziarz88
    There are no problems with the Ethernet connection, the problems are only with WiFi. Am I to understand that I lead the cable to the AP, and it creates WiFi (at the same time I turn off WiFi in the UPC router)?
    What would be good then? :) I would like to add that I would like to be able to connect a hard drive there.
    IC_Current
    Help: 1499
    Rate: 2509
    Yes. You lead the wire to the AP, and in the CB you turn off the radio.
    However, you need to check that WiFi problems are not caused by neighboring networks. To do this, install the WiFi Analyzer software on your phone and check if other networks are not broadcasting on the same channel as CB (both in the 2.4 and 5GHz bands). Also check the range in the 5GHz band.
    As an AP, I recommend Unifi UAP AC Pro/Lite. I don't know what this drive is supposed to be for, but it usually doesn't work (a USB drive for a soap dish), the performance is poor and few file formats are supported - you can save small text files, but you won't be able to watch a movie comfortably.
  • #7 18271068
    Gandziarz88
    Channels are ok, not crowded and I've tried many combinations over the months.
    The LITE/PRO difference only applies to 2x2 or 3x3 antennas? Without 3x3 receivers, I will not feel the difference by paying extra for PRO, right?
    EDIT: I read that only the PRO version has USB. Therefore, the question is whether there will be a reasonable AP with USB in the budget of PLN 500? Sorry to bother you but I want to choose wisely.
    As for the drive, it would be a network drive for documents, possibly music.
  • #8 18271113
  • #10 18271203
    IC_Current
    Help: 1499
    Rate: 2509
    No Unifi has USB connectors. There is an additional Ethernet port in the pro version. To take advantage of MIMO 3x3 capabilities, you also need such an antenna.
    Personally, I would buy the Lite version for a well-functioning WiFi, and as a file server, additionally, some cheap NAS for 250 zlotys, or a TV adapter with Android and Linux support in jail. Then you have hassle-free internet access and disk storage flexibility.
    @ostap1
    With these Tendas, more than one on the forum cried. On paper, it's miracles and fairy tales, but in practice...
  • #11 18281406
    Gandziarz88
    Ok, Unifi Lite version has appeared, all problems have disappeared, WiFi communication is finally at the right level. Only for posterity I will point out that the range generated by this AP is a disaster, I had to make a small sculpture in the house to set it in the central point. In conclusion, thank you for your help, it's good ;) .
    Regarding the NAS, I've only read a little about it and now the question is what is better to do, Raspberry Pi + USB drives, or buy some ready-made (at this price it's probably only DLink) and put large 3.5" drives there?
    What is the issue of power consumption, does such a mini computer make a real difference?
✨ The discussion revolves around finding a suitable router to replace the UPC Connect Box for a 300Mbps connection, focusing on 5GHz performance and the ability to support around 30 devices in a 65-meter apartment. The user expresses dissatisfaction with the UPC router's stability and connection issues, particularly with WiFi. Suggestions include using an Access Point (AP) like the Unifi UAP AC Lite or Pro, with considerations for USB connectivity for network storage. Alternatives such as the Netgear R6220 are also mentioned, with advice to flash OpenWRT for enhanced functionality. The user ultimately opts for the Unifi Lite, which resolves their WiFi issues, although they note limitations in range. The conversation also touches on the potential for using a Raspberry Pi for network storage versus purchasing a ready-made NAS solution.
