Master TL321 - TP.S506.PB818 - Seeking Dump for Reboot Issue (CV320PW03S, VVP32H148A00-02)
Acca85 13608 13
Where can I get a dump for a Master TV with TP.S506.PB818 that shows the logo and then reboots, and how is it applied?
Yes — a dump was shared for this TP.S506.PB818 set, and it was reported to fix the logo-then-reboot problem [#17985543][#17987658] One reply also notes that the U2 GD25Q32 must be programmed with an external programmer, so this is not just a USB software update [#18693587] Another user confirmed the firmware worked flawlessly after flashing it [#17987658]
  • #1 17983487
    Acca85
    Rate: 19
    I have this Master branded TV that shows the logo and then reboots, does anyone have the dump?
    Motherboard TP.S506.PB818
    Panel CV320PW03S
    Sticker VVP32H148A00-02
    159VKM0091
    Sticker on chassis: HK315LEDM-0H3TH
    AJ32T03
  • #2 17985543
    ODARROC
    Rate: 10
    in allegato il dump
    buon lavoro
    • U2-GD25Q32.rar (3.19 MB) You must be logged in to download this attachment.
  • #3 17987658
    Acca85
    Rate: 19
    Perfetto la tv funziona :)
    Firmware worked flawlessly.
  • #5 18410883
    Touaguine Mohamed
    Rate: 17
    J'ai besoin d'un DUMP LED TV LHD 32 K 2206 W TP.S 506 PB 818.
    JE RECTIFIE TV LED CONDOR LHD 32 K 2206 W NAD BOARD RAG 7 820 5930/ROH PANEL RAG 7820 6063/ROH .
    TV LED STARTLIGHT SL 32 E 31 S TP .S 506.PB 818
  • #6 18623097
    DreddyFykk
    Hello, how did you dump the files in the tv? My problem is the same as yours, it shows the logo and then reboots so i cant access the menu. Could you hepl me with that?
  • #7 18692689
    woojczi
    Hi ! I have TP.S506.PB801 motherboard with a AJ32T03-v04 panel and I'm looking for the dump, I'm not sure but I mean the file ".bin" to copy on USB drive and plug to the TV. Thanks a lot, sorry for writing in this topic, but I think it's okay.
  • #8 18693587
    Michał99
    Help: 140
    Rate: 345
    Post # 2 needs a programmer to program U2 GD25Q32
  • #9 18706101
    davidxuereb
    can you please advise procedure how to apply the dump firmware please?
  • #10 19027261
    sibbione
    ODARROC wrote:
    in allegato il dump
    buon lavoro
    Ciao, ho lo stesso tuo problema su Tv 32 Master (si accende sul logo e si riavvia) mi puoi dire la procedura per caricare il file Bin che ho già scaricato?
    Grazie Maurizio.
  • Requesting procedure to create a software dump application
    #11 19028867
    jeloi
    Help: 285
    Rate: 598
    davidxuereb wrote:
    can you advise the procedure how to make a software dump application?
    https://pt.aliexpress.com/item/32793046925.ht...-4c26best=180960-2c26b7d=0f91f741-0960-4c2697 searchweb0_0, searchweb201602_, searchweb201603_
  • #12 19032505
    sibbione
    Grazie, acquisto subito.
  • #13 21195437
    roudany
    >>17985543 thanks for help it's working for my krohler 32 thank you very much
A user reported a reboot issue with a Master branded TV, specifically showing the logo before restarting. The motherboard is identified as TP.S506.PB818, with a panel model CV320PW03S and a sticker number VVP32H148A00-02. Several responses provided a firmware dump that resolved the issue, allowing the TV to function properly. Other users inquired about the procedure to apply the dump and shared similar problems with different models, seeking assistance and firmware files. Some users also discussed the need for specific programming tools to apply the firmware successfully.
TL;DR: Boot-looping TP.S506.PB818 TVs are fixed with a 3‑step SPI reflash: “needs a programmer to program U2 GD25Q32.” USB .bin updates won’t work while it reboots; program the SPI flash directly. [Elektroda, Michał99, post #18693587]
Why it matters: This FAQ helps DIY techs and repair shops recover TP.S506.PB818-based 32" sets stuck on the logo without menu access.
How do I fix a TP.S506.PB818 TV that reboots at the logo?
Reprogram the SPI flash (U2, GD25Q32) with the working dump using a hardware programmer. This bypasses the OS boot loop and restores firmware. As one expert noted, “needs a programmer to program U2 GD25Q32.” After flashing, power-cycle and test video. [Elektroda, Michał99, post #18693587]
Where can I download the working dump mentioned in this thread?
See post #2, where the dump was attached by the contributor. Download it from that post’s attachment area and use it to program U2. [Elektroda, ODARROC, post #17985543]
Can I use a USB stick (.bin) to update if the TV is stuck in a boot loop?
No. When the set continuously reboots, it can’t apply a USB update. You must write the dump directly to the SPI flash with a programmer to recover it. [Elektroda, Michał99, post #18693587]
Which chip do I program on TP.S506.PB818?
Program U2, marked GD25Q32. That’s the SPI flash storing the firmware. Remove it or clip in-circuit, then write the dump using an SPI programmer. Verify the write before reassembly. [Elektroda, Michał99, post #18693587]
What tools do I need to flash the dump?
Use a USB SPI programmer such as a CH341A, plus a SOIC8 clip or desoldering tools. Install the programmer software on a PC, load the dump, and program U2. [Elektroda, jeloi, post #19028867]
How do I write the dump to the SPI flash (quick 3-step)?
  1. Connect your SPI programmer to U2 (GD25Q32) via clip or after removing the chip.
  2. Load the .bin dump, erase, program, and verify the flash.
  3. Refit the chip if removed, power up, and test image/audio. This restores a clean firmware image. [Elektroda, Michał99, post #18693587]
Is this fix confirmed to work?
Yes. The original reporter confirmed the result after flashing: “Firmware worked flawlessly.” Others later echoed success on similar 32" models. [Elektroda, Acca85, post #17987658]
Will this dump work for a Krohler 32" TV with TP.S506.PB818?
One user reported success using the same shared dump on a Krohler 32 set. Results can vary by panel pairing, but this case worked. [Elektroda, roudany, post #21195437]
My board is TP.S506.PB801. Can I use the PB818 dump?
No. PB801 requires its own dump. A user asked specifically for a PB801 .bin, highlighting the different firmware requirement. Don’t cross-flash PB818 images. [Elektroda, woojczi, post #18692689]
Which panel and stickers matched the successful repair case?
Panel: CV320PW03S. Stickers observed: VVP32H148A00-02, 159VKM0091, HK315LEDM-0H3TH, AJ32T03. Matching these IDs improves dump compatibility chances. [Elektroda, Acca85, post #17983487]
What is the memory size of the GD25Q32 chip?
GD25Q32 is a 32 Mbit (4 MB) SPI NOR device. Typical block structure uses 4 KB sectors and 256‑byte pages. This capacity fully holds the main TV firmware image. [GigaDevice, 2017]
How can I back up the original firmware from a working set?
Use your SPI programmer to read U2 (GD25Q32) and save a .bin image. Keep this safe for future recovery. Read-verify to ensure a valid backup file. [Elektroda, Michał99, post #18693587]
The TV still reboots after flashing—what should I check next?
Confirm your board variant and panel match the dump. PB801 vs PB818 images differ, and mismatches can keep the boot loop. Recheck hardware IDs and use the correct dump. [Elektroda, woojczi, post #18692689]
What file format is the dump I need to program?
A binary .bin image for the SPI flash. It’s not a user-level update package. Program it with a hardware SPI tool, not via the TV menu. [Elektroda, woojczi, post #18692689]
Where can I buy a suitable programmer for this job?
A CH341A USB SPI programmer is commonly used and was linked in the thread. Order a kit and include a SOIC8 clip if you prefer in-circuit flashing. [Elektroda, jeloi, post #19028867]
Does this apply to other brands like Condor or StartLight on TP.S506.PB818?
Yes, but confirm exact board and panel. A user requested dumps for Condor and StartLight variants, indicating model-specific needs even on PB818. Use the precise match. [Elektroda, Touaguine Mohamed, post #18410883]
