[Solved] Firmware Search for TV Master TL321 with TP.S506.PB801 Motherboard & HK315LEDM Panel
giorgiobardi 6564 4
  • #1 20961452
    giorgiobardi
    Cerco firmware per TV Master mod. tl321. Scheda madre Tp.S506.PB801 pannello hk315ledm-oh1th aj32to3.
    Grazie a chi può aiutarmi.
    billobirillo
    Help: 338
    Rate: 803
    the tv is in bootloop?
  • #3 20961631
    giorgiobardi
    Si visualizza il logo e poi va in loop di accensione e spegnimento. Per spegnere, si deve scollegare la spina dalla corrente.
    USB recovery procedure and SPI flash fallback
    #4 20961680
    billobirillo
    Help: 338
    Rate: 803
    here is the firmware!
    rename the file SIS506_49.bin to SIS506_sos.bin
    usb recovery
    copy the file SIS506_sos.bin on an empty usb stick
    unplug the power cord
    insert the usb stick and reconnect the power cord
    look at the standby led, at the beginning it flashes slowly, after about 1 minute it doubles the speed, update completed
    unplug the power cord, then remove the usb stick
    reconnect the power cord and turn on the tv
    if it doesn't work with usb recovery, you have to replace the spiflash U2 with a new one and write it with the file SIS506_sos.bin
    • CP88505_HKC31501024_TP_S506_PB801_ITALY_AJ32T03_irK21_logoMASTER_32C1N_MIRROR_REF49_VA_AT_R14628_0xE0C0_20150203_173129.zip (3.13 MB) You must be logged in to download this attachment.
  • #5 20962062
    giorgiobardi
    inserito nuovo firmware con usb
