Search Function & Server Connection Issues on TV: Seeking Solutions & Possible Reasons
olo322 28779 16
Why can’t my TV connect to the server anymore?
The site/server is probably being blocked or otherwise unreachable from your connection, not broken on the TV itself: it works when Opera VPN is enabled, but not directly in Firefox or Chrome [#18000000] [#18000015] One reply says a traceroute shows the cause, and the domain resolves to a Cloudflare IP (194.68.123.246), so the issue may be on the Cloudflare/location side or with the route to the server [#17998139] [#18000017] If other sites work normally, the router/network card is less likely to be the cause [#17997782]
  • #1 17997757
    olo322
    Rate: 21
    Hello, since yesterday the server has not been working on tv. Anyone know what the reason is?
  • #2 17997765
  • #3 17997780
    olo322
    Rate: 21
    no connection to the server
  • #4 17997782
  • #5 17997787
    olo322
    Rate: 21
    everything is ok except tap.
  • #7 17997814
    olo322
    Rate: 21
    The static.zalukaj.com server is not responding for too long.
  • #8 17997864
    Milae
    Chickens from yesterday, even the site is not loading :(
  • #9 17998139
    doom27
    Rate: 17
    traceroute explains the case. Try the vpn opera. You can watch or pull the lines there. Maybe the problem is on the cloudflare side. Probably back to normal,
  • #10 17999214
    Vates
    Rate: 8
    And it still doesn't work ... They closed it down like Darkwarez, Premiumy and others?
  • #11 18000000
    doom27
    Rate: 17
    If you turn on vpn in opera, it works. Still it doesn't work directly. For me, the same thing with the danger side.
  • #12 18000010
    kympol
    Rate: 14
    How it doesn't work, how it works, I haven't noticed any interruptions.
  • #13 18000015
    Vates
    Rate: 8
    I don't use Opera every day, but I installed it and it actually works when I turn it on. It does not work on Firefox and Chrome from what I see in my home ... Thanks @ doom27
  • #14 18000017
    doom27
    Rate: 17
    Both sites are searched and the threat shows netnod-ix-ge-a-sth-1500.cloudflare.com [194.68.123.246]. Due to the location, some may not. Just check the command from the windows console: tracert zalukaj.com
  • #15 18280857
    maryann
    Level 37  
    Help: 342
    Rate: 337
    Now, at my site, I constantly inform about an overloaded server, even when logging in. Do you have that too?
  • #16 18280869
    doom27
    Rate: 17
    It has been like this for some time. Regardless of the time of day or night. There are many other alternative or better websites. They are probably trying to earn money and apparently vip accounts are also stupid because they do not change anything. I advise you to buy an account based on the opinions of users.
  • #17 18280924
    maryann
    Level 37  
    Help: 342
    Rate: 337
    I only know the CDA. Send some addresses to PW, because I urgently need one movie.
The discussion revolves around server connection issues experienced on a TV, specifically with the static.zalukaj.com server. Users report that the server is unresponsive, with some suggesting that the problem may be related to network configuration or the need to reset the router. While some users can access the site using a VPN in Opera, others find it non-functional on browsers like Firefox and Chrome. There are mentions of potential server overload and comparisons to other sites that have faced similar issues. Users are advised to check their network settings and consider using VPN services for access.
TL;DR: If your TV/browser can't reach zalukaj.com, note this: two browsers failed while Opera VPN worked; "it actually works when I turn it on." This FAQ helps home viewers fix "no connection" and "server overloaded" errors with quick checks, traceroute, and a VPN workaround. [Elektroda, Vates, post #18000015]
Why it matters: You can quickly tell if the fault is your device, your ISP route, or the site.
  • Windows tracert defaults to a 30-hop maximum, listing each router on the path. “tracert (Windows)”
  • Opera includes a built-in, no-cost VPN toggle that changes your exit route. “Opera VPN”
  • In-thread results: Firefox and Chrome failed, while Opera + VPN restored access. [Elektroda, Vates, post #18000015]
  • Users reported “overloaded server” messages at all hours; VIP access didn’t improve it. [Elektroda, doom27, post #18280869]
Is zalukaj.com down or is it just me?
Reports show Firefox and Chrome failed, but Opera with VPN worked. That pattern means the service was reachable from some routes. Test with a VPN or another connection. If it loads there, the issue is route- or region-specific, not a full outage. [Elektroda, Vates, post #18000015]
How do I fix "no connection to the server" on my TV or browser?
Check your network adapter settings. Reboot your router and modem. Confirm other sites work. Try a different browser. These quick checks isolate device or browser issues before deeper network tests. If others work, focus on route or site specifics. [Elektroda, Anonymous, post #17997782]
How do I run tracert on Windows to diagnose this?
Open Command Prompt. Run: tracert zalukaj.com. The tool lists each hop toward the destination. By default, it probes up to 30 hops. Timeouts appear as asterisks. Save the output to share with support or your ISP. “tracert (Windows)”
What does 'netnod-ix-ge-a-sth-1500.cloudflare.com' in traceroute mean?
Your traffic traversed a Cloudflare-linked hop seen by users tracing this route. If failures start near that hop, the issue is upstream of your home network. Include that hostname in any ISP ticket to speed escalation. [Elektroda, doom27, post #18000017]
Quick 3-step: what's the fastest way to get streaming again?
“Just check the command from the windows console: tracert zalukaj.com.”
  1. Run tracert zalukaj.com and note where it stalls.
  2. Enable Opera’s VPN and try loading the site again.
  3. If VPN works, use it until direct routing recovers. [Elektroda, doom27, post #18000017]
Why does Opera VPN work when Chrome/Firefox fail?
Opera’s built-in VPN routes your traffic through Opera servers and masks your IP. That changes the exit path and apparent location, bypassing route- or region-specific blocks. It’s a quick connectivity A/B test without extra software. “Opera VPN”
The static.zalukaj.com host isn't responding — what should I do?
Users saw requests to static.zalukaj.com hang for too long. When a required host times out, pages may not load properly. Try the VPN workaround suggested by others, or wait for the host to recover. You can also traceroute that subdomain to compare paths. [Elektroda, olo322, post #17997814]
Why does it work for some people but not for me?
One user noticed no interruptions while others couldn’t connect. That suggests differences in ISP routing or region. Try a different network, mobile hotspot, or a VPN to confirm a route-specific issue. [Elektroda, kympol, post #18000010]
Did they shut the site down like Darkwarez or Premiumy?
There’s no confirmation of a shutdown in this thread. Opera VPN restored access for affected users. That indicates the service remained reachable via other routes during the incident. [Elektroda, Vates, post #18000015]
I keep getting 'server overloaded' — any fixes?
Members reported overload messages regardless of time. VIP access provided no relief. That points to a server-side condition. Retry later, or use another platform. Avoid paying for upgrades if community feedback shows no benefit. [Elektroda, doom27, post #18280869]
What should I capture before contacting my ISP?
Run tracert and save the full output. Note timestamps and the hop where packets stall. Include any Cloudflare-labeled hops observed near the failure. Provide destination domain and your connection details when opening a ticket. [Elektroda, doom27, post #18000017]
Can I use Opera VPN on my smart TV?
Opera’s VPN is a feature of the Opera desktop browser. If your TV cannot run Opera, you cannot use this specific VPN on it. Test on a PC with Opera to compare connectivity routes. “Opera VPN”
