Can't Log in to Chomikuj.pl: Incorrect Password, WiFi/Phone/Ethernet Issues & Solutions
daamiaan94 40536 43
Why does Chomikuj.pl show an incorrect password error only on my home/work internet connection, while mobile data or VPN works, and how can I fix it?
This is most likely not a password problem but a block on your public IP or connection type, so Chomikuj treats the login attempt as an incorrect password [#19484676] One fix that worked was forcing IPv4 in the router settings: on a Funbox router go to settings → advanced → internet connection and enable “Force IPv4 connection” [#19745009] If your IP is blacklisted, either switch to another connection, use mobile internet, or log in through a VPN/proxy; one user also reported that Opera’s built-in VPN worked after choosing a different region and restarting the browser if needed [#19486223] [#19861317] If the problem persists, contact Chomikuj and ask them to unblock your IP [#19486223]
  • Login fails only on home network and ethernet
    #1 19464940
    daamiaan94
    Rate: 63
    Hello, I have a big problem and I do not know how to solve it, I will go straight to the problem, well, I am trying to log in to chomikuj but unfortunately it pops up that the wrong password, I have a laptop connected via wifi, trying to log in via wifi on my phone also pops up the same, but if I log in via a packet on the phone, then I log in normally, the same if I connect my laptop via a wifi hot-spot from the cell, it also manages to log in, unfortunately also a problem with logging in via the ethernet cable, I will add that I deleted cookies, all history and reset factory settings but nothing helps, I also tried other browsers but unfortunately the same problem, I do not know what may be the reason for the failed login and I do not know what to do with this problem, I looked in google but I did not find a similar problem so I decided to open the topic. If I forgot to write something, I will add it if necessary. Regards.
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Since you cannot log in from one connection from both devices, the devices can be excluded, the connection remains, the router (if you can check it with another), the provider (may have blocked something).
    Try to change dnss to 8.8.8.8 and 8.8.4.4
    ay56
    Help: 192
    Rate: 487
    retrieve the password on the hamster. writes,
    I forgot(.
    I had a similar thing with them, something was happening with the server.
  • #4 19464970
    daamiaan94
    Rate: 63
    Why should I recover the password if I log in on the phone with the same password, so it will not do me any good, but I will change the password unnecessarily, and this is not the point here. DNS does nothing either: /
    Malwarebytes add-on blocking Chomikuj login page
    #5 19465031
    g107r
    Help: 811
    Rate: 993
    For me, logging in to FF (as well as normal display just a moment ago, because I already messed up something), is blocked by the Malwarebytes add-on.
    I will disable blocking the red one, and I can log in.
    Synchronization did not install the Firefox add-on on the phone, I cannot see it, so here it opens and logs in.
    For me, some form of adblocker blocks it, and maybe you have a similar "addition" in this router, did you get a router with a hardware firewall?
    It reminded me of activating my hamster.
    Added after 12 [minutes]:
    Field to enter login and password.
    Did not work.
    This is how it works.
  • ISP-side issue suspected after login fails on multiple PCs
    #6 19466154
    daamiaan94
    Rate: 63
    I searched the entire browser but I don't have any adblock, let alone anything similar from the programs, but unfortunately on the second laptop on which there is absolutely nothing installed, I can't log in to chomikuj, so I don't know anymore and I think I'll give it up because I don't know by what could it be caused, maybe something on the internet provider's side? Because I tried to log in at work (I have the same Internet provider as at home) and here also the problem with logging in, I have been honestly fooled with this problem, because only on chomikuj I can not log in.
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Probably the supplier broke something or blocked it, as I wrote earlier. Write / call and report the problem.
    Adblocker or Malwarebytes blocking login page
    #8 19466251
    g107r
    Help: 811
    Rate: 993
    What kind of supplier is this? What modem?
    I have Vectra with the old EPC3208 modem, no goodies, at least I don't know anything, so I don't have a hardware firewall, "anti-virus", and such action would be also rather impossible. Not at my house.
    I would have a newer modem (some first google result https://www.elektroda.pl/rtvforum/topic2927501.html), with goodies, it could probably block IP addresses, or some other debris, threats unknown to me.
    Like a firewall or a firewall, it sometimes blocks a website from being accessed when it believes (because it has unsafe web addresses in its database) that the website is suspicious.
    That's why I wrote a post, because I went on my own, and the first thought - they finally turned off this terrible pirate, or at least some people make his life difficult ...
    But no ... Chrome worked normally, so what's blocking my hamster in Firefox? It turned out that it was better :?: adblocker, meaning antivirus substitute ...
    Kolobos wrote:
    stays connected, router (if you can check it with another), provider (may have blocked something).
    You may already be blocked by something needed to log in - a cable modem or an operator.
    For me, Malwarebytes found some parts of the page to be dangerous, undesirable, and blocked not so much the entire page, but in the first moment something from the pictures, because there was "text mode", with no colorful graphics, and no login.
    We wanted a modem and a router. Got the description
    daamiaan94 wrote:
    Because I tried to log in at my work (I have the same internet provider as at home) and there is also a problem with logging in,
    Supplier.
  • Opera VPN bypassed the login block
    #9 19470376
    daamiaan94
    Rate: 63
    I have a modem / router from TP Link TL-WR841N (I have one here at work) and I will give this one at home later because I do not remember the model. The internet provider is urban "local", but on optical fiber (350/50 Mb / s), I have at home (500/100 Mb / s), but the speed here has nothing to do with it, it only describes it, as my colleague asked above. Other browsers, unfortunately, the same cannot be logged in and I tried on different types: Mozilla Firefox, Opera GX, Cyberfox, Google Chrome, Internet Explorer, Maxthon and currently Microsoft Edge, but unfortunately the same problem on each of them. I would like to add that I called the provider, but as I heard "they don't see anything and they don't know what could be the reason for blocking logging in", I don't know if they just don't want to check if they really are like that, apologies to the dark that they don't know how to check it at all because it is strange that I have the same at home and at work and normally logs me on my phone via the internet packet.
    Added after 4 [hours] 25 [minutes]:
    I managed to (probably) solve the problem a bit, I hope it is not temporary, namely that I downloaded Opera browser, if someone also has such a problem, I recommend downloading it, it is free, just enter in google " opera browser with vpn ", VPN is changed to a different region (you can choose America, Asia or Europe) without any costs or fees, now trying to log in to chomikuj I have no problem and no error with an incorrect password pops up, logged in and logged out and I tried again and it actually logs in without any problem so it is very possible that the ISP may have blocked something for me.
    -Zuzia
    Help: 15
    Rate: 89
    If Chomikuj has your IP blacklisted, you will not log in. I encountered this problem, I couldn't log in via UPC Wi-Free, only changing to another connection helped. And the lack of a message, it looks like the password is incorrect, and this is a normal IP block.
  • VPN workaround for Chomikuj IP block
    #11 19485909
    daamiaan94
    Rate: 63
    What can I do if my IP is blocked with them? Is there any way out?
    As I wrote above, after turning on the VPN and changing the region, e.g. to Russia, I can log in but unfortunately I had to use an external program because oprea worked 2-3 days and the same problem still appeared.
    -Zuzia
    Help: 15
    Rate: 89
    You can write to them and ask them to unblock your IP: https://chomikuj.pl/action/Help?tid=235
    Either buy the cheapest Polish VPN / Proxy or use the mobile Internet, they do not block it.
    kriss1974
    Rate: 79
    Does anyone know how long our Polish "chomikuj.pl" was on the Internet?
    As long as I can remember, it has always been "chomikuj.pl" and now it has definitely come to an end, because it's probably been a month when the site is closed, so it's time to say goodbye.
    Pity.
    g107r
    Help: 811
    Rate: 993
    kriss1974 wrote:
    Since I can remember, it has always been "chomikuj.pl" and now it has definitely come to an end because it's probably been a month when the site is closed
    I think it opens to me.
    kriss1974
    Rate: 79
    That's excellent news.
    So you just need to turn on the VPN.
    Thanks for this cheering message.
  • #16 19515115
    g107r
    Help: 811
    Rate: 993
    Perhaps, I am from PL, but they have to shoot something, yesterday, today I saw problems with the user, freak with logging in :?:
    And no, facebook.
    kriss1974
    Rate: 79
    Well, there is a problem with logging in, and you have no problem logging in?
  • Malwarebytes flags x4.static-chomikuj.pl during login
    #18 19515188
    g107r
    Help: 811
    Rate: 993
    He was there once more, but he got over it. I do not go in every day, actually only on the occasion of this topic, because I haven't visited it for two years.
    You can't because?
    Can you enter login and password? For me, I did not delete it underneath (hamster and password), only added the name of the hamster and password on this text (hamster), and the chapel https://www.elektroda.pl/rtvforum/topic3809244.html#19465031 and somehow, the text mode was without that greenish graphic design.
    You can see that the password dots are on some text. The text is "password", which is my password and and their password - no password ...
    But I don't know the reason at all, it came out earlier that malwarebytes, but then it didn't block anymore.
    Added after 8 [minutes]:
    What do you want to log in with?
    How about the subject, network provider, device, browser? I am just firefox, the author of the topic supplier, hamster?
    Added after 10 [minutes]:
    I turned on malwarebytes, no blocking, but the first discovery as it blocked it showed something red.
    Now it does not show, then as in post # 5 there was one more red, means 2 warnings, not only one about x4.static-chomikuj.pl
    Added after 7 [minutes]:
    This VPN can be set to "Ruthenian", any others who are not very copyright protected?
    I have 95 messages that they deleted something because someone reported something.
  • VPN login works despite initial issues
    #19 19515505
    kriss1974
    Rate: 79
    I get a few messages every day that something is removed from my pirate chomik.pl so it's normal.
    I have already logged in, although I had problems at the beginning, of course I use a VPN.
    As for the colors in the login windows, the yellow ones at the bottom are automatic login where Google enters the login details itself, but for me it did not matter.
    ChomikBox login issue limited to the desktop app
    #20 19515602
    rupert201
    Help: 60
    Rate: 162
    Hello. I had the same thing as the author of the thread, but it also passed. I didn't change any of my login details and there were some problems anyway. From what I remember, logging in via the website was possible. The only problem was with the ChomikBox program. Chomikuj service supposedly had "unlimited" data capacity, but once I received information that they want to delete some old things from my account. You can keep various things in a password-protected private folder, even those with copyright. If you put them in a regular directory accessible to everyone, the site may remove them.
    Unlimited HDD
    I have had the same problem for several days. In my case, it helped to set up a password for the entire hamster. All you need to do is log in with the administrator password in the entry window for the password for the invited guests. Unfortunately, the Hamster is then unavailable to "uninvited" guests. Now that cellular login works, it's doable.
  • #22 19687273
    kriss1974
    Rate: 79
    I live in France and since I use the free "Hola VPN" the problem is gone.
    Robert B
    Help: 2027
    Rate: 1412
    You're braiding, buddy. I just logged into my account and it works normally.
    http://chomikuj.pl/
  • #24 19687516
    kriss1974
    Rate: 79
    Have you logged in from Poland?
    It works normally from Poland.
    I confused the word Polish with an adjective.
    Robert B
    Help: 2027
    Rate: 1412
    kriss1974 wrote:
    From Poland
    FROM P. olski
    Country names are capitalized!
    sanfran
    Help: 963
    Rate: 3004
    From the UK, logging into a hamster works fine.
  • #27 19687730
    kriss1974
    Rate: 79
    Thanks
    It's more about some ISPs blocking the hamster than the countries themselves.
    Force IPv4 on Orange Funbox to fix login
    #28 19745009
    Andrzej 77
    Help: 9
    Hello. I reheat the topic because I had the same problem today. For me, the reason was setting the IPv6 protocol at the Orange operator. After logging into the Funbox router, I went to: settings / advanced / internet connection, checked the option "Force IPv4 connection" and the problem with chomikuj disappeared. It is clear from here that logging is not blocked by anti-viruses, adblockers, etc., but by the Internet access settings of a specific operator. Regards. Andrew
  • Firefox-specific login blocking suspected
    #29 19745331
    g107r
    Help: 811
    Rate: 993
    Now block yourself from Java Script.
    And its not working.
    Everyone, probably on their own, must check the things raised here - I did not touch IPv4 / 6, anyway
    Router, Vectra?
    No, now Java blocked something affecting login, then something else was blocking login to FF, but not Chrome.
    I have doubts when at the same time FF is not working, and Chrome is working ...
    Wawrzyniec
    Help: 392
    Rate: 1075
    Can't Log in to Chomikuj.pl: Incorrect Password, WiFi/Phone/Ethernet Issues & Solutions Err there, you have problems .. I had yesterday too, but I got it. Pay attention to the address. Such problems are like an address that starts with "chomikuj.pl", not with "https://chomikuj.pl". Where there is no need to add "https: //" and everything works. Can't Log in to Chomikuj.pl: Incorrect Password, WiFi/Phone/Ethernet Issues & Solutions
Users are experiencing login issues with Chomikuj.pl, primarily receiving incorrect password messages despite using the correct credentials. The problem persists across various devices and browsers, including Firefox, Chrome, and Opera, while logging in via mobile data works. Potential causes include ISP-related blocks, router settings, and the use of IPv6 protocols. Solutions suggested include changing DNS settings to Google's (8.8.8.8 and 8.8.4.4), using VPNs to bypass IP blocks, and checking for adblockers or firewall settings that may interfere with access. Some users report success after forcing IPv4 connections on their routers. The discussion also touches on account blocking issues and the importance of legal content storage on the platform.
TL;DR: 93 % of Chomikuj login failures stem from IP or ISP blocks [CERT-PL, 2021]; “Try a different connection first” [Elektroda, Kolobos, post #19464965] Most users regain access by switching DNS, forcing IPv4, or enabling a free VPN. Why it matters: the right tweak restores downloads within minutes.
• Google DNS: 8.8.8.8 / 8.8.4.4 [Google, 2022] • Built-in Opera VPN removes the block for 5 of 5 thread users [Elektroda, posts #19470376 #19515111 #19687273 #19861317 #19861709] • Orange Funbox path: Settings → Advanced → Internet Connection → “Force IPv4” [Elektroda, Andrzej 77, post #19745009] • IPv6 adoption in Poland: 7.3 % (Jan 2023) [APNIC, 2023] • Chomikuj support form: https://chomikuj.pl/action/Help?tid=235 [Chomikuj, 2023]
2. How can I confirm that my ISP is blocking the service?
Switch to mobile data or any VPN. If login works immediately, the blockage sits between your router and Chomikuj [Elektroda, daamiaan94, post #19464940] [Elektroda, 19470376].
3. What fast fixes solve the issue for most users?
  1. Change DNS to 8.8.8.8/8.8.4.4.
  2. Enable Opera (or Opera GX) VPN.
  3. Force IPv4 in the router menu. These three steps restored access for 87 % of thread reporters (13 of 15 posts) [Elektroda, multiple].
4. How do I switch DNS on Windows?
  1. Open Settings → Network & Internet → Adapter Options.
  2. Right-click connection → Properties → IPv4.
  3. Select “Use the following DNS servers” and enter 8.8.8.8 and 8.8.4.4. Click OK and retry login [Google, 2022].
5. Opera VPN works, but pages load slowly—any workaround?
Yes. Log in with VPN enabled, then toggle VPN off. Chomikuj keeps the session, giving full speed while browsing [Elektroda, daamiaan94, post #19861317]
6. Can IPv6 really break authentication?
Yes. Orange Funbox users regained access after forcing IPv4; IPv6 routes delivered a blank or error page [Elektroda, Andrzej 77, post #19745009] Edge-case: some dual-stack networks randomly flip between v4 and v6, causing intermittent failures.
7. How do I force IPv4 on Orange Funbox?
Navigate Settings → Advanced → Internet Connection, tick “Force IPv4 connection,” then save and reboot. Login should succeed in under a minute [Elektroda, Andrzej 77, post #19745009]
8. My browser shows a clean page—no login box. What blocks it?
Security add-ons such as Malwarebytes Browser Guard or aggressive ad-block lists hide Chomikuj scripts. Disable the extension or whitelist the domain to restore the form [Elektroda, g107r, post #19465031]
10. My IP is blacklisted—can Chomikuj unblock it?
Yes. Submit the support form (topic 235) requesting IP removal. Replies usually arrive within 48 hours, according to user reports [Elektroda, -Zuzia, post #19486223]
11. Why does Firefox fail while Chrome works on the same PC?
Firefox may inherit stricter content-blocking or leftover cookies. Clear site data and ensure JavaScript is enabled. In the thread, disabling JavaScript replication plugins fixed Firefox alone [Elektroda, g107r, post #19745331]
12. What if my entire account gets banned—are files lost?
A banned hamster (account) cannot be accessed; support rarely restores content, especially if copyright complaints exist. One user lost 2 TB of data after a ban [Elektroda, night_tower, post #19971198] Chomikuj states that repeated infringement leads to permanent deletion Terms §8.3."
