BMW N46 B20 E90 2.0 150km Engine: Seeking Torque Specs for Valvetronic, Camshaft, Chain Components
Michał Rumowski 53583 5
  • #1 18025307
    Michał Rumowski
    Rate: 12
    Hello everyone. Is anyone able to help me, namely I need the tightening torques of the screws in the n46 b20 BMW e90 2.0 150 km engine. I need timing moments. Tightening valve tronic, exhaust camshaft, chain slides, chain tensioner, valve cover.
    I only know this:
    Crankshaft 300Nm
    Vanos 20 nm +2×90 degrees each
    I will be grateful for your help, regards!
    DriverMSG
    Help: 3984
    Rate: 4883
    BMW N46 B20 E90 2.0 150km Engine: Seeking Torque Specs for Valvetronic, Camshaft, Chain Components BMW N46 B20 E90 2.0 150km Engine: Seeking Torque Specs for Valvetronic, Camshaft, Chain Components BMW N46 B20 E90 2.0 150km Engine: Seeking Torque Specs for Valvetronic, Camshaft, Chain Components
  • #3 18025605
    Michał Rumowski
    Rate: 12
    Thanks a lot! Greetings
  • #4 19869452
    HNT126
    Rate: 10
    Hello, could someone give the tightening torques of the N46B20 valve cover bolts and the valvetronic assembly to the cylinder head?
  • #5 19870291
    DriverMSG
    Help: 3984
    Rate: 4883
    E90.pdf (247.53 kB)You must be logged in to download this attachment.
  • #6 21024045
    alaingaming21
    Hi im new to this forum and have the same question about the torque specs of the valve cover bolts and the valvetronic screws. I saw an admin posted an E90 document but it is in another language I can't read. Could somebody please help me out!
    Already thanks!
