Firmware Te32472s27txd: Seeking Firmware Update for Te32472s27txd Model
sergioetzi 4779 13
How can I find and load the correct firmware for a Telefunken TE32472S27TXD TV?
Use the correct panel and board data first: the thread identifies the panel as VES315SW-2D N13 and the processor as MSD92LHSW2-006F [#18255192] The working update method was to extract the firmware folder to a USB stick, enter service mode with menu code 4725, plug in the USB, choose USB operations, and press OK [#18257008] After that, wait about 10 seconds, turn the LCD off and reconnect/power-cycle it to check whether the problem is resolved [#18257008] One user also reported success after programming the 25128 EEPROM with a CH341 programmer, then running the USB file, which fixed the issue [#18258851] The file was described as intended to program the panel, and another reply noted that the provided data worked but the picture had strange colors until the correct panel information was used [#18256473] [#18255844]
  • #1 18254712
    sergioetzi
    Rate: 17
    I'm looking for a firmware te32472s27txd
  • #2 18254764
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Please provide serial number, chassis and lcd panel.
  • #3 18255192
    sergioetzi
    Rate: 17
    [img-0] [img-1] [img-2] Firmware Te32472s27txd: Seeking Firmware Update for Te32472s27txd Model
    pannello VES315SW-2D N13
    telefunken TE32472S27T
    processore MSD92LHSW2-006F
  • #4 18255586
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Is the panel reference correct?
  • #5 18255844
    sergioetzi
    Rate: 17
    grazie amico i dati che mi hai dato funzionano ma l'immagine ha i colori strani Firmware Te32472s27txd: Seeking Firmware Update for Te32472s27txd Model
  • #6 18255959
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Please provide the panel label?
  • #7 18256439
    sergioetzi
    Rate: 17
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    I will try to get the file to program the panel
  • #9 18256482
    sergioetzi
    Rate: 17
    ti ringrazio per la collaborazione
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Extract the folder to a usb pen, enter service (menu 4725), enter the pen and select usb operations and press ok. Wait 10 seconds, turn off the lcd and reconnect and check if it is resolved
    • pq.rar (12.34 KB) You must be logged in to download this attachment.
  • #11 18257118
    sergioetzi
    Rate: 17
    YOU ARE A GREAT GREAT THANK YOU
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Try it and tell me how it went so you can tell the person who got me the files
  • #13 18258851
    sergioetzi
    Rate: 17
    I thank you and I went to the end I programmed 25128 with the ch3414 programmer then I launched the file you sent me in the usb and all ok ok thanks also to the friend
  • #14 20092511
    annavivaldi57
    Level 4  
    It's this firmware can resolve my issue with LCN ??
The discussion revolves around seeking a firmware update for the Telefunken TE32472S27T model. The user initially requests the firmware and is prompted to provide additional details such as the serial number, chassis, and LCD panel specifications. The panel referenced is VES315SW-2D N13, and the processor is identified as MSD92LHSW2-006F. Users share images and troubleshooting steps, including programming the panel and using a USB drive to install the firmware. A successful update is reported after programming the 25128 chip with a CH3414 programmer and using the provided firmware file.
TL;DR: Telefunken TE32472S27T/TE32472S27TXD owners: use USB panel reprogramming with a 10‑second wait. “Enter service (menu 4725), select USB operations, press OK.” [Elektroda, Aquario_blue, post #18257008]
Why it matters: This helps fix wrong‑color images from mismatched VES315SW‑2D N13 panel settings and guides safe updates.
What firmware does the Telefunken TE32472S27T/TE32472S27TXD actually use?
Match firmware to the hardware, not just the model suffix. This unit reports panel VES315SW‑2D N13 and processor MSD92LHSW2‑006F. Use files intended for that panel/mainboard pairing to avoid display issues. [Elektroda, sergioetzi, post #18255192]
How do I update the panel firmware via the USB service menu?
Use the built‑in service routine. 1. Extract the provided folder to a USB drive. 2. Enter service menu with Menu → 4725. 3. Select USB Operations and press OK, wait about 10 seconds, power off, reconnect. “Enter service (menu 4725), select USB operations and press ok.” [Elektroda, Aquario_blue, post #18257008]
My screen shows strange colours after flashing—what does that mean?
That symptom points to a mismatched panel configuration. The set displayed abnormal colours when the initial parameters didn’t match the installed panel. Reconfirm the exact panel label and request the correct panel file. [Elektroda, sergioetzi, post #18255844]
Where do I find and how do I share the panel label?
The label is on the LCD panel sticker. Take a clear photo and share it so helpers can match the panel file precisely to your hardware. [Elektroda, sergioetzi, post #18256439]
What info should I post to get the right firmware file?
Provide the serial number, chassis, and LCD panel reference. Helpers use these details to locate the correct panel configuration and avoid mismatches. [Elektroda, Aquario_blue, post #18254764]
Is my panel reference definitely VES315SW‑2D N13—how can I be sure?
Verify the panel reference printed on the panel’s label before any programming. Community helpers explicitly asked to confirm the panel reference to prevent colour issues. [Elektroda, Aquario_blue, post #18255586]
What if the USB method doesn’t work or the TV stays the same?
Program the SPI/EEPROM directly, then rerun the USB routine. One fix used a CH3414 to write the 25128, then launched the USB file, and the TV worked properly. [Elektroda, sergioetzi, post #18258851]
What service code opens USB Operations on this chassis?
Enter the service menu with Menu → 4725. Then select USB Operations, press OK, wait around 10 seconds, power off, and reconnect AC to apply. [Elektroda, Aquario_blue, post #18257008]
Did this process actually fix the TV in the thread?
Yes. The poster confirmed success after programming the 25128 with a CH3414 and then running the USB file. The display returned to normal. [Elektroda, sergioetzi, post #18258851]
Will this firmware resolve LCN (Logical Channel Number) problems?
No. LCN comes from DVB Service Information tables and regional settings, not the panel configuration. Adjust region/LCN options or rescan channels; panel firmware won’t change numbering. [ETSI EN 300 468, 2023]
What does “USB Operations” actually do?
It triggers the service task that reads and applies the panel setup from the USB drive. The guidance specifies waiting about 10 seconds before powering off and reconnecting AC to complete. [Elektroda, Aquario_blue, post #18257008]
Any pitfalls or edge cases to avoid during flashing?
Using a file for the wrong panel can produce abnormal colours or other artifacts. Always validate the exact panel label before programming to prevent this failure mode. [Elektroda, sergioetzi, post #18255844]
