Razor for Daily Clean Shave Against the Grain: Best Electric Models for Zero Irritation
karolfejs 18984 8
  • #1 18274379
    karolfejs
    My job requires me to be clean shaved against the grain every day. Shaving with an ordinary disposable razor causes quite severe skin irritation in my case. I decided to buy an electric razor, so I have a question for you. Can you advise me on any particular model that is going to score zero? There is a razor that can shave your stubble like this?
    Regards.
  • #2 18274402
    Marek39
    Help: 40
    Rate: 153
    you will have to change jobs because I have not seen such machines, the shortest hair that leaves one I have met is 0.4 mm, most from 0.5 to 1 mm
  • #3 18274423
    koziołek
    Help: 54
    Rate: 61
    Tell us what the job is.
  • #4 18274461
    Ture11
    Help: 573
    Rate: 1130
    Being in HydePark, I would write: 'Movie plan of the razor advertisement' :-)
  • #5 18274498
  • #6 18277369
    karolfejs
    I serve in the army. So maybe I will try one that would also leave this 1mm, maybe it will look like somehow. Are you able to recommend something from yourself?
  • #7 18278458
    Marek39
    Help: 40
    Rate: 153
    I am but nobody pays me for advertising (PW)
  • #8 18278503
    karolfejs
    Gentlemen, I just read what I wrote calmly and I see that I asked the question wrongly, because you received it as I am looking for a razor for hair on my head, and I mean shaving my facial hair. Now I have realized why you were so surprised by my question. Sorry.
  • #9 18278545
The discussion revolves around finding an electric razor suitable for daily clean shaving against the grain without causing skin irritation. The original poster, who serves in the army, seeks recommendations for a model that can achieve a close shave, ideally leaving hair at a length of 0.5 to 1 mm. Responses indicate skepticism about achieving a "zero" shave with electric razors, with suggestions leaning towards models that minimize irritation. The Philips OneBlade is specifically recommended as a viable option, noted for its effectiveness and availability of newer versions.
