[Solved] Best Jigsaw Under PLN 300: Makita 4239, BLACK & DECKER KS901PEK, Einhell TH-JS 85 & More
ketonek 10116 9
Which jigsaw under PLN 300 is best for straight, trouble-free home use?
The Bosch Professional GST 8000 E is the most solid recommendation in this price range, and if you can add a little above PLN 300 it is the preferred choice; the Makita 4239 is also considered OK [#17108941] [#17118300] Good saw blades matter as much as the tool itself, so do not buy cheap sets; forum users recommend original Bosch blades or good individual blades instead [#17119212] [#17123367] [#17123537] A useful jigsaw should have tool-free blade changes, speed control, work-light/backlighting, and vacuum extraction support, with about 500 W of real power [#17119212] Laser is not important here, but lighting the cutting line can still be useful, especially when the cut is not perfectly straight [#17118300]
  • #1 17108914
    ketonek
    Rate: 8
    Hello, I am looking for jigsaws up to PLN 300 for home use. It is important to me that the jigsaw cuts straight and does not cause problems. I don't need any water jets in the form of a laser (which doesn't work anyway) or led lights there. I am thinking about Makita 4239 now, but it does not have a blade without a tool change (although I can somehow live with it), but I am also worried about weak power. There are other devices on the market, e.g. BLACK & DECKER KS901PEK, Einhell TH-JS 85, Skil 4581 CA, Ryobi R18JS-0, or something else?
  • #3 17109182
    ketonek
    Rate: 8
    I can add that much, but I will wait, maybe someone else will have an idea, and if not, I will take this bosha
  • #4 17118300
    witoj
    Level 30  
    Help: 110
    Rate: 138
    Nothing more solid than this Bosch is not at this price, Makita 4239 is also ok, as for laser tinsel is actually not needed but lighting the cutting line (especially not straight) very useful.
  • #5 17119212
    wiesiekmisiek
    Help: 259
    Rate: 524
    Do not forget to buy good saw blades (do not regret the money for them), otherwise even if you buy the most expensive and the most advertised jigsaw, a poor saw blade will lead its cutting line anyway. The jigsaw should, however, have a quick and tool-free saw blade replacement, speed control, backlighting of the workplace, possibility of connecting to an industrial vacuum cleaner (useful for work in the apartment). The power is a minimum of 500 W (but the real 500W).
  • #6 17123206
    ketonek
    Rate: 8
    I already have this Bosch at home, for now it seems solid, and what saw blades do you recommend?
  • #8 17123537
    wiesiekmisiek
    Help: 259
    Rate: 524
    I buy original Bosh saw blades, they go like butter (of course, to work in wood). They are more expensive than the ones presented above, but I am honestly worth the price. Buy at the beginning 2 or 5 pieces in a blister and cut anything even in hard wood, you'll find out what I write.
  • #9 17126052
    ketonek
    Rate: 8
    I will do that too, thank you for your help. T / C
  • #10 17126055
    ketonek
    Rate: 8
    Purchase of a jigsaw recommended by forum users
✨ The discussion centers around selecting a jigsaw for home use under PLN 300, with a focus on models that provide straight cuts and reliability. The Makita 4239 is considered, though concerns about its power and lack of tool-free blade change are noted. Other models mentioned include BLACK & DECKER KS901PEK, Einhell TH-JS 85, Skil 4581 CA, and Ryobi R18JS-0. Users emphasize the importance of quality saw blades for optimal performance, recommending Bosch blades for their effectiveness. Additional features such as speed control, tool-free blade replacement, and the ability to connect to a vacuum cleaner are highlighted as desirable.
