Best Face & Head Shaver for Bald Look: Battery-Powered, Wet/Dry Options Under 300 PLN
antmalin 14640 11
  • #1 16363212
    antmalin
    Rate: 9
    Hi, I would like to buy the first ever face and head shaver. I do not know about them at all, I would ask for advice. For 20 years I have been shaving my face and head bald every week with a Gillette Mach3 razor, but I'd like to try something different. It is best if it is powered by a battery with the possibility of dry and wet shaving.
  • #2 16363478
    krzysiozak
    Level 40  
    Help: 508
    Rate: 1140
    From what I noticed, your current shave is the best option.
    Shaver if you buy it only network. Because the mains-rechargeable battery means it is charged from the mains, and can only be used when disconnected from the mains, which, after frequent use, will be suitable for returning to a complaint or to the trash if it exceeds the warranty period a little.
    I will say again, the current shave is maybe tedious but the best, I've changed some of these shavers. In each case, if you buy it network and the most expensive, then you can expect the expected results.
  • #3 16363505
    E8600
    Help: 525
    Rate: 2474
    With a hard coat, the machine sooner or later becomes blunt and no matter what the blades do not have.
  • #4 16365146
    antmalin
    Rate: 9
    Thanks to Krzysiozak for opinions, they will definitely be useful when buying. And which foil or rotary device is better for shaving the head ,?
  • #5 16365298
    krzysiozak
    Level 40  
    Help: 508
    Rate: 1140
    And for this question you should find the answer on the web by typing in the search engine: "men's head or foil shaver." For me both are not satisfying.
  • #6 16365319
    antmalin
    Rate: 9
    I have done it for a long time but there are not too many opinions about shaving the head with shavers.
  • #8 16368226
    antmalin
    Rate: 9
    But this is a hair clipper and I'm looking for a shaver.
  • #9 16370791
    r103
    Level 37  
    Help: 280
    Rate: 932
    And the current thing is wrong - how it works well, it's more important, today's equipment works nicely but with durability it's not like that for 20 years :-)
    For example, I am going to cut my hair for 20 years with such a cheap little razor, it would cost less than 100 zlotys Panasonic made in Hungary and work and why change it ???
  • #10 16371989
    antmalin
    Rate: 9
    The current nothing is wrong because it is not and never has been. :)
    Well, I chose two and I can not decide, maybe somebody has one. Foil BRAUN 3050 and rotary Philips S5100 / 06.
    Felini
    Moderator
    Help: 123
    Rate: 429
    krzysiozak wrote:
    [...] Shaver if you buy it only network. Because the mains-rechargeable battery means it is charged from the mains, and can only be used when disconnected from the mains, which, after frequent use, will be suitable for returning to a complaint or to the trash if it exceeds the warranty period a little.
    I had a few shavers; Braun (model I do not remember), Philips 6890 and currently Philips 860/16. All were networked battery operated and operated on both mains and battery power. When the battery ran out and you had to shave quickly, I connected to the mains and the shaver was full power. Even the manual says that you can use the shaver both from the mains and the battery, here is a quote from the operating instructions p. 108 at the top in the PDF attachment: " Note: The shaver can also work on mains power. Just plug it into an electrical outlet. "
    krzysiozak wrote:
    [...] if you buy it network and the most expensive, then you can expect the expected results.
    My first Philips was the most expensive model, the current cost PLN 270, so at most the average price range. I would say that this new shaver is also shaving
    well as the previous one, maybe even better. Facial hair is removed quickly and properly without skin irritation, the shaver is also lighter and quieter than the 6890 model.
    I would have a shaver with moving heads to shave my face or head. They adjust to the curvature of the face / head and thus the goal is more effective.
    Shaver with foil is much louder and vibrates during work. The most expensive Philips models are about 1,600 zlotys, I do not consider spending such money unfounded.
    These shavers have several gadgets (speed control, display of the remaining shaving time, etc.), completely useless for me.
    • Philips_PT860.pdf (200.67 KB) You must be logged in to download this attachment.
  • #12 16372159
    antmalin
    Rate: 9
    Thanks Felini. I bought PHILIPS S5100 / 06. I close.
✨ The discussion revolves around selecting a suitable battery-powered face and head shaver for achieving a bald look, with a budget under 300 PLN. The user, accustomed to using a Gillette Mach3 razor, seeks alternatives that allow for both wet and dry shaving. Responses highlight the pros and cons of different shaver types, including foil and rotary options. Some participants recommend specific models, such as the Philips S5100/06 and Braun 3050, while others share experiences with various brands like Philips and Moser. The consensus suggests that while traditional shaving methods are effective, modern electric shavers can provide convenience and efficiency, especially when they can operate on both battery and mains power.
