Huawei P9 Lite (2017) Low Memory Issue: Increase Storage without Root or Moving Apps to SD Card
szymon1051 32919 10
Can I increase the storage on a Huawei P9 Lite (2017) without rooting it or moving apps to the SD card manually?
Yes, the thread suggests the practical workaround is to use the SD card as internal/adoptable storage instead of trying to expand the phone’s built-in memory. One reply says you can format the SD card as internal memory, and that it should be possible on Huawei too [#18319385] Another reply says many newer phones hide this option in the UI, but you can force it with ADB: enable USB debugging, run `sm list-disks`, then `sm set-force-adoptable true` and `sm partition disk:179,64 private` [#18480678] After that, the phone may show the SD card with an odd size, but the storage works as internal space [#18480678]
  • #1 18316113
    szymon1051
    Help: 5
    Rate: 67
    I have a Huawei P9 lite (2017) and it is low on memory, hardly ever installed and takes up something.
    Is it possible to somehow increase the memory without rooting the phone and forcing you to move some applications to the SD card?
  • #3 18316173
    cuuube
    Help: 36
    Rate: 267
    I have similarly ... free 690MB
    5.59GB firmware
    7.42GB applications
    cache data 294 MB
    videos 0
    and somehow it flies
  • #4 18318011
    staś pytalski
    Help: 760
    Rate: 1437
    This is a deliberate policy of Google and the manufacturers. Memory is clogged up with all these updates. Applications require more and more space as well as increasingly powerful devices. You can take out a new phone from 2016 and try to download all the updates, if there is enough memory ... In the past you could try to transfer applications to the memory card, new phones do not have it anymore (except for Motorola and Nokia). For me, playing root is a short-term solution. Sooner or later, something will limit the functionality of the phone. This business just has to be "spinning". Consider writing a letter to Santa ;) .
  • #5 18319385
    margi85
    Help: 5
    Rate: 21
    You can always format the SD card to internal memory. I think it can be done in Huawei as well.
  • #6 18319733
    cuuube
    Help: 36
    Rate: 267
    How to do it ?
    Can it be in the Sony M4 aqua?
  • #7 18319758
    staś pytalski
    Help: 760
    Rate: 1437
    In old androids, when you entered settings> applications> after selecting the application, you selected the memory and there you could change either the device memory or the memory card.
  • #8 18319768
    cuuube
    Help: 36
    Rate: 267
    I know this, so I have done with those that allow it
  • #9 18320234
    Allx84
    Help: 13
    Rate: 35
    See what takes up so much space, recently my chrome cache was 4gb.
  • #10 18320269
    cuuube
    Help: 36
    Rate: 267
    I have chrome turned off. Internal memory used 2.51MB, but maybe I'll do an overview of the rest.
    So fast I have some apk holding 100-200MB internal.
  • ADB method to adopt SD card as internal storage
    #11 18480678
    szymon1051
    Help: 5
    Rate: 67
    There is almost nowhere such an option, neither in huawei nor in samsung or xiomi, almost everyone blocks.
    However, there is a brute-force solution https://forum.xda-developers.com/p8lite/help/how-to-extend-storage-using-sd-card-t3614396
    We enable adb via usb on the adb computer.
    The adb shell
    >> sm list-disks
    We will read something like: disk:179,64
    The phone shows e.g. -6 GB on the sd card but it works :) .
    If I do not know how to unscrew it :) .
The discussion revolves around the low memory issue faced by users of the Huawei P9 Lite (2017). Users express concerns about insufficient storage due to application updates and cache data. Suggestions include formatting the SD card to function as internal storage, although this method may not be universally supported across all devices. A workaround using ADB commands to enable adoptable storage is also mentioned, allowing users to partition the SD card for additional space. Users are encouraged to check which applications consume the most memory, with specific mention of Chrome's cache taking up significant space.
