Kogan KALED32DVDVA - TV is cycling through boot logo would like to try a firmwar
Icy-Wolverine 5739 5
  • #1 18381976
    Icy-Wolverine
    Hope someone can help. I have a Kogan KALED32DVDVA it is booting to the logo, and repeating this cycle over and over again. I have seen this problem with other Kogan TV's on youtube and the solution appears to be a firmware update. Unfortunately I can not find the bin file for my TV.
    I believe these are the important details
    Make: Kogan
    Model: KALED32DVDVA
    Chassis: TP.SIS231.P83
    Panel: CX315DLEDM
    There is also a sticker on the tp.sis231.p83 board that reads AJ32T03 T1410-03
    as well as a barcode that reads A14100166-0A00704
    Hoping someone can help with either the bin file or another solution
    <br>
    Kogan KALED32DVDVA - TV is cycling through boot logo would like to try a firmwar Kogan KALED32DVDVA - TV is cycling through boot logo would like to try a firmwar Kogan KALED32DVDVA - TV is cycling through boot logo would like to try a firmwar Kogan KALED32DVDVA - TV is cycling through boot logo would like to try a firmwar Kogan KALED32DVDVA - TV is cycling through boot logo would like to try a firmwar
  • #2 18389237
    lisek
    Service technician RTV
    Help: 6363
    Rate: 6896
    Catch the contact on ( billobirillo ) , give this person a full number. model serial number ... (the first 8 letters of the serial number (it begins with G9 ???...),)
    Read Link
  • #3 18389555
    jezrdna
    Help: 46
    Rate: 68
    Chassis known from Manta. I think it was 3204 or 3201.
  • #4 18390589
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    Hello, if you can copy the eprom, try copying and saving the read file, then clearing the eprom and then programming again with save file.
  • #5 18395218
    Icy-Wolverine
    Read Link
    Thank you very much. But I can not find serial number beginning with G9.
    Thank you. It looks very similar I will see if this will point me in the right direction.
    Thank you very much. Sorry I am new so I have no idea how to do this. I will look into it now.
    Icy-Wolverine wrote:
    Read Link
    Looks like I need to buy an EZP2010 or something similar. Only $15, I think I will give it a shot
  • CH341A reflash with matching 25Q64 bin file
    #6 18446495
    Icy-Wolverine
    Ok. Finally got the TV working. I bought a CH341A programmer off eBay. It comes with a clamp that attaches to the 8 pins of the flash memory which is great because I didn't have to de-solder the BIOS.
    I downloaded version 1.30 from https://www.kazmielecom.com/2018/07/27/ch341a-usb-mini-programmer-software-free-download.html
    I backed up previous firmware, erased chip, did a blank check, open file, write, verify. Same problem stuck in boot loop.
    I ended up googling the main board tp.sis231.p83 and panel cx315dledm and matching up the flash memory 25q64.
    I found a bin file on this website http://www.fanzo.org/forum/viewtopic.php?t=28019
    I had to Google translate as my Serbian is not very good.
    I did the same as before erase, blank check, open file, write verify.
    It says Vinchi on boot but everything works well and is in English also.
    Thank you to Spin from Fanzo.org for posting the bin code back in 2015 and everyone else here that chimed in.
