Monarch LE-50D3 50 FHD LED TV: Continual Booting Loop with Kogan Firmware on T.S506.81 Mainboard
Archetypal 3042 6
  • #1 18240073
    Archetypal
    Hi everyone,
    This problem has me stumped. The brand listed (Monarch) does not seem to exist anymore and the model number matches with a contex TV (same description etc). Upon further inspection it seems someone has flashed the firmware with Kogan firmware as this is the logo that displays when the TV is booting. It turns on, displays the logo for about 4 to 5 seconds, turns off, turns back on and this repeats endlessly.
    The mainboard inside states that it is a T.S506.81 which seems to be quite common in some brands. I have downloaded one bin file from here but cannot get it to try and flash to the new one to see if I can fix it.
    Here are the specs on the back of the TV.
    Brand: Monarch
    Model: LE-50D3
    50" FHD LED TV
    Any help would be appreciate in to how I can stop this from happening or potentially fix it.
    Thank you all so much,
    Regards
    Adrian
  • #2 18247083
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    I have a smart tech file, but unfortunately I don't know if it's working, as I haven't had a chance to test it yet
    Smart Tech LE-5018
    • GD25Q32B_U2.rar (3.37 MB) You must be logged in to download this attachment.
  • #3 18249538
    Archetypal
    Thank you. I will test it and get back to you.
  • #4 18531747
    SpecialBownie
    I have the exact same problem and managed to use Kogan Agora's firmware but the remote doesn't work so looking to try another firmware. What firmware are you using?
    My system info:
    ver.31028
    TP.S506.81/T.S506.81B
    SW update name SIS506BD81.bin
    Kogan uses the same SW name but different remote codes so can't use the remote even though the TV works now. Do you have your firmware dump that I can try?
  • #5 18547724
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    And what is the brand of your equipment?
  • #6 18829932
    camstevo15
    Did you happen to figure out the issue?
  • #7 19959653
    SpecialBownie
    Still can't get the remote to work but the picture seems fine. Figured out a way to connect the audio too but the main problem is the remote.
✨ The Monarch LE-50D3 50" FHD LED TV is experiencing a continual booting loop after having Kogan firmware flashed onto its T.S506.81 mainboard. The TV displays the Kogan logo for 4-5 seconds before restarting. Users have reported similar issues, with one successfully using Kogan Agora firmware but facing remote control compatibility problems. Discussions include attempts to find alternative firmware solutions and the challenges of remote functionality despite the TV displaying images correctly.
