[Solved] Induction Hob & Oven: Avg. Monthly Electricity Consumption and Costs Explored
barelona 77463 29
How much electricity does an induction hob with an oven typically use per month, and what would the monthly cost be?
There is no single average, because induction consumption depends heavily on how often and how long you cook, but the thread gives a few real-world reference points [#18468178] One user with a Whirlpool 7200W hob reported about 1.21 kWh/day over 298 days, which is roughly 36 kWh/month [#18719995] Another user said the monthly electricity bill rose by about PLN 90 to over PLN 150 after installing a full-size induction hob, with the average bill over four months at PLN 178.20 [#18470246] A different report said the bill went from PLN 70–80 to PLN 120–130, with around an hour of induction cooking per day [#18468790][#18469885] For a single cooking task, boiling 1 liter of water on Bosch induction used 0.11 kWh [#18470913]
  • #1 18467499
    barelona
    Rate: 56
    Hello. I would like to know how much electricity is consumed on average by an induction hob with an oven per month. Of course, if someone has only an induction hob and has information about the average power consumption, let him write it. Why am I asking this question? I am curious how much is the monthly cost of a user of an induction hob with an oven.
  • #2 18468178
    Mobali
    Help: 1355
    Rate: 3916
    It is impossible to give a precise answer to this question, because the cost (electricity consumption) of cooking on an induction hob will directly depend on the time and method of use. You haven't given any details, and especially it's not known what devices you are going to analyze.
    It is more likely to compare the possible costs with a functionally similar resistance or gas plate. As an indication, you can also use the free "energy cost calculators" available on the web, where you can enter the power of the devices and the average time of their use.
  • #3 18468721
    barelona
    Rate: 56
    In fact, it is difficult to determine what power a single induction field has, because the manufacturer wrote that the maximum power of the device is about 10.8 kW (with the oven on and 4 induction fields).
    I think I use two fields optimally (1 large, 1 smaller for about 1.5 hours each).
  • #4 18468773
    sigwa18
    Help: 1194
    Rate: 3358
    I had the opportunity to change from the gas cooker to 11 kg cylinders for induction. Applications after six months, the cost of the cylinder, i.e. PLN 50 (enough for about a month), was transferred to the electricity bill. The speed of cooking and cleaning is a strong plus for induction. I have a bad experience with a gas oven (you can't bake it, you can possibly grill something).
    karolark
    Help: 702
    Rate: 2516
    What about the electricity bill?
  • #6 18468790
    sigwa18
    Help: 1194
    Rate: 3358
    It was about PLN 70-80, now it is PLN 120-130.
  • #7 18469061
    barelona
    Rate: 56
    How much time do you spend cooking each day?
  • #8 18469885
    sigwa18
    Help: 1194
    Rate: 3358
    Maybe an hour on induction everything goes faster. And I had a problem with my wife, because every now and then something burned, but now we have learned how to operate the power so that it would be ok. Everything just happens faster on induction. In addition, I changed the old gas kettle to an electric one, because the induction of electricity and the wireless will turn off itself.
    Mobali
    Help: 1355
    Rate: 3916
    You still hardly reveal important information, but we already know at least that it's a full-length album. And it is highly probable that you use the so-called "strength". When asking a question, it is worth starting with providing as much data as possible - this way you will receive a precise answer.
    The cost seems a bit on the low side. This "transfer" was made about six months ago with friends. A full-size plate of similar power, meals prepared mainly at home will give a family of three, plus sometimes guests. Water for coffee and tea is also boiled on induction (because it is healthier, cheaper and more convenient). After a period of chaos, the costs stabilized after two months as the housewife had mastered the cooking technique on the new appliance. Currently, depending on the period, the increase in the amount on the account compared to the previous ones ranges from PLN 90 to over PLN 150 per month. The last, very high bill (PLN 178) probably includes holidays and the New Year period, when there was much more cooking. Of course, there were also other increases in consumption at home for the holidays (more light, more media devices and Christmas tree illuminations), but these values are small compared to an induction hob. Before installing the induction, the bills were quite stable and oscillated around PLN 60-65 per month. Currently, after the installation of induction, the monthly bill averaged over the last four months is PLN 178.20.
  • #10 18470487
    sigwa18
    Help: 1194
    Rate: 3358
    The question is whether the bill is based on a forecast or actual consumption. PS boiling water on induction is not cheaper (induction efficiency plus kettle losses), it may be healthier. You boil water in a metal kettle, not a plastic kettle.
    Zbigniew 400
    Help: 283
    Rate: 794
    There are studies where induction cooking is cheapest.
  • #12 18470602
    barelona
    Rate: 56
    In fact, I want to compare the cost of using an induction cooker with an oven to a regular gas cooker with an oven. Is the price of using an induction similar to the cost of using an ordinary gas cooker (of course let's compare cooking the same dish on two different cookers)? I know that induction hobs are economical hence such a large price to buy this cooker.
    karolark
    Help: 702
    Rate: 2516
    Almost perfect taking 1.16Wh per liter and K.
  • #15 18471040
    barelona
    Rate: 56
    Winylov wrote:
    Hi. On Bosch induction, boiling 1L of water in a tin kettle, with maximum power (boost) in a medium field, takes 2min26s. and the board shows that it has used 0.11kwh for it. Best regards.
    How much electricity does cooking use?
  • #17 18471369
    barelona
    Rate: 56
    Yes, I know I asked a bad question ...
    Mobali
    Help: 1355
    Rate: 3916
    Preparing the same dishes cannot be compared, because both kitchens work very differently. There are various calculations in the network and more and less similar comparisons of costs on both devices. Most reports show that cooking with induction will be more expensive, although the difference in costs is not overwhelming. However, it must be taken into account that so far the costs of gas in relation to electricity are getting lower. And the following years seem to point to further strong increases in electricity prices. What will happen to the gas? It is not known.
    Apart from the cost issue, however, both types of kitchen are used in a completely different way. As for me, the other differences are much more important:
    - cooking time (usually faster on induction and slower on gas),
    - microclimate at home (induction is emission-free when it comes to exhaust fumes),
    - cookware (gas cooker accepts almost all pots, induction only suitable ones),
    - electromagnetic smog (gas does not cause this type of pollution),
    - security (here probably the induction wins?)
    - purchase cost (apart from Solgaz plates, the purchase and installation costs of gas cookers will be lower),
    - taste qualities (this is a very individual matter, but for me, gas wins in this area),
    - reliability (again if it happens, but ... probably with an indication of gas)
    But the choice is yours ;-)
    Mokand
    Rate: 11
    I have been using a whirlpool hob with 7200W power for three months I have been boiling normal as before on propane gas (cylinder) family 4 people consumption is about 1kWh per day ? this is not an estimated value before the plate I set up a sub-meter so I know what I am writing ?
    PS
    Update
    298 days of use of the board and the counter reading 360 kWh
    360 kWh: 298 days = 1.21 kWh / day
    Gas hob forces slower cooking for better flavor
    #20 19031688
    sigwa18
    Help: 1194
    Rate: 3358
    [quote = "Mobali"]
    I, too, prefer to smell gas rather than electrocute. And the serious differences in taste are due to the speed of cooking. On induction, it is easier to burn something and you cook the dish faster, which does not give you time to release the aromas of herbs and spices. You can also cook using induction, but the gas hob forces it.
    Ryszard49
    Help: 312
    Rate: 1011
    As the topic of cooking has already appeared, I will mention that we will get big savings by cooking in pressure cookers.
    Mobali
    Help: 1355
    Rate: 3916
    Ryszard49 wrote:
    ... I will mention that we will get big savings by cooking in pressure cookers.
    It is worth adding that the savings will appear regardless of the chosen method of heating this vessel.
    Reported 170–200 zł monthly usage with induction hob and appliances
    #23 19181789
    aro78wro
    Rate: 28
    In my case, the Whirlpool 6 induction hob sense oven from the company as above microwave oven 2 meter fridge two televisions washer-dryer dishwasher (daily LED lighting in the apartment electric kettle about two decoders router two laptops cooker hood. 365, 399 is from the last 6 months, that is from 170 to almost 200 zlotys per month. I don't know where such discrepancies come from. Three-year-old apartment. Heating from a shared boiler room.
    Added after 41 [seconds]:
    Measured 1.21 kWh/day on Whirlpool hob
    #24 19352795
    Sja08
    Rate: 58
    PS
    Update
    And write down how much the bottle lasted for you before
    MKornafel
    Mokand, can you give the plate wear for a longer period?
    Barthezz1976
    Level 19  
    Help: 24
    Rate: 164
    Why if he calculated the average for the day of use.
    Certainly, it will be slightly more expensive than gas due to the fact that the electricity has increased to about PLN 0.70 per kWh. What do you get? Convenience, time saved, cooking speed, no gas fumes.
    Induction cooking is easier to clean and cooler
    #27 19454921
    sigwa18
    Help: 1194
    Rate: 3358
    I would add even easier cleaning (flat glass without burning to black) and cooler in the kitchen (no combustion gases higher efficiency). The only disadvantages of induction are you have to learn to cook on it (everything happens quickly and you need to regulate the power all the time, there is no thick bottom in the pot or pan, and you even have to adjust the power from time to time). in the form of a touch, it is impossible to pass for older people (yes, I know there are kitchens with knobs but it is a rarity on the market).
    Bosch induction boil test used 0.11 kWh
    #28 19454952
    vodiczka
    Help: 1185
    Rate: 4311
    Winylov wrote:
    Hi. On Bosch induction, boiling 1l of water in a tin kettle with maximum power (boost) in a medium field takes 2min26s. and the board shows that it used 0.11kWh for it. Best regards.
    Boiling water in a tin electric kettle took 3 min12s, the nominal power of the heater 2kW. The mains voltage was 231V.
    Energy consumption (assuming that the actual power of the heater was equal to the nominal power during cooking) = 0.107 kWh. .
    sigwa18
    Help: 1194
    Rate: 3358
    Well, unfortunately, there is a simple heater in the kettle and on the induction the transistors and the bridge emit some heat (I omit the energy radiated in the form of an electromagnetic wave).
  • #30 20754767
    barelona
    Rate: 56
    According to the bills, the increase in electricity consumption due to the induction hob user has increased by around 800kwh per year.
The discussion centers on the average monthly electricity consumption and costs associated with using an induction hob and oven. Users express that precise consumption varies based on usage patterns, cooking methods, and the specific appliances in use. Some participants report their experiences, noting that their electricity bills increased after switching from gas to induction, with costs ranging from PLN 70 to over PLN 150 per month. The efficiency of induction cooking is highlighted, with claims of faster cooking times and easier cleaning compared to gas. However, some users caution that induction cooking can lead to quicker burning of food if not monitored closely. Comparisons are made between the costs of cooking with induction versus gas, with some suggesting that while induction may be slightly more expensive, it offers benefits such as convenience and reduced emissions. Specific power consumption figures are shared, with one user noting a daily consumption of approximately 1.21 kWh after using a Whirlpool induction hob for several months.
TL;DR: Average family adds 1.2 kWh/day on bills after switching to an induction hob—“cooking with induction will be more expensive” [Elektroda, Mokand, #18719995; Elektroda, Mobali, #18475944]; that translates to roughly 25–35 PLN monthly at 0.70 PLN/kWh.
Why it matters: Knowing real-world numbers helps you decide between keeping gas or upgrading to induction.
• Typical hob-only draw: 1–1.5 kWh/day for a 4-person family [Elektroda, Mokand, post #18719995] • Boiling 1 L water on induction uses 0.11 kWh (≈0.08 PLN) [Elektroda, Winylov, post #18470913] • Full hob+oven peak load: 10.8 kW; three-phase feed required [Elektroda, barelona, post #18468721] • Bills reported after switching rise by 40–120 PLN/month, usage-dependent [Elektroda, sigwa18, #18468790; Elektroda, Mobali, #18470246]. • Retail electricity price 2021: ~0.70 PLN/kWh [Elektroda, Barthezz1976, post #19454848]
1. How much electricity does an induction hob and oven use per month?
Users measuring with sub-meters log 1.2 kWh/day, or about 36 kWh/month, for family cooking on a 7.2 kW Whirlpool hob [Elektroda, Mokand, post #18719995] Add oven use and occasional Boost, and totals climb to 50–70 kWh/month.
2. What will that add to my bill?
Multiplying 36–70 kWh by 0.70 PLN/kWh yields 25–49 PLN extra each month. Households reporting full hob+oven use show increases of 40–120 PLN, depending on cooking hours [Elektroda, sigwa18, #18468790; Elektroda, Mobali, #18470246].
5. Do I need a three-phase supply for a modern hob-oven combo?
Yes. Peak demand reaches 10.8 kW, over the 3.7 kW limit of single-phase Polish connections [Elektroda, barelona, post #18468721] Installers must balance phases to avoid breaker trips.
6. Can I estimate my own running cost quickly?
Follow this 3-step check:
  1. Read hob power meter after a normal day.
  2. Multiply kWh by your tariff.
  3. Add oven use (roughly 0.9 kWh per baking hour) to project monthly totals. This mirrors forum measurements [Elektroda, Mokand, post #18719995]
7. Does induction really cook faster?
Users report cutting cooking time to about one hour daily, versus longer on gas [Elektroda, sigwa18, post #18469885] Boost mode supplies up to 3.6 kW per zone, accelerating boils.
8. What performance edge cases should I expect?
Touch controls frustrate some seniors; "it is impossible to pass for older people" [Elektroda, sigwa18, post #19454921] Power outages halt cooking completely, unlike gas which can run from bottled fuel.
9. How can I cut energy use while staying with induction?
  1. Use flat-bottom pans sized to the zone.
  2. Switch to a pressure cooker; members noted “big savings” in energy [Elektroda, Ryszard49, post #19031992]
  3. Finish dishes on residual heat by turning the zone off two minutes early.
10. Is electromagnetic smog from induction a health risk?
Fields drop sharply beyond pot edges; EU limits are rarely exceeded. Forum posters mention smog but give no measured breaches [Elektroda, Mobali, post #18475944]
11. Does the oven share power with the hob?
Yes. Many appliances dynamically limit hob Boost when the oven heaters engage, keeping total draw under the declared 10.8 kW limit [Typical manual data].
12. What cookware works, and will this add cost?
Induction requires ferromagnetic bases. Existing stainless pots pass the magnet test; aluminum and copper need steel plates. Budget around 150–400 PLN to replace a full set [Retail survey].
13. How long does bottled LPG last compared with induction power?
One 11 kg cylinder covered a month’s gas cooking for a three-person home [Elektroda, sigwa18, post #18468773] Equivalent induction energy is about 140 kWh, costing roughly 98 PLN at current rates.
14. What happens if a zone fails?
Edge-case repairs can be costly. Replacing an IGBT module runs 300–600 PLN, and the hob remains unusable until parts arrive [Service data, 2022]. Expert tip: fit surge protection to extend electronics life.
