  • #1 16508147
    Estrowyswiat
    Approx . My problem is that I left one burner on the hob for the whole night. Sclerosis. I'm afraid to admit this to my boyfriend. The question is whether this is a threat. What electricity bill can I expect and can it be that the heater can burn out?
  • #2 16508152
    stanislaw1954
    Help: 2013
    Rate: 4675
    What board, how much power? You'd be more concerned about fire if there was something flammable nearby.
  • #3 16508167
    sanfran
    Help: 963
    Rate: 3004
    The maximum is about PLN 1.50 per hour.
  • #4 16508195
  • #5 16508205
  • #6 16509429
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    I do not know what hob you are talking about, but it is quite possible that the cooking zone will turn itself off after a certain time. Mine is 2 hours.
  • #7 16514511
The discussion revolves around the concern of leaving an electric hob burner on overnight. Users addressed the potential risks, emphasizing that the primary concern would be fire hazards if flammable materials were nearby. The cost of electricity for running the hob was estimated to be around PLN 1.50 per hour, with some users noting that the total cost for the night would likely be a few zlotys. It was mentioned that many modern hobs, particularly induction types, have safety features that may automatically turn off the burner after a set period, typically around two hours. Overall, the consensus is that the situation is not likely to cause significant damage or financial burden.
