PHILIPS 43PUS6401/12 Restart Issue - Seeking USB Autorun_QM163E for QM16.3E LA Chassis
Indyczes 14073 6
  • #1 18493304
    Indyczes
    Help: 186
    Rate: 272
    As in the subject, QM16.3E LA chassis on Andriod, maybe someone knows how to put it back on its feet? File needed on USB autorun_QM163E_
  • #3 18493645
    Indyczes
    Help: 186
    Rate: 272
    OK helped. After downloading, do not unpack, just change to UPG.
    Thank you.
    Regards
    • wipedatatool_QM16.3ELA.zip (1.91 MB) You must be logged in to download this attachment.
  • #4 18493708
    stacho57
    Help: 169
    Rate: 448
    Something is wrong with the attached file. Can you explain?
  • #5 18494289
    Indyczes
    Help: 186
    Rate: 272
    The file must be converted to UPG, do not unpack it, in this form to pena, disconnect the plug from the socket, press the yoistika button on the back of the tv housing to the bottom position and, holding it, turn on the network. It takes a while before it catches up.
    https://hdtvpolska.com/forum/topic/47547-55pus6561-ci%C4%85g%C5%82e-reset-boot-loop/
  • #6 19167432
    eprom
    Help: 11
    Rate: 46
    Hello, I have the same problem with the 49PSU6401/12, can this batch be used for this model?
  • #7 21280148
    ARGAMEDON
    Help: 8
    Rate: 43
    "The file needs to be converted to UPG "with what to convert it ? I came to zip change to upg.
The discussion revolves around resolving a restart issue with the PHILIPS 43PUS6401/12 TV, which utilizes the QM16.3E LA chassis on Android. Users seek a USB autorun file named UPG_QM163E_ to restore functionality. A helpful response provides a link to a file and instructions to convert it to UPG format without unpacking. Additional guidance includes pressing a button on the TV while powering it on to initiate the recovery process. Other users inquire about the applicability of the provided solution to similar models, such as the 49PSU6401/12.
