[Solved] Renault Master 2018: Replacing Visteon R&Go Radio with MediaNav - Adapter Availability
AlMeu 57258 6
  • #1 18563970
    AlMeu
    Rate: 15
    Hi everyone,
    I have a Renault Master 2018 which is equipped with a radio R&Go Visteon.
    I want to replace this radio with a navigation MediaNav. Some older models of this car come from factory already equipped with this navigation type from factory.
    If there is already an adapter for this update I would like to have a link where to find out.
    If not I want to make it. I know very well the pin connections for MediaNav, but I don't know the pin connection of this radio Visteon.
    Pictures for Visteon radio R&Go are down:
    Spoiler:
    Car dashboard with a radio displaying Digi FM station.
    Image of the back of a Visteon car radio with visible informational stickers and cables.
    Rear view of a car radio connector with visible colored wires.
    Close-up of a hand holding a white car radio connector.
    View of the back of a car radio with visible connectors.
    Close-up of a white radio wire connector held by a person.
    Close-up of a car radio plug held in a hand.
    Connection for MediaNav are down:
    Spoiler:
    Rear panel of a car radio with visible connectors and ports.
    View of a car radio wiring connector on a wooden desk.
    White plastic car radio adapter with wires.
    24-pin radio connector diagram with wire function description.
    Diagrams of car radio audio connector and remote control connector.
  • #2 18660608
    xxl13
    How is your project going on?
    I'm exactly in the same situation...I have a Renault Master 2018, with radio R&Go. I purchased a MediaNav Evolution, with adaptor wiring and gps antenna...but the hard part just begins: I would need the support for the MediaNav and the centre panel of the dashboard to fit the head unit. Unfortunately I can't find anywhere at a reasonable price :(
    Diagram of a Renault Master dashboard with parts outlined in red. Photos show the disassembly of the radio in a 2018 Renault Master with replacement by a MediaNav Evolution system and wiring.
  • #3 18661256
    AlMeu
    Rate: 15
    Hi @xxl13
    I already solved my problem by myself. Everything works well. As I see you already fit the unit in the place and the unit is running.
    What is not OK for you? I didn't understand.
  • #4 18661297
    xxl13
    No, unfortunately, this is not my car, just this is how it should be... :(
    My car still looks like this:
    Car console with FM radio displaying ONDA VIP on the screen.
    And I have the MediaNav, too:
    MediaNav screen in a car displaying app icons such as Radio, Media, Phone, Android Auto, Driving Eco, Navigation, and Settings. [img-1]
    But I still would need the support and the middle dashboard panel to install it.
  • Request for Visteon R&Go wiring diagram and adapter
    #5 19053770
    rmeneghello
    AlMeu wrote:
    Hi everyone,
    Spoiler:
    Spoiler:
    Hi @AlMeu,
    I 'd like to replace the same radio. If you solved your problem could you help me please with a wiring diagram of the original radio (function/wire color)?
    thank you very much
  • #6 19054730
    AlMeu
    Rate: 15
    Here is the connection of Visteon.
    But I bought an adapter already made ... faster.
    • Visteon.pdf (45.18 KB) You must be logged in to download this attachment.
  • #7 19054890
    AlMeu
    Rate: 15
    Bought an ready made adapter.
The discussion revolves around replacing the Visteon R&Go radio in a 2018 Renault Master with a MediaNav navigation system. Users express challenges in finding an adapter for the installation and the necessary dashboard support for the MediaNav unit. One participant successfully created a wiring solution and purchased a ready-made adapter, while others seek wiring diagrams for the original Visteon radio. Visual references of the current setup and the MediaNav unit are shared to illustrate the installation challenges.
