John Deere 6900 Tractor Issue: Hour Meter Not Displaying, Only Blinking Kilometers
Beduin01 8676 5
  • #1 18587951
    Beduin01
    I have a problem with the John Deere 6900 tractor. The problem is, it does not show hours, but when I turn the key, it shows u and then only blinks kilometers after ignition. Anyone help?
  • #2 18599310
    Markus
    Help: 8
    Rate: 38
    Either a short circuit, or a damaged switch that you change to display on the dashboard.
    If it is turned on before turning the key, it enters the programming mode and you can, for example, change km to miles.
    If that doesn't work, it means the memory is overwritten or damaged and needs to be repaired.
    If you can't make it, get in touch with priv, I'll give you a lead to the guy who will help you.
  • #3 18599369
    tolo
    Help: 233
    Rate: 1177
    Probably corrupted eeprom content, you can fix it.
  • #4 21072757
    slaweksadkowski8
    Hello, I have a similar problem. It doesn't count the horsepower and doesn't show speed, shaft etc. I fitted the meter to another tractor and it works.
  • #5 21072836
    tolo
    Help: 233
    Rate: 1177
    It's a working meter, how about the condition of the installation?
  • #6 21072842
    slaweksadkowski8
    It was checked. The guy who checked it decided that this controller under the cab was defective. Now the question is does anyone fix it
    Damaged controller with connected wires visible under the cabin. .
