[Solved] Sony KD-49X8305C Android Boot Loop Issue: eMMC Replacement, Easy JTAG Plus & PSU Board Advice
guppyno1 9714 5
  • #1 18808030
    guppyno1
    Hi
    My Sony TV had the Android boot loop issue, so I replaced the eMMC (H26M52103FMR). The dump was programmed via Easy Jtag Plus. The dump went fine with no errors reported. When I put the board back, nothing happened—no power light. So instead of reballing the chip again, I found the pinout diagram on the net. I just ISP it again with another dump; still the same outcome, no power.
    Did hard reboot, inserted new firmware via USB, still nothing.
    Is there any other IC/component which needs replacing? Any help or advice would be appreciated.
    Also changed the PSU board too.
  • #2 18876375
    querij
    Help: 42
    Rate: 226
    Change the mainboard
  • #3 18876605
    GanCegall
    Help: 339
    Rate: 1630
    guppyno1 wrote:
    when I put the board back nothing happened no power light
    Try to solder chip again
    guppyno1 wrote:
    I replaced the emmc
    for a new? used? programmed?
  • #4 19313133
    Guardado
    Rate: 9
    Can you Share dump working file?
  • #5 19316992
    Adam4321
    Help: 31
    Rate: 85
    Have you moved extCSD from the damaged bone to the new bone? Probably the TV is trying to start with Boot1 and it should with UserData.
  • #6 19415508
    guppyno1
    Solved by getting another dump
