How to Calculate Percentage Modulation from RMS Voltage Before and After Modulation?
249 9
How do I calculate the percentage modulation when the carrier RMS voltage is 5 V before modulation and 5.9 V after modulation?
The percentage modulation is 18% if 5.9 V is the modulated RMS maximum and the corresponding minimum RMS value is 4.1 V. Using the standard AM formula, percent modulation = 100 × (Emax - Emin) / (Emax + Emin), so 100 × (5.9 - 4.1) / (5.9 + 4.1) = 18% [#21668170] This is equivalent to calculating directly from the given values as 100 × (5.9 - 5) / 5 = 18% [#21668175] A result of 1.25 would mean 125% modulation, which is over-modulation and not consistent with the stated voltages [#21668177]
  • #1 21668169
    Ozai Ozuma
  • Percent modulation calculated as 18% from RMS voltages
    #2 21668170
    Steve Lawson
  • RMS modulation index needs missing carrier data
    #3 21668171
    David Adams
  • #4 21668172
    Steve Lawson
  • Deriving 88.6% modulation from power ratio
    #5 21668173
    David Adams
  • RMS amplitude method for estimating modulation depth
    #6 21668174
    Steve Lawson
  • Direct calculation of 18% modulation from RMS values
    #7 21668175
    Donald Dahl
  • #8 21668176
    Steve Lawson
  • #9 21668177
    Dishan Pangan
  • #10 21668178
    Steve Lawson
The discussion addresses how to calculate the percentage modulation of an AM signal given the RMS voltage of the carrier before (5V) and after modulation (5.9V). Initial attempts to calculate the modulation index yielded incorrect or unclear results, such as 1.25 or 125%, which would indicate over-modulation. A commonly referenced formula for percent modulation is 100 × (Emax - Emin) / (Emax + Emin), where Emax and Emin are the maximum and minimum envelope voltages. However, this formula typically applies to peak voltages, not RMS values. One approach assumed the minimum RMS voltage as 5 - (5.9 - 5) = 4.1V, leading to an 18% modulation index. Another method used power relations: with a 50-ohm load, unmodulated power is calculated as V²/R, and total power after modulation as (5.9)²/50, then applying the formula M = sqrt[2 × (Pt/Pc - 1)] to find a modulation index of approximately 88.6%, which seems too high for the given voltages. The consensus favors the simpler calculation of percent modulation as 100 × (5.9 - 5) / 5 = 18%, consistent with the assumption that the RMS voltage increase corresponds directly to modulation depth. It is noted that modulation percentage should ideally range from 0 to 100%, and values exceeding this indicate over-modulation and distortion. The discussion highlights the importance of distinguishing between RMS and peak voltages in modulation calculations and the need for additional waveform information (e.g., minimum voltage or scope measurements) for precise determination.
