Title: Oscam NC+ Settings - Setup Guide for Karte NC+ Cameleon & Troubleshooting Dark Channels
John121212 30930 12
How can I make the dark NC+ channels work again in Oscam, or disable all NC+ channels in Oscam?
The thread says the operator is closing the system, so channels will keep disappearing unless you use a special Oscam setup with the required “parka” entered in a properly configured Oscam [#18892316] Before anyone can troubleshoot the dark channels, you also need to provide real Oscam logs from those channels so they can check whether the card is being queried and whether it matches [#18889814] The posted `[reader]` block is not a log, so it was not enough for diagnosis [#18892305]
  • #1 18886955
    John121212
    I have Karte NC + Cameleon and for some time some programs cannot be watched. It's dark. I read that Canal + is up to something. There is some way to put all nc + programs off of oscam
  • #2 18889814
    n6210
    Help: 126
    Rate: 169
    You watched any logs with oscam on these channels that do not work? There is an inquiry to the card? Does the card match? Whatever?
  • #4 18890412
    John121212
    So far, apart from Polsat 2 and Historia, all channels are working. But as I read, they will all slowly disappear. I have a Dreambox with oscam and a Cameleon card.
  • #5 18891298
    n6210
    Help: 126
    Rate: 169
    Does this answer mean you will not share logs of your activity on these channels so that you can try to diagnose the problem? Well wait until the other channels disappear as you read :)
  • #6 18892088
    John121212
    Sorry nie jajazylem
    [reader]
    label = nc+
    protocol = internal
    device = /dev/sci0
    caid = 0100,0B01
    detect = cd
    mhz = 450
    cardmhz = 2700
    group = 1
    emmcache = 1,3,2,0
    blockemm-unknown = 1
    blockemm-g = 1
    saveemm-u = 1
    saveemm-s = 1
    ratelimitecm = 4
    ratelimittime = 9000
    srvidholdtime = 0
    Dzisial tez polsat wylaczyli
    • oscam.txt (608 Bytes) You must be logged in to download this attachment.
  • #7 18892254
    charlee
    Help: 30
    Rate: 135
    vito007 wrote:
    You got info from a friend what to read, but you continue this topic here without providing any relevant information. What box do you use and what oscam do you have installed?
  • #8 18892282
    John121212
    Dreambox 7080 HD and Oscam 11.577
    Thank you very much
  • #9 18892305
    vito007
    Help: 73
    Rate: 214
    John121212 wrote:
    [reader]
    label = nc+
    protocol = internal
    device = /dev/sci0
    caid = 0100,0B01
    detect = cd
    to nie są logi.
  • #10 18892316
    charlee
    Help: 30
    Rate: 135
    As you know, the operator seals the system, individual channels start to fade out, you need a special oscam and the so-called "parka" which you have to enter in a properly configured oscam.
  • #11 18892412
    John121212
    Can you help me somehow or will it be a problem?
  • #12 18892428
    charlee
    Help: 30
    Rate: 135
    I can only direct you.
    PW
✨ The discussion revolves around issues with the Karte NC+ Cameleon card, specifically regarding dark channels on the Dreambox 7080 HD using Oscam 11.577. Users report that certain channels, such as Polsat 2 and Historia, are not accessible, with concerns that more channels will soon be affected due to operator actions. Participants suggest checking Oscam logs for inquiries and card matching, and mention the need for a special Oscam configuration and a "parka" to maintain access to channels. Links to external resources are provided for further reading on the topic.
TL;DR: 2 channels were dark — "apart from Polsat 2 and Historia, all channels are working" — fix dark NC+ Cameleon on OSCam by enabling logs, verifying reader settings, and preparing for pairing requirements. [Elektroda, John121212, post #18890412]
Why it matters: This FAQ helps Dreambox/OSCam users with NC+ Cameleon cards diagnose dark channels and understand pairing-driven changes.
Why are my NC+ Cameleon channels going dark on OSCam?
The operator is tightening access controls, and channels are being phased to pairing-only. As one expert noted, "you need a special oscam and the so-called 'parka'" configured correctly. Without pairing, affected services stop clearing progressively. Plan for pairing-capable OSCam and proper setup. [Elektroda, charlee, post #18892316]
Which receiver and OSCam version does this thread use as a reference?
The case discussed uses a Dreambox 7080 HD with OSCam 11.577 (r11577). Knowing the exact box and build helps align configs and logs. If your environment differs, note it when asking for help. [Elektroda, John121212, post #18892282]
What base OSCam reader settings were shown for a Cameleon in the internal slot?
Example settings: protocol=internal, device=/dev/sci0, caid=0100,0B01, mhz=450, cardmhz=2700, plus EMM handling entries. These are configuration lines, not logs. Wrong CAIDs or clocking can block ECMs. Confirm your slot path and CAIDs match your card. [Elektroda, John121212, post #18892088]
How do I capture useful OSCam logs when a channel is dark?
Enable logging and reproduce the issue for at least 60 seconds. Include ECM/EMM lines and note the exact channel and time. Share logs with sensitive data redacted so others can see card inquiries and reader matches.
  1. Enable OSCam webif logging.
  2. Tune the failing channel 60–120 seconds.
  3. Copy ECM/EMM lines and channel/time info. [Elektroda, n6210, post #18889814]
Are configuration snippets the same as logs?
No. Config snippets show how OSCam is set, but logs show what happens at runtime. Helpers need logs to see ECM requests, EMMs, and reader matching. As noted, “to nie są logi” when only configs were posted. [Elektroda, vito007, post #18892305]
Why did Polsat go dark today on my setup?
A user reported, “today they also switched off Polsat,” indicating the ongoing rollout reached that service. Expect additional channels to follow as pairing requirements expand. Prepare your pairing-ready setup to maintain access. [Elektroda, John121212, post #18892088]
Only two channels failed at first—what does that tell me?
Initially, two channels (Polsat 2 and Historia) failed while others worked. That pattern suggests a staged migration, not a total outage. Track which services fail and when, then compare against your logs for trends. [Elektroda, John121212, post #18890412]
Do I need “parka” (pairing data) and a specific OSCam build?
Yes. With the system being sealed, you need a pairing-capable OSCam and to enter the required “parka” correctly. “You need a special oscam and the so-called 'parka'” to keep channels clearing. [Elektroda, charlee, post #18892316]
Where can I read more background on the NC+/Canal+ changes?
See the thread linked by a contributor for details on the changeover and implications. It provides context for pairing and OSCam requirements as channels transition. [Elektroda, vito007, post #18889857]
What should I include when asking for help on dark channels?
Provide OSCam logs from the failing channel, plus the channel name and time. Helpers explicitly asked for logs to verify card inquiries and reader matches. Without them, you may just “wait until the other channels disappear.” [Elektroda, n6210, post #18891298]
Will a single setting unlock all NC+ channels in OSCam?
No. There isn’t a universal toggle. The operator’s sealing requires pairing and a suitable OSCam. Without that, more channels will stop clearing over time, regardless of reader tweaks. [Elektroda, charlee, post #18892316]
How do I know if the card is being queried and matched by OSCam?
Check your logs for ECM requests reaching the reader and a matching CAID. If there’s no inquiry or no matching reader, channels stay dark. Confirm CAIDs, device path, and reader assignment. [Elektroda, n6210, post #18889814]
How are EMMs handled in the shared example config?
The example blocks unknown and global EMMs and saves unique and shared EMMs: blockemm-unknown=1, blockemm-g=1, saveemm-u=1, saveemm-s=1. Review your EMM handling so necessary updates aren’t unintentionally filtered. [Elektroda, John121212, post #18892088]
Can I get one-on-one guidance to set this up?
A helper offered to direct the user via private message. If you need individualized steps, request guidance similarly and share your exact box, OSCam build, and logs. [Elektroda, charlee, post #18892428]
