OSCam Canal+ and Cline - I have a problem with receiving a program on the tuner
pilatus 23730 5
  • OSCam local card blocking Cline fallback
    #1 19865803
    pilatus
    I have a ZGEMMA H2S tuner, a card from Canal + - Cameleon card works in it. OSCam is configured, the channels from the package I pay for are displayed correctly, but I have a problem with this tuner reading the Cline of the channels I am missing. The donor server is ok - (checked on another tuner), in the logs when I switch the channel to the one that I do not have in the package, if it finds that the card does not have permissions for this channel, the tuner cannot download the keys from the donor server and gets tired again not the Cyfra+ card.
    If I turn off the READER with the Cyfra + card, there are also problems with receiving channels from "Cline". Then I observe in the tuner's web panel in the status tab that dvbapi in the LB Value/Reader entry not found (4925 ms) i.e. not found and there is a very high ping - and of course there is no image.
    I searched a bit on the Internet about it, I traced the OSCam configurations, but I can't deal with it. I changed the configuration files several times, updated the tuner, etc., but it didn't help.
    Does anyone know how to get the config so that the tuner receives channels both from the Canal+ card and from "Cline"?
    There was no problem with it until I changed the config after I got the problem of disappearing channels from the Canal+ offer on my own equipment.
    Channels from Canal+ are now displayed without a problem, but there are no those from the donor Cline.
    The tuner acts as a donor for the 2 tuners I have in other rooms. And everything is fine with them. i.e. they receive keys from the Canal+ card, and what is not on it they download from "Cline", which they have configured in their oscam.server file
    And this is my config:
    oscam.conf
    [global]
    logfile = /tmp/oscam.log
    logduplicate lines = 1
    nice = -1
    maxlogsize = 512
    preferlocalcards = 2
    lb_mode = 10
    disablecrccws = 1
    DisabLCRCCWS_ONLY_FOR = 1708: 000000; 1811: 003311; 09c4: 000000; 0500: 030b00,042820; 0604: 0000; 1819: 00006d; 0100: 00006d; 1810: 000000; 1884: 000000; 0900 000000;0500:50F000;1883:003311
    ecmfmt = c&0p/i/d/s/l
    [cache]
    [newcamd]
    port = 22000@0000:000000
    key = 0102030405060708091011121314
    keepalive = 1
    [cccam]
    port = 12000
    nodeid = 27E047BF108514D6
    version = 2.1.3
    reshare = 1
    [dvbapi]
    enabled = 1
    au = 1
    user = dvbapi
    boxtype = dreambox
    [webif]
    httpport = 8888
    httpuser =
    httppwd=
    httprefresh = 15
    httppollrefresh = 12
    httpallowed = 0.0.0.0-255.255.255.255
    oscam.server
    [reader]
    label = 1813_canal+
    protocol = internal
    device = /dev/sci0
    caid = 1813
    mod1= BF5675BBA4B2CD3B1DB0F6ADE5CC1EDFCCCEB265A807465223AF9E0E26A97709F6DA14DED4F48849CECCD750B4DF2EE7CE375A957384A9336B34C624DB7311CDBDF6C958BCF4E30B713FE594E0449A6C211CE74F8410136DB1B50EE4D8AFE142330AFBE63214E4372CE8553C2E55CA89
    idir = FFFFFFFF
    key3588 = D63D2585550DFC8C7DE85E93063E748CF22B76E9E805709AA2F1B6503142F24C15837ABD1C78CFF2842EA0B2AAE497B4588A2D8B66E4CDC8730138E584A56A42934A069C48806D4E4840DCA45ADDE7FBDB52649C0BFE060306E82D72D63C6EF22C19C54FDEA1EA6A16C51E0B45E40D4610415C12FD9D523DD4C3C7EBC8FA6CFF81741ADF7B2B48BE
    data50 = B6711C868C3EE72533A4E08C1364B83AEEFDEBE9FB54156A8776D872CBC41FF2E5EA2CBAF4F26A58C521EC53E310FC494354E49ECE6CD0F9631B724FAB0C8BAEC1F66C346AD
    mod50 = DB9E1F1BD23C6153444E444D8E6C471E162EC63C599D44F476E0D40C3840E0FDB7B63D174DD73B575543983F2F2DFB94E3644958AE642C91636A6BE55528478EB7A422479598C68E6F1FC9D647BBC4D5
    nuid = xxxxxxx
    cwekey0 = xxxxxxxxxxxxx
    cak7_mode = 1
    ecmwhitelist = 1813:64.6A
    ecmheaderwhitelist = 803061006800075C00,813061006800075C00,803067006800075C00,813067006800075C00
    detect = cd
    nagra_read = 1
    detect_seca_nagra_tunneled_card= 0
    mhz = 540
    cardmhz = 2700
    group = 1
    [reader]
    label = donor_cline
    description = donor_cline
    protocol = cccam
    device = donor_cline,18801
    user = xxxxxxxxxx
    password = xxxxxxxxxx
    inactivitytimeout = 30
    group = 1
    cccversion = 2.1.2
    ccceepalive = 1
    nuid and cwekey0 are wyixed as requested by the donor
    same username and password
    My equipment is:
    Brand & Model: Zgemma H.2S
    Processor: Broadcom 7362
    OE version: OE-Alliance 4.4
    Firmware version: OpenATV 6.4.20200831 (2020-08-29)
    Kernel version / Drivers date: 4.10.12 / 20180830
    OSCam: tit Build: r11581 Compiler: mipsel-ssl102-libusb
    To view the material on this forum you must be logged in. - channels from Cline - nothing is visible, READER of the Canal+ tab is on
    To view the material on this forum you must be logged in. - channels from the Canal+ card reception without any problem
    To view the material on this forum you must be logged in. - channels from Cline, READER of the Canal+ card turned off, sometimes the channels are there but occasionally, usually there are none, I don't know what it depends on, but if the timeout is at a decent level, i.e. a few sers of ms, the channel sometimes receives, and if it is like in the picture, then it's always dark.
  • #2 19865829
    kiko80
    Help: 67
    Rate: 163
    Why don't you restore the previous config??
  • Prefer donor tuner keys for faster channel switching
    #3 19865850
    pilatus
    Unfortunately, I don't have the previous configuration.
    And even if it was soft, it was so old that it was no longer possible to watch it.
    Then the channels from my Canal+ package did not work for me. I got the problem of "disappearing channels from the "Canal+" offer.
    Anticipating the question - I do not want to get rid of the card, because I have a package available for another tuner at home from it. Cline, on the other hand, gives me channels that are not included in the package. Besides, if there is a problem with the donor or the Internet, at least I have something to watch. In addition, keys from my donor tuner switch channels much faster on my client tuners than those from the Internet.
  • #4 19866445
    tomaszlonski
    Help: 347
    Rate: 901
    There are no appropriate entries in dvbapi.oscam I will not give it, look for it yourself because it is breaking the rules of the forum, you are using sharing.
  • Missing dvbapi priority or ignore rule for Canal+
    #5 19866525
    pilatus
    oscam.dvbapi I have:
    # dvbapiconfig
    # types:
    # P - Priority
    # format:
    # P: :[]:[]:[]
    #I - Ignore
    # format:
    # I: :[]:[]:[]
    #M - Map
    # format:
    # M: :[]:[]:[] :[]
    #D - Delay
    # format:
    # D: :[]:[]:[]
    # Delay answers that come too fast (eg from cache)
    D: 0500 90
    D: 1830 320
    D: 1838 320
    D: 1843 320
    D: 1860 320
    D: 186A 320
    D: 098C 120
    D: 098D 120
    D: 098E 120
    D: 09C4 120
    # Canal+ platform
    P: 1813:000068
    I: 0
    Could someone point me to what's missing?
    tomaszlonski
    Help: 347
    Rate: 901
    Everything is missing, entries are not for Polish operators and cards. Change the forum better and look for more information.
