Samsung UE55D6530WSXZF Smart TV Keeps Rebooting: BN94-05539G Board - Solutions? (90)
atmane60 3282 9
Why does a Samsung UE55D6530WSXZF with BN94-05539G main board keep rebooting, and how can it be fixed?
The most likely cause is corrupted firmware / a failing U-Boot section in the mainboard memory, not the power supply, so constant rebooting is usually a mainboard issue [#18981656] The suggested fix is to replace the mainboard with the same model or reflash the firmware using a programmer [#18981656] This may require lifting the chip with hot air or working through the eMMC if it is BGA-type memory [#18981656] There is no USB solution for this fault [#18997297]
  • #1 18965632
    atmane60
    Mark: Samsung
    Model: UE55D6530WSXZF
    Chassis (main board, components): BN94-05539G
    LCD Screen/Panel (if exist): ......?
    More informations: S/N Z8RQ3SQBB00553D
  • #2 18968609
    samsi3102
    Help: 15
    Rate: 203
    SEND COD BN41-......
  • #3 18972067
    promo7uk
    Rate: 15
    think firmware is needed mate have you checked all voltages
  • #4 18972722
    atmane60
    Yes, the voltages are intact I think it is power supply, It has a problem Because the device Restarting Not the software I need remove protection BN44-00428A
    I need Scheme to remove protection power supply Carte NO/ BN44-00428A
  • #5 18978860
    atmane60
    keep rebooting not stuck on the logo
    promo7uk
    Rate: 15
    LIKE I'VE SAID IT'S FIRMWARE CORRUPTED,! I'm a TV engineer work as a head engineer for a company I repair electrical goods for a living mate, if you're not going to take my advice you're in the wrong place, power supply won't cause reboot constantly., it's an issue with firmware ,, where "u boot" fails,, it has a corrupt section in the firmware, this will cause the loop.. nothing to do with power supply.. Samsung are common for it, as well.
    replace mainboard with same model or reflash with firmware... you will need tools such as programmer, and hot air machine to lift chip.. rest is up to you or EMMC connection if it's BGA,
  • #7 18983473
    tomasz wojcicki
    Help: 26
    Rate: 347
    Try to rflow cpu on mainboard SDP...
    Good luck
  • #8 18986807
    promo7uk
    Rate: 15
    tomasz wojcicki wrote:
    Try to reflow cpu on mainboard SDP...
    Good luck
    if cpu fails it won't cause reboot. it won't boot at all or can cause picture fail, and you wouldn't even get the logo. how do you figure this will repair his issue,
  • #9 18986913
    atmane60
    Is there a solution by USB?
  • #10 18997297
    promo7uk
    Rate: 15
    NO.
    REPLACE MAINBOARD OR EMMC REPROGRAM WITH A PROGRAMMER.
The Samsung UE55D6530WSXZF Smart TV is experiencing continuous rebooting issues, likely due to firmware corruption rather than power supply problems. Users suggest that the mainboard (BN94-05539G) may need replacement or reprogramming of the EMMC chip. Some responses indicate that checking voltages is essential, but the consensus leans towards firmware issues, particularly with the "u boot" section. A professional engineer advises reflashing the firmware or replacing the mainboard, as power supply faults typically do not cause such reboot loops. There is also a query about potential solutions via USB, but the recommended actions focus on hardware interventions.
