[Solved] D3d11 - Compatible GPU (feature level 11.0 shader model 5.0) is required to run
bulaboys22 22161 9
Why does Fortnite show that a D3D11-compatible GPU with feature level 11.0 and shader model 5.0 is required on my MSI N210 graphics card?
Your MSI N210 / Nvidia GeForce 210 does not meet Fortnite’s GPU requirement, so the game cannot run on that card. The exact model given is N210-MD1GD3H / LP MSI, which is a GeForce 210 with shader model 4.1, and it is an 11-year-old GPU [#18981676][#18981691] Installing DirectX 11 or changing drivers will not make it compatible with feature level 11.0 / shader model 5.0 [#18981691] The YouTube video does not prove otherwise; the uploader’s own comments say the game cannot be run on this GPU [#18981795] If you want to play, you need a newer graphics card that meets the required D3D11 feature level [#18981691]
  • #1 18981491
    bulaboys22
    Rate: 56
    Hello, I get a message after starting fortnite
    a d3d11-compatible gpu (feature level 11.0 shader model 5.0) is required to run
    Please help I installed Direct x 11,
    I still do not work, I have a weak graphics card because msi 210 ..
    I am asking for support and help.
  • #2 18981652
    cysiekw
    Help: 1003
    Rate: 1410
    bulaboys22 wrote:
    raficzna because msi 210 ..
    please provide the exact model of this card
  • #3 18981676
    bulaboys22
    Rate: 56
    Planning to purchase a MSI GTX750TI
    But on YouTube I can see that playing fortnite on this tab is possible on the lowest settings ..
    So the game should start ..
  • #4 18981691
    cysiekw
    Help: 1003
    Rate: 1410
    In Polish, it is Nvidia geforce 210 which has a shader model 4.1, card from 11 years ago, it is not possible to run this game on this gpu
  • #5 18981701
    bulaboys22
    Rate: 56
    Can't update it or something?
    Why do they play on this tab on youtube?
    On google they show that there may be a problem with the driver ??
  • #6 18981761
    cysiekw
    Help: 1003
    Rate: 1410
    Provide a link to this video on yt
    cysiekw
    Help: 1003
    Rate: 1410
    Yes, it's not GT, except read the comments under this video, it is not possible to run this game on this gpu, the uploader of this video himself wrote yes
  • #9 18981817
    bulaboys22
    Rate: 56
    Now at least we know the origin of the bug ..
    Thank you for your help .. it's always better to ask than to look for a solution .. greetings
  • #10 18981828
    bulaboys22
    Rate: 56
    Added after 5 [minutes]:
    I learned the truth about the possibilities of this graphics card ..
The user encountered an error message indicating that a D3D11-compatible GPU (feature level 11.0, shader model 5.0) is required to run Fortnite. The user has an MSI 210 graphics card, which is outdated and only supports shader model 4.1, making it incompatible with the game. Despite seeing gameplay on YouTube with similar hardware, it was clarified that the game cannot run on the user's GPU. The discussion highlighted the importance of checking hardware specifications and driver updates, ultimately leading to the conclusion that the user's graphics card is insufficient for running Fortnite.
