FUJIFILM Instax Mini 9 - Blinking Lights Issue: Can't Take Photos, Tried New Batteries & Clichés
Davi15 49404 2
  • #1 18995278
    Davi15
    Level 4  
    Hello, I have an Instax 9 Mini and it is impossible to take a picture and nothing, because all the LEDs from mr at fire, new batteries give nothing and new cliches.
  • #2 19165376
    maciekkkk3333
    Rate: 32
    I had the same problem, I replaced the batteries with 3 different ones from other companies. Panasonic Alkaline power batteries proved to be the solution. Many people also wrote that these batteries helped. good luck :)
  • #3 19548691
    miszelos
    Rate: 132
    I have the same problem. Instax had previously run on Kodak batteries - after replacing the film, the lead-up lamp came out halfway and then there was a symptom like a colleague Davi15.
    Will replacing the battery with the ones mentioned above actually help?
