Panasonic TX-L32EM5E: Auto Shutdown & Blinking Red Light Issue
abramkyr1995 1590 6
  • Requesting blink pattern details for Panasonic shutdown fault
    #1 21351211
    abramkyr1995
    I have a TV PANASONIC TX-L32EM5E. Its turning on normally but after 5-10 minutes its turning off automatically and blinking red light. What I have to do?
    *I turn off eco operations and all automatic switching off..
    AI: Does the blinking red light follow a specific pattern, such as a certain number of blinks before pausing?
    every second
    AI: Did anything change or happen recently before this issue started, like a power surge or a firmware update?
    No.
  • #2 21351473
    oskmar
    Help: 12
    Rate: 67
    abramkyr1995 wrote:
    flashes red
    It flashes all the time , is this some kind of error code ?
    Αναβοσβήνει συνέχεια, είναι αυτό κάποιο είδος κωδικού σφάλματος ?
  • #3 21351674
    abramkyr1995
    >>21351473 I don't know.
    oskmar
    Help: 12
    Rate: 67
    Service Manual with error codes :
    • panasonic_tx-l32em5e_chassis_km19e.pdf (20.73 MB) You must be logged in to download this attachment.
  • #5 21352157
    abramkyr1995
    >>21351922 I made a factory reset and now it's working normally. If it happens the same again, do you have firmware to download it, please? (Bin file).
  • #6 21352738
    oskmar
    Help: 12
    Rate: 67
    abramkyr1995 wrote:
    >>21351922 I did a factory reset and now it works normally. If the same thing happens again, do you have the firmware to download? (bin file).
    No I don't have
  • #7 21353098
    abramkyr1995
    >>21352738 Thank you for your fast response my friend!
The discussion revolves around a Panasonic TX-L32EM5E television that experiences automatic shutdowns after 5-10 minutes of operation, accompanied by a blinking red light. The user has disabled eco operations and automatic shutoff features but still encounters the issue. Responses include inquiries about the blinking pattern, suggestions to check for error codes, and a reference to a service manual. A factory reset was performed by the user, which resolved the issue temporarily. The user also inquired about firmware availability in case the problem recurs.
