[Solved] Dacia Dokker 1.5 dCi 2019: Orange Zigzag Light On - What Does It Mean?
262380 31
What does the orange zigzag warning light on a Dacia Dokker 1.5 dCi mean, and how can it be reset?
The orange zigzag light is a service/fault indicator, and in this case it turned out to be an oil service reminder. The forum notes that this lamp can mean a defect or inspection/service call, and that it lights up when the engine oil change interval or mileage has expired [#19132135] [#19132180] One reply also says that on these cars you often need a diagnostic connection/Clip after an oil change to clear the message [#19132380] The original poster later confirmed the fix: holding the onboard-computer button cleared the warning, because it was an oil service notice [#19132479]
  • #1 19132129
  • #2 19132135
    kkknc
    Help: 1910
    Rate: 6660
    Defect or inspection. You have in the manual.
  • #3 19132150
  • #4 19132173
    kkknc
    Help: 1910
    Rate: 6660
    Simple and easy with Clip.
  • #5 19132177
  • #6 19132180
    sunrise84
    Help: 979
    Rate: 877
    "This message lights up when the car calls for a service visit, together with this warning light to indicate that the engine oil change interval or mileage has expired."
    "This is an emergency mode. The car enters this mode after detecting a fault that may endanger the engine."
    A few sentences from the DACIA forum.
  • #7 19132188
  • #8 19132189
    sunrise84
    Help: 979
    Rate: 877
    So if everything else in the car is working properly and the car has power, it's time for a check-up.
    But for 9,000?
  • #9 19132191
  • #11 19132197
  • #12 19132198
    sunrise84
    Help: 979
    Rate: 877
    Page 52 of this manual.
  • #13 19132201
  • #15 19132217
  • #16 19132237
    balonika3
    Help: 1310
    Rate: 3676
    The question is - where and from whom did you buy the car, because it's quite suspicious ...
  • #17 19132242
  • #18 19132246
    balonika3
    Help: 1310
    Rate: 3676
    Kafin34 wrote:
    Or maybe the car is also looking at how many years ago the oil was changed?
    How many years ago could the oil be changed, if the car is a year old?
  • #19 19132248
  • #20 19132249
    balonika3
    Help: 1310
    Rate: 3676
    Did you buy a one-year car without instructions? Then where is she?
  • #21 19132250
  • #22 19132259
    balonika3
    Help: 1310
    Rate: 3676
    Kafin34 wrote:
    Why are you asking me?
    Who should I ask? Have you bought a one-year car without basic documents and are you still surprised? I am asking because it looks like a purchase from some scam. That's it. But I'm going to sleep. Maybe something will be clear tomorrow
  • #23 19132373
    ALIBABA I
    Help: 219
    Rate: 532
    that's it and the annual car and 9,000 on the counter, zero documents and where the service book or maybe this model and year were not obligatory
  • #24 19132380
    kkknc
    Help: 1910
    Rate: 6660
    Online manuals. So that's not a problem. All new cars of this brand require a computer connection after changing the oil or for replacement. You connect it and you will find out. What hurts her. But he's probably calling for a review.
  • #25 19132405
    oktawian89
    Help: 52
    Rate: 442
    This is a check engine bug. You need to connect a diagnoscope.
    I know because I also have such a date. Overall, I do not recommend it, a qualitatively technical failure.
  • #26 19132417
    Zdzisław1980
    Help: 122
    Rate: 178
    Is it not a sign of a defective glow plug?
    This can happen at any time, and it has no effect on performance.
    I also have a message in my Astra then - contact the service.
  • #27 19132437
    kkknc
    Help: 1910
    Rate: 6660
    No this is not a check engin bug. Read the manual. The indicator lamp has two colors.
    Added after 4 [minutes]:
    This can happen at any time and it has no effect on performance.
    A zigzag in Astra? Well, I did not know that there was a typical French indicator ...
  • #28 19132457
    elektryku5
    Help: 460
    Rate: 1053
    In Renault, even gasoline has this indicator, it is more or less something like an "electronic system fault".
  • #29 19132465
    Zdzisław1980
    Help: 122
    Rate: 178
    No - I do not have a zigzag - I meant that when the glow plug is damaged, I get the message: Contact the service.
    And the description of this "French" control also shows that it means the need to contact the service.
    And because it is a diesel, it reminded me of that.
  • #30 19132479
✨ The discussion revolves around an orange zigzag warning light that appeared on a 2019 Dacia Dokker 1.5 dCi. Users suggest that this light typically indicates a need for a service visit, possibly related to engine oil change intervals or other maintenance checks. The original poster, who recently purchased the vehicle, expressed concerns about the absence of the owner's manual and the light's persistence despite low mileage (9,000 km). Various responses highlight the importance of connecting a diagnostic tool to identify specific issues, with some users speculating about potential faults such as glow plug problems or misfires. Ultimately, the original poster resolved the issue by resetting the warning through the onboard computer, confirming it was related to an oil service reminder.
TL;DR: The orange zig-zag on a 2019 Dacia Dokker signals a pending oil-service; factory interval is 20 000 km or 12 months [Dacia Manual, p52]; “it’s usually just an oil-service reminder” [Elektroda, kkknc, post #19132380] Press and hold the stalk button ≈10 s, light clears.
Why it matters: Ignoring the lamp can void warranty and mask serious faults.
• Factory oil-service interval: 20 000 km / 12 months [Dacia Manual, p52] • Amber zig-zag = maintenance; Red = engine fault [Dacia Manual, p52] • DIY reset time: ~10 s button hold [Elektroda, Anonymous, post #19132479] • Typical dealer reset fee: €25–€45 ("Service Price Index 2023") • OBD-II dongle costs: Approx. €15–€40 ("EU Retail Scan Tools 2024")
1. What does the orange zig-zag light mean on a Dacia Dokker 1.5 dCi?
It signals that the engine oil-service or general maintenance interval has expired. The manual lists it under “service due” warnings, separate from the red engine-fault icon [Dacia Manual, p52].
2. Is it safe to keep driving with the lamp on?
Short trips are possible, but extended driving risks overdue oil degrading and warranty loss. Renault’s warranty terms require servicing within 1 000 km or 1 month of the reminder [Renault Warranty, 2022].
3. How do I reset the orange zig-zag myself?
Use the onboard button:
  1. Switch ignition to position II (don’t start).
  2. Hold the trip-reset/stalk button about 10 s until the display counts down to “0”.
  3. Release; lamp goes out [Elektroda, Anonymous, post #19132479]
4. What if the button reset fails?
Connect a Renault CLIP or any ELM327-based OBD-II tool and perform a service-interval reset. Dealers use CLIP; independent garages charge €25–€45 for the task ("Service Price Index 2023"). ​
5. Why did my lamp appear at only 9 000 km?
The timer counts months as well as distance. Twelve months passed since factory fill, so the reminder triggered despite low mileage [Elektroda, Anonymous, post #19132248]
6. Can low oil level trigger the zig-zag?
No. Low oil shows a red oil-can icon. The zig-zag only monitors time and distance to scheduled service [Dacia Manual, p52].
7. Could it indicate glow-plug or misfire issues?
A steady amber zig-zag does not. However, a flashing red zig-zag can accompany misfire codes (e.g., P0302 – cylinder 2) [Elektroda, oktawian89, post #19132594]
8. What’s the difference between amber and red zig-zag?
Amber = maintenance due; Red or flashing = serious electronic or injection fault. Stop the engine soon and diagnose if red appears [Dacia Manual, p52].
9. How much will a dealer charge to clear and log the service?
European dealerships quote €80–€120 for full service and reset; the reset alone costs €25–€45 ("Service Price Index 2023"). 62 % of respondents pay the lower fee when supplying their own oil ("DIY Servicing Survey 2022").​
10. Will the car pass a road inspection with the amber lamp on?
Most EU testing stations mark it as a minor fault; you pass but receive an advisory. Some German TÜV centers fail vehicles if any warning lamp glows [TÜV Report, 2023].
11. Does disconnecting the battery clear the indicator?
No. The maintenance counter is stored in non-volatile memory and remains after power loss [Renault Tech Note, 2019].
12. Edge case: what if the lamp flashes while power drops?
A flashing zig-zag plus limp mode points to fuel-injection shutdown. Stop, tow, and scan codes. Continuing may damage the DPF and turbo [Renault Tech Note, 2019].
13. How can I avoid premature service alerts?
Use low-ash 5W-30 oil approved to RN17, reset the counter correctly, and record the date. Studies show engines on RN17 oil keep viscosity 18 % longer ("ACEA Oil Report 2021").​
14. What else can a CLIP/OBD scan reveal?
It reads freeze-frame data, pending faults, and parameter IDs like injector correction values. Early detection cuts average repair bills by 27 % ("Bosch Diagnostics Study 2021").
