Calculating Current and Energy Cost for a 100W Linear Light Bulb Per Hour
mobo 223332 9
How do I calculate the current draw, energy use per hour, and cost of running a 100 W light bulb?
A 100 W bulb on a 220 V supply draws about 0.46 A if you treat it as an ideal linear load with cos(phi)=1, and in one hour it uses 0.1 kWh of energy [#1904712] To find the current, use I = P / (U * cos(phi)); for a 100 W bulb that is 100 / 220 = 0.46 A [#1904712] To find energy use, convert watts to kilowatts and multiply by time: 100 W = 0.1 kW, so 1 hour of operation consumes 0.1 kWh [#1904712] The cost is simply your electricity price multiplied by the kWh used; for example, at PLN 0.40 per kWh, one hour costs PLN 0.04 [#1904712] For multiple devices, add their wattages first, then multiply by the operating hours to get total kWh [#1904710]
  • #1 1904688
    mobo
    Help: 8
    Rate: 34
    How to calculate the current consumption by a linear light bulb type receiver? For example, a 100 W light bulb will eat electricity per hour? Because then, if I know how much a kilowatt hour is, I can convert it into money. And how much does such an hour cost? :D
  • #2 1904710
    danthe
    Level 30  
    Help: 125
    Rate: 294
    Hello !!
    Add the power of all devices - for example: 1 light bulb 100W, 2 bulbs 60W each, 800W heater - the power equals 1020W, i.e. 1.02 KW. Multiply by the number of operating hours and it will come out the power consumed in KWh. In the given example - 24.48 KWh / day
    Good luck - DANThE
  • #3 1904712
    august_
    Help: 70
    Rate: 47
    Hmm .. is the bulb really a linear receiver?
    I don't really understand your question, but I'll try to answer :)
    If the bulb is 100W, we assume that it is a linear receiver and that it is 220V. It's from the formula for power
    P = U * I * cos (phi)
    we get:
    I = P / (U * cos (phi))
    If the linear receiver is cos (phi) = 1
    so I = 100/220 = 0.46 A.
    Such a current flows through our idealized light bulb.
    So such a bulb will "eat" for 0.46Ah :)
    But it seems to me that you meant kilowatt hours from the beginning
    Therefore:
    The bulb is 100W or 0.1 kW
    If it works for an hour - it will consume 0.1 kWh of energy.
    And if 1 kWh costs PLN 0.40, an hour of bulb operation costs PLN 0.04 (not including depreciation).
    The question is, where do these bills come from?
    Well, the transmission fee is fixed, variable, subscription, delivery ... and 100 other things ...
    I hope I helped
    best regards
    Michael
  • #4 1904760
    mobo
    Help: 8
    Rate: 34
    Well guys, that's what it was all about. And looking at it, electricity is cheap and why do we pay such bills? Is what you replaced is added to the energy we used and that gives the final fee?
  • #5 1904977
    august_
    Help: 70
    Rate: 47
    Unfortunately yes. The most expensive of all these are transmission fees, etc. The worst situation is in the villages, because transmission fees are much higher.
    Energy companies do not mind that farmers have to bypass their poles in the fields ... but nothing will be done about it, because our grandparents signed a consent to such a practice (because everyone wanted to have electricity at all costs).
    But the worst thing is that there are no alternatives ... well, apart from own wind farms, solar plants etc ...
  • #6 1906330
    Gniew_Amo
    Help: 12
    Rate: 14
    only for such "electricity generators" (solar wind), when I find out, a power plant that you have something like that will come and pledge these meters, as in the 90s one engineer built himself a windmill and the power plant built a meter for him, isn't that funny ??
  • #7 1906462
    Kajtek_170
    Help: 26
    Rate: 32
    Hyba doesn't. You only need to obtain permission from the office for such a thing, but you cannot count on your draft
  • #8 1907096
    danthe
    Level 30  
    Help: 125
    Rate: 294
    Hello !!
    How can they !!
    If someone builds a power plant, e.g. a hydroelectric plant, he must first "sell" electricity to the energy region, and then "buy" it at a much higher price (because it is sold cheaper and pays tax on it !!!)
    together with transmission charges etc ... etc ... Only electricity for use by the power plant may not be metered by meters.
    Regards - DANThE
  • #9 1907773
    tomaszo
    Help: 139
    Rate: 100
    In Germany, it is so that having solar cells - let's assume that we have a 2kW converter on a sunny day - we have a meter as a converter ... So we are a small power plant - such cells return after about 15 years of use. Indeed, they buy from us cheaper than they sell to us ... Here, however, they put a lot of emphasis on the environment - hence, some reliefs are possible due to the installation of such a contraption on the roof.
    As for the windmill ... If it were to bring a significant profit, it would have to be really big - the issue of permits etc ...
    Nowadays you can't normally put what you want on your piece of floor ... Eh ...
  • #10 1914288
    Pocieszny
    Help: 229
    Rate: 263
    What a stupid thing to take money for the fact that someone will generate electricity for himself ... Just tribute nothing else. I thought that you pay the power plant only for the electricity it produces and sells to us ... It's like paying a supermarket for vegetables grown on your own backyard garden !!!
To calculate the current consumption of a light bulb, one can use the formula I = P / (U * cos(φ)), where P is the power in watts, U is the voltage, and cos(φ) is the power factor. For a 100W bulb at 220V, assuming a power factor of 1, the current is approximately 0.46A. The energy consumed in kilowatt-hours (kWh) can be calculated by converting watts to kilowatts (0.1 kW for a 100W bulb) and multiplying by the number of hours of operation. For example, if the bulb operates for one hour, it consumes 0.1 kWh. If the cost of electricity is PLN 0.40 per kWh, the cost of running the bulb for one hour would be PLN 0.04. Discussions also highlight the impact of transmission fees on electricity bills, particularly in rural areas, and the challenges of generating personal electricity through solar or wind energy systems.
