The intensity of the current consumed by the receiver
xamrex 271702 4
  • #1 4276572
    xamrex
    Help: 82
    Rate: 341
    Elo
    I am a beginner so please don't be surprised by my question.
    1000 watt how many ampere?
    is it possible to convert volts to amps or not?
    Błażej
    Help: 1923
    Rate: 3627
    Oh man! Basic formula:
    P = U * I, where
    P - power
    U - voltage
    I - intensity
    and you count!
    At a certain power, the current flowing in the circuit depends on the applied voltage.
    The higher the voltage, the lower the current. Anyway, count yourself! And for books!
    maras2003
    Help: 63
    Rate: 115
    You need to know two values. To calculate the Intensity (how many amps), you divide the power (1000W) by the voltage (e.g. 230V) the result will be the current (amps ...)
  • #4 16522509
    fafikdog
    Rate: 61
    The calculation is simple.
    I have another question: a 60W bulb at 230V is about 0.26A.
    What to do, after connecting the bulb after the above-mentioned voltage ammeter showed more? E.g. 2A.
  • #5 16522515
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    Connect more light bulbs or one with more power.
