Calculate Power Consumption (W) for Processor, Hob, Disk & Home Appliances: Voltage & Amps
dezkom 142370 10
How can I calculate the power consumption of a processor or home appliance from voltage and current without using the manual?
You can calculate power as P = U × I for DC circuits or for AC resistive loads, and for AC loads with motors or other non-resistive behavior you need P = U × I × cos(φ) [#4451438][#4451426] For a processor, disk, or similar computer parts, power changes with load, so a simple voltage-and-amps calculation is not very practical and the manufacturer usually specifies the power [#4451426][#4451438] For a whole computer, measuring the current on the mains is not enough by itself because switching power supplies have a power factor and a non-sinusoidal current waveform; an electricity meter/power meter is the better way to measure actual consumption [#4451516][#4451438] PSU calculators can give only rough estimates of the required power supply size and may overestimate actual power drawn from the grid [#4451504][#4451516] An energy meter will measure consumption accurately, and you can use it to calculate cost if it is programmed correctly [#4455172]
  • #1 4451400
    dezkom
    How to calculate how many watts are consumed, for example, by a processor, hob, disk and other components and also other home appliances without looking at the technical data in the manual.
    Eg 1.8V processor? You also need amps to calculate it or not? Is there any way.
    Thanks in advance
  • #2 4451426
    adams987
    Help: 288
    Rate: 138
    In such a simple way, it is possible to calculate the power consumption of a light bulb or a heater, because the consumption practically does not change with time and equals voltage X intensity. You probably know well that the processor or disk does not always work with 100% load. The power of such elements is given by the manufacturer.
    For alternating current, we also have cos?, it is the power factor and depends on the nature of the load, then power = U * I * cos?, and such a load with variable cos? is e.g. an electric motor,
  • #3 4451435
    dezkom
    And assuming that it will work with full load, then the formula: W = V * A
  • #4 4451438
    kortyleski
    Help: 957
    Rate: 3860
    P = U * I
    I = U / R
    Where:
    I - current in amperes
    U - voltage in volts
    P- power in watts
    These formulas are valid for direct current and for alternating current with resistive load.
    The computer processor draws current depending on the load of programs, you should measure the average value of the current - rather unfeasible in amateur conditions.
    It is easier to estimate the current consumption of the entire computer by measuring the current consumed on the mains (carefully - risk of electric shock) and using the formula:
    P = U * I * cos (phi), unfortunately I do not know what is the phase shift angle in the computer power supply ...
  • #5 4451470
    dezkom
    And this cos (phi) is a constant value. If so, how much is it. Where should I get it.
  • #6 4451490
    adams987
    Help: 288
    Rate: 138
    It is provided by the manufacturer, but it is not always constant, it depends on which device. For example, in a transformer it changes depending on what is connected to it as a load, whether it is resistance or capacitive or inductive reactance.
    Or, for the motor, the manufacturer specifies cos ? = 0.75 but this is at rated power, as if the idle run without load is cos?
  • #8 4451516
    forestx
    Rest in Peace
    Help: 299
    Rate: 496
    In the case of switching power supplies, a parameter is used called the power factor (it is not equal to cos? ;) .
    This is because the current waveform is non-sinusoidal.
    Measurement of the current consumed by the computer will not help us do anything (even made with an ammeter with TrueRMS), because we do not know the power factor.
    I use an electricity meter to measure the power of computers.
    Give the full list of components: processor, graphics card, drives, disks - I will approximate the power consumed for you.
    Added after 4 [minutes]:
    Calculators on the manufacturers' websites calculate the minimum power of the power supply (and they usually overestimate this power). It has little to do with the power drawn from the grid. For example, my set consumes about 100W (140W "under stress") and according to the calculator above, it comes out over 200W.
  • #9 4454211
    dezkom
    Is such a device http://allegro.pl " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://allegro.pl will have accurate measurements and is it worth buying something like this? Will it accurately enumerate the consumed power?
    Write more carefully! No errors, using Alt etc. - regulations p. 15.
    Before posting, use the "Spelling" button [Mirek Z.]
  • #10 4455172
    waldekg
    Help: 69
    Rate: 169
    Hello. The energy meter will measure everything accurately, but you need to read the manual to correctly interpret its indications. To calculate the costs of electricity consumed, the meter must be programmed. When buying, you need to check that the instruction manual is in Polish. Best regards.
  • #11 4455201
    sony1
    There are certainly several measures, which one should you choose? The moderator has already learned. It is okay.
    :) Spaces! This time I corrected. [Mirek Z.]
To calculate the power consumption (in watts) of various electronic components and home appliances, the fundamental formula is P = V * I, where P is power, V is voltage, and I is current. For processors and disks, which do not operate at full load continuously, it is recommended to measure the average current draw under typical usage conditions. The power factor (cos φ) is also a critical factor for alternating current calculations, particularly for devices with variable loads like motors. Manufacturers often provide the power factor, but it can vary based on the load type. For accurate measurements, using an electricity meter is suggested, as it can account for the power factor and provide real-time consumption data. Online power calculators can also help estimate power requirements, but they may overestimate actual consumption. When purchasing measuring devices, ensure the manual is available in the preferred language for accurate interpretation of results.
