[Solved] Uploading OpenPLI and Oscam to the Zgemma H9 Twin receiver - step by step instructions
Galus71 33435 5
  • #1 19514150
    Galus71
    Rate: 9
    How to upload software to H9 Twin? For H9S pendrive with the receiver turned off, reset and turn on. Unfortunately it doesn't work here. I have Open Atv but I can't load Oscam and I won't access CCCam, so I wanted to load OpenPLI, but I couldn't find the option. Thank you for the info.
    Manual OSCam installation via FTP and tmp folder
    #2 19514393
    Przem188
    EDA specialist
    Help: 157
    Rate: 156
    You can't upload OSCAM because the developers of Open ATV were forced by the authorities to remove it from their software in order not to facilitate sharning. Their system became so popular on set-top boxes that the German authorities ordered them to remove Oscams from the repo.
    But you can upload it. Just download OSCAMA as an installation file, add oscams to the visible repositories in the plugin installation menu (under the MENU button) and install the add-ons and that's it.
    There are guides on how to do this. You upload the plugin file via FTP to the tmp folder on the decoder, and then manually install it in the decoder menu. After this operation, the oscam repo will be added to those already there.
  • #3 19514454
    Galus71
    Rate: 9
    Thanks so much for the tip. Do you have a link to the Oscars? I'm looking, but I haven't found it. Thank you very much.
    Install arm softcam-feed-universal via local package
    #4 19515539
    Przem188
    EDA specialist
    Help: 157
    Rate: 156
    Here's an explanation of what and how, and to download it, you need to register.
    https://www.linuxsat-support.com/thread/122481-openatv-softcam-feed/
    Generally, you need to install softcam-feed-universal in the arm version (This camera has an ARM processor, like in smartphones, other, smaller models have MIPS processors).
    You download the softcam-feed-uniwersal file and put it via FTP into the tmp directory (or anywhere, it can be on a pendrive that you plug into the decoder, but you will have to look for the path).
    Then Menu-Settings-Software management-Install local package.
  • #5 19516200
    Galus71
    Rate: 9
  • #6 19517934
    Galus71
    Rate: 9
    Thank you for your help.
