[Solved] Web services for recording sensor data ppm10, ppm25
726 5
  • #1 19257826
  • #2 19257889
    stomat
    Help: 257
    Rate: 1982
    For what purpose do you want to save them? I presume it's not the saving itself for later reading, but the service presenting this data in some way right?
  • #3 19257900
    tos18
    Help: 1114
    Rate: 1872
    Erbit wrote:
    Do you know of any web service where I can record ppm10, ppm25 sensor data ?
    Build your own - not a lot of work
  • Local charts are enough for single-user use
    #4 19257959
  • #5 19260562
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Airly - but it's probably necessary to take sensors from them?
  • #6 19260577
