Weather station with monthly recording of readings - what to buy
DakotaPL 1203 2
  • Seeking weather station with monthly logging and online access
    #1 20830787
    DakotaPL
    I need to find a weather station with monthly logging of readings and preferably online access.
    Detailedly it is about the measurement of temperature and wind strength
    It is important that there is the possibility of checking the historical readings, they do not have to be older than a week
    It would be nice if it was online, but it does not have to be, can only be after connecting a computer via USB, WiFi, LAN. Also on the phone will be OK, but so that you can somehow save the readings
    I'm looking for something available in Poland
    Greetings
    Przemek
  • WiFi weather stations can feed home automation
    #2 20830936
    Mobali
    Help: 1355
    Rate: 3923
    Virtually any weather station with WiFi should meet your needs. Once you have downloaded a package of measurement data from the station, virtually everything else is up to you and how you want to process and archive it. For example, the readily available Bresser weatherman or Froggit WH3000 make data available via WiFi, which you can archive, use in a weather app or data sheet. Those indicated, in addition to the functions you require, also have a hygrometer, and a clock with alarm/alarm functions, among others.
    You can also successfully use the components of a weather station with data transmitted via WiFi to control home automation, for example to close windows or shutters (when cold) or automatically close roof windows (when it rains). For example, the popular TUYA Smart/Smart Life also supports weather data. In this case, the purchase of a separate weather station will actually be unnecessary, as it will be sufficient to purchase only a selection of measurement sensors (thermometer, hygrometer, wind meter or barometer) that transmit the data to TUYA (or a similar application). The role of "weather station" in this case will be played by a smartphone or computer. You will be able to access the data anytime and anywhere, even when you are away from home.
  • #3 20830945
    DakotaPL
    Thank you for your reply. I will look into these models
    In my case nothing will be controlled. It is only about temperature and wind strength. We need to have weekly reports on these two parameters for documentation
