Need Firmware for JVC LT48C570 (Currys/PC World Exclusive Model) - T.MS3463S.711 Chassis
Pentode 1788 4
  • Suspected firmware corruption in JVC LT48C570
    #1 19455156
    Pentode
    Model: JVC LT48C570
    Chassis (main board, components): T.MS3463S.711
    LCD Screen/Panel (if exist): LSC480 HN08-8
    This is a Badged JVC for Currys and PC World, model not listed on JVC site.
    Dead set with LED lighting, all voltages are correct and 'hash free' including the voltage converter on the main board. I suspect firmware corruption.
    One peculiar thing seems to happen, sometimes the LED will flash just once after one minute producing a click from the speakers. The LED backlights are OK as tested on a LED tester.
    Does anyone know where to get the firmware, Curry's are no help and JVC don't want to know since they don't list the model.
    Thanks, Dave
  • #2 19456055
    billobirillo
    Help: 338
    Rate: 798
    is there a spiflash in UF1 position? or not?
  • #3 19456117
    Pentode
    No it's blank, thanks for your reply. Dave
  • #4 19457116
    jeloi
    Help: 285
    Rate: 597
    Post the defective dump.
  • Board markings and software version identified
    #5 19459036
    Pentode
    I can't access the dump at the moment, I ought to get a dump reader, a necessity these days.
    UF1 Spi chip position is empty and uses a big nand chip underneath..... underside the main boarded is marked-:
    PO No: 2010028801
    P/N: 515Y35634M01
    Des: T.MS3463S.711
    SW: 20170810_220838.... would this be the software version?
    I posted this info in case it threw any light?
    Dave
