Man TGS Truck: Outside Temperature Sensor Location & Code 5556 - Solving Heat Problem
Abdulla51 11421 2
  • #1 19539377
    Abdulla51
    I have a Man TGS truck that has a heat problem, I checked it with an OBD device and it gave me this malfunction "outside temperature sensor" with the code 5556.
    I want to know the location of this sensor
  • #2 19540000
    darfur5
    Help: 267
    Rate: 1715
    The sensor is under the hood on the front right side of the cab.
  • #3 19541185
    kakibara
    Help: 202
    Rate: 1284
    Abdullah what temperature?
    The external one that displays on the dashboard or the one to control the air conditioning? Because this sensor is located in the inlet to the cabin filter ?
