MAN TGS: Replaced Heating Valve, Ad Blue Not Charging, Active GDK/PDF 05009-01 Issue
piter523 8181 6
  • #1 13333869
    piter523
    Hello. the heating valve replaced with a new one and still does not charge ad blue. GDK / PDF 05009-01 active.
  • #2 13334362
    serwis_gh
    Diesel injection systems specialist
    Help: 211
    Rate: 1238
    My favorite fault.
    The patency of the wires to be checked, filters, etc. AdBlue pressure test, draining, and ZME, most likely no overflow.
  • #3 13334666
    piter523
    Thank you for your response.
  • #4 17783384
    wit-trans
    Rate: 68
    Hello, How do I unblock this transfer? Is it a pipe from the pump to the tank or another? I am asking you to expand this topic because I'm getting this error, I do not get the adblu, and the heating valve is ok.
  • #5 17803375
    Fast_international
    Help: 6
    Rate: 87
    wit-trans wrote:
    Hello, How do I
    wit-trans wrote:
    this transfer? Is it a pipe from the pump to the tank or another? I'm asking you to expand the topic because I'm getting this error, I do not get the adblu, and the heating valve is about
    All the best, including the one from the tank to the pump. Blow clean, clean and inject.
  • #6 21020260
    Fryc64
    Rate: 11
    Hello, I have the same error 05009-01 and my hands are already falling, the pipes are blowing, everything is clear and the error still appears, what else could be the cause???
  • Frozen AdBlue lines and heater circuit faults suspected
    #7 21021679
    ROKADI
    Help: 43
    Rate: 194
    SPN 5009 External hose heating
    Monitoring strategy
    Check for frozen AdBlue lines between the tank and the delivery module
    Client perception/symptom description
    • Yellow warning light
    • Yellow indicator light
    • Buzzer
    Failure Mode Identification (FMI)
    FMI 1 Too high
    Indication on the display
    Priority 5 Text
    indications
    OBD
    OBD /
    P-Code
    P20C2 MIL P204B - Reductant Pressure Sensor Circuit Range/Performance
    P20BA - Reductant Heater "A" Control Circuit Performance
    P20BE - Reductant Heater "B" Control Circuit Performance
    P20C2 - Reductant Heater "C" Control Circuit Performance
    Symptoms
    Systemic reaction/possible effects
    The system will turn off until the next system startup (terminal 15 on)
    React
    ROKADI - MAN
    Kętrzyńskiego 8, Olsztyn, 10-506 | Tel.: 660-XXX-XXX (Show)
The discussion revolves around issues with a MAN TGS vehicle where the heating valve was replaced, but the AdBlue system is still not functioning, indicated by the active GDK/PDF 05009-01 error. Participants suggest checking the wiring, filters, and performing an AdBlue pressure test. They also recommend inspecting the transfer pipes from the pump to the tank for blockages and ensuring that the AdBlue lines are not frozen. Additional error codes related to the reductant pressure sensor and heater circuits are mentioned, indicating potential systemic failures that may require further diagnostics.
