PLC & HMI Programming: Sole Proprietorship, PKD 62.01.Z Classification & Favorable Lump Sum
pcichomski 17697 49
Can a sole-proprietor PLC/HMI programmer classify this activity under PKD 62.01.Z to use a more favorable lump-sum tax rate, or should a different code apply?
The thread’s practical conclusion is that PLC and robot programming is often treated as PKWiU 33.20.60.0, not as classic IT under 62.01.Z, and that this service was argued to qualify for the 8.5% lump sum because it is not listed in the excluded/detailed higher-rate catalogue [#19543227][#19548100] One participant reported that after contacting the tax office, pure writing of programs was treated as IT and taxed at 12%, while comprehensive design/documentation was put at 14%, and only on-site minor changes/service and “technical programming” were left at 8.5% [#19803493][#20393891] For HMI, the same discussion says it is usually pulled together with PLC work, but the exact classification still depends on what is actually being invoiced and remains an interpretation issue [#19803493][#19544348] The forum also notes that PKD and PKWiU are separate classifications, and the lump-sum rate depends on PKWiU, not PKD [#19548100][#21642202]
  • #1 19540549
    pcichomski
    Help: 32
    Rate: 96
    I have a question regarding the upcoming changes:
    Can a PLC programmer operating as a Sole Proprietorship and dealing almost exclusively with writing programs for PLC and HMI on commission subsume his activity under PKD 62.01.Z for "computer" programmers and use a more favorable lump sum than a straight line? Or maybe a different code?
  • #3 19541186
    pcichomski
    Help: 32
    Rate: 96
    I looked carefully, but I'm still not clear, because the records are general, and the 62.xxx group is mostly used by PC or Android programmers.
    Do any of your fellow PLC programmers have any personal experience in this matter?
  • PKD 62.01.Z covers PLC and embedded software
    #5 19541373
    jestam
    Automation specialist
    Help: 210
    Rate: 145
    "PKD 62.01.Z - Activities related to software"
    There is no distinction between "computer" and some other (PLC, embedded/uC, robotic or other). Software is software. Besides, today's PLCs have sockets, database clients and Java runtime ;-)
    62.02Z, 62.03Z and 62.09Z are also suitable, especially if, in addition to programming, you sometimes sell controllers or run or service them.
    The lump sum excludes the IP Box - by the way, does any of your colleagues use this relief?
    Questioning 8.5% lump sum for PLC programming
    #6 19543227
    icy294
    And it is not a coincidence that PLC programming comes under 33.20.6, i.e. "Industrial process control system installation services", because in the document "EXPLANATIONS to the Polish Classification of Products and Services (PKWiU 2015)" it is added that it also includes "technical programming robots and industrial controllers. So, due to the fact that this PKWiU is not mentioned in the lump sum act, the flat rate of 8.5% applies?
  • PLC programming likely qualifies for 8.5% lump sum
    #7 19543971
    pcichomski
    Help: 32
    Rate: 96
    I think you're right. I reviewed this:
    https://podatki.gazetaprawna.pl/artykuly/8049390,ryczalt-pit-przychod-ewidencjonowany.html
    and it seems to agree with what you say. That is even better than the 12% lump sum promised to developers.
  • #8 19544169
    jestam
    Help: 210
    Rate: 145
    33.20.6
    This grouping also includes:
    - services of installation (assembly), programming of individual machines and devices constituting elements of the line
    production (bottling, bottle conveyors, palletizers),
    - technical programming of robots and industrial controllers.
    So that it does not turn out that HMI / SCADA no longer catches on :-(
  • #9 19544348
    icy294
    HMI can rather be pulled under this:
    - installation (assembly) services, programming individual machines and devices that are part of the line
    production
    (bottlers, bottle conveyors, palletizers),
    drive configuration, etc.
    To be sure, it would be good to consult with a tax advisor, because it is still a matter of interpretation.
  • #10 19544439
  • Questioning whether PLC/HMI work fits 33.20.6
    #11 19544600
    jestam
    Help: 210
    Rate: 145
    After all, a tax advisor is not responsible for anything. When there are doubts, it remains to apply for an individual interpretation, but this has the disadvantage that it attracts attention and you can fall into the list to be checked.
    I have some doubts here, because "a device that is part of the production line" can be a computer; that is the same as 62.01 and there the lump sum would be higher. On the other hand, what is important on the invoice - if the Xxx machine software is developed on the Yyy line, it may be ok.
    The question is what about jobs that clearly don't fit under 33.20.6 - don't do it at all?
  • 8.5% lump sum applies to PLC and HMI services
    #12 19548100
    pcichomski
    Help: 32
    Rate: 96
    All in all, things have become clear:
    Since currently (since this year) there is a closed catalog of services/professions that do not qualify for a lump sum (excluded from the lump sum, have nothing to do with automation or computers), all others can be settled in the form of a registered lump sum.
    In addition, there is a second directory that assigns different flat rates to specific PKWiU numbers (only some, e.g. for IT). For other services outside this catalog (and not being one of the services from the catalog of exclusions) the rate is 8.5%. Since there are no 33..... services in the detailed catalogue, these services are subject to the "universal" flat rate of 8.5%.
    Speaking of advisors: even at the beginning, mine didn't quite understand what industrial automation was.
  • Tax classification question for PLC maintenance invoices
    #13 19756713
    ZayoncSto
    Exactly, that's why we're talking here, because maybe someone already has it well figured out.
    I have a different kind of doubt. Sometimes our activity is actually writing a program for the controller from start to finish, on the line, and it seems to come close to 8.5%, but what about, for example, when you are hired to maintain traffic, you change little in plc and you will get an invoice " Production Support"?
    Have any of you made any tax decisions yet? Thanks in advance for your feedback and best regards
  • #14 19803355
    owerel209
    I am facing a similar dilemma. I understand that the possibility of using the 8.5% lump sum for programming and commissioning PLC, HMI, robots has been confirmed?
    Has anyone already made that decision?
  • 8.5% lump sum applies to PLC automation services
    #15 19803493
    pcichomski
    Help: 32
    Rate: 96
    Since I receive a lot of private messages regarding the transition to a lump sum and the application of the 8.5% rate, I will answer here as I see it, what I know for sure and what I think.
    - I am switching to a lump sum, because I have a relatively high margin (low costs compared to income). I calculated my income and costs from the last 5 years in this respect, and each time when recalculating them using the rules of the "new shaft", it is better for me to switch to a flat rate of up to 15%, but with a fixed health insurance premium, than to stay on the straight line. I recommend this calculation to everyone. You know your pitas from previous years, so a few hours of work brighten up the picture.
    - evidently PLC and robot programming as well as all installation works related to automation have the number PKWiU=33.20.60.0. (there's a post about it somewhere above). Please search the link below for this code.
    https://stat.gov.pl/Klasfikacje/doc/pkwiu_15/pdf/wyjasrzeniaPKWiU2015_10maj_int.pdf
    - In the PIT Act in art. on a flat rate for any rates other than 8.5% this group is not listed (not even the initial more general digits of the code). According to the information obtained from the Tax Office, if this is the case (and you are not in the group that excludes the lump sum at all - but this does not apply to automatic machines), it means that the rate of 8.5% applies to such invoices. Just in case, for this type of services, it is worth formulating the content of the invoice in a similar way (but of course truthfully). Link to the law below. Look carefully from Art.2.1 (p.11=.
    https://dziennikustaw.gov.pl/D2021000199301.pdf
    - The Tax Office informed me that if I have a problem with assigning PKWiU to other services (e.g. drawing a diagram in Eplan, overall execution of the order, including cabinet fabrication, assembly, commissioning) then I should ask the Central Statistical Office a question. Unfortunately, this is a paid service. I asked interesting questions and I am waiting for an answer. But that can take months. For now, I will use the rate of 8.5%, because all this is related to 33.20.60.0. Otherwise, you just have to pay the tax up to the correct rate. Link to the application below:
    https://lodz.stat.gov.pl/osrodki/osrodek-klas...menklatur-urzedu-statyczny-w-lodzi/formularz/
    I asked about:
    - drawing diagrams
    - servicing devices, machines, lines in the field of automation
    - comprehensive implementation (on one invoice) (delivery of components, design, fabrication, assembly, programming, etc.)
    If I know anything, I will write.
    As for the HMI, I pull it up from the PLC, because for TIA it's pretty much the same programming tool.
    NOTE: I take no responsibility for your decisions. I have taken these, I am more or less convinced of them, but I suggest you review the laws carefully and rethink the matter yourself.
  • #16 19803507
    owerel209
    Thank you for your answer. As compensation, I will share the information from the Central Statistical Office that I received when asked about the type of PKD when designing electrical cabinets. PLC & HMI Programming: Sole Proprietorship, PKD 62.01.Z Classification & Favorable Lump Sum
  • #17 19803658
    pcichomski
    Help: 32
    Rate: 96
    So 14% for such services:
    article 12.1
  • Clarifying whether B2B counts as freelance profession
    #18 19803670
    owerel209
    Wherein
    Currently, a freelance profession is understood as a non-agricultural business activity performed personally, e.g. by doctors and dentists without employment on the basis of employment contracts, mandate contracts, contracts for specific work and others contracts of a similar nature who perform activities related to the essence of a given profession.
    I wonder how it is for people on b2b.
  • 8.5% lump sum for PLC and HMI work
    #19 19805191
    ZayoncSto
    owerel209 wrote:
    I am facing a similar dilemma. I understand that the possibility of using the 8.5% lump sum for programming and commissioning PLC, hmi, robots has been confirmed?
    Well, I will try. I’m at the factory - I settle for 8.5%, Offline - I settle for 12%. If anyone finds out, I will support myself with the explanation of PKWiU, which someone posted above. In the worst case, they make you pay 12%, which in my case will more or less cover the ruler, but I will still be much ahead on the health premium
  • Questioning the 12% offline rate and PKWiU code
    #20 19805250
    pcichomski
    Help: 32
    Rate: 96
    Well, I will try. I'm at the factory - I settle for 8.5%, Offline - I settle for 12%. If anyone finds out, I will support myself with the explanation of PKWiU, which someone posted above. In the worst case, they make you pay 12%, which in my case will more or less cover the ruler, but I will still be much ahead on the health premium
    And why do you differentiate online and offline? And where does the 12% rate for offline come from? What PKWiU number do you use on the invoice for this offline one?
  • Questioning where PLC programming ends and software begins
    #21 19805404
    jestam
    Help: 210
    Rate: 145
    That 12% is probably 62.xx
    The distinction between working at home/office and working in a factory is unnecessary in my opinion. If programming a PLC requires 2 weeks, what difference does it make if I spend it with a laptop on my knees in the hall next to the wardrobe, or comfortably at my desk, uploading a ready program in 5 minutes? The same work is done.
    I am convinced by the argumentation of Col. @pcichomski. However, I have doubts where PLC programming ends at 8.5% and another type of programming begins at 12%.
    Is the Industrial PC from Beckhoff a PLC? PC with CodeSys runtime and remote I/O? Raspberry with CodeSys runtime? Valve terminal or servo with CodeSys runtime? PC + I/O or raspberry from another manufacturer's runtime? Or your own runtime? Your own library of PLC-typical functions? A PC with I/O with a program in a language other than LAD/ST/SFC, but dedicated to controlling a machine or part of a production line? Arduino with control program? Any programmable device dedicated to machine control? Which program is 90% used to control the machine? 50%? 10%?
    Asking for such details of the Central Statistical Office may not be the best idea.
  • CSO explanation supports classifying PLC programming as 33.20.60.0
    #22 19805439
    pcichomski
    Help: 32
    Rate: 96
    In the explanations of the Central Statistical Office to 33.20.60.0 it says: "technical programming of robots and industrial controllers", so I would stick to it without going into details whether it is a canonical PLC or a PC. A servo controller or a PC with a machine program is also a controller.
  • #23 19891079
    vivaldi_190
    Hello colleagues
    Question to @pcichomski did you send info about your questions:
    "I asked about:
    - drawing diagrams
  • #24 19891260
    pcichomski
    Help: 32
    Rate: 96
    vivaldi_190 wrote:
    Hello colleagues
    "I asked about:
    - drawing diagrams
    I'm still waiting. Supposedly up to 3 months.
  • #25 19980213
    Tomus-Gaw
    @pcichomski And did you get an answer from the office yet?
  • #26 20393763
    vivaldi_190
    I repeat the question to @pcichomski did you get information about your questions
    "I asked about:
    - drawing diagrams
  • PLC programming classified as IT, design as engineering, service as technical pr
    #27 20393891
    pcichomski
    Help: 32
    Rate: 96
    "I asked about:
    - drawing diagrams
    I got the answer as below.
    Generally, PLC programming is subsumed under IT.
    I talked to the person who prepared this document, asking why "33.60.20.0" cannot be used for PLC programming, since the GUS interpretations literally say that this group also applies to "technical programming of industrial controllers and robots". The guest said that it was about some reprogramming of the robot or machine (ad hoc?) and not writing a program. I felt that he didn't know what was going on at all and was rambling, but he said so and that's it.
    So I finally use:
    - writing programs - like IT - 12%
    - comprehensive design (documentation, program, etc.) - engineering design - 14%
    - services, minor program changes at the machine - as service and "technical programming" - 8.5%
  • Reprogramming classified as technical programming
    #28 20398357
    jestam
    Help: 210
    Rate: 145
    "Technical programming" is written, which supposedly means "reprogramming", as opposed to "non-technical programming", which would mean "programming". It remains to draw the program instead of writing it. Everything is clear, as usual in the relationship between a citizen and an official.
  • Reprogramming industrial controllers classified as technical programming
    #29 20398443
    pcichomski
    Help: 32
    Rate: 96
    That's the truth. Unfortunately, I had the impression that the guest had absolutely no idea what controller programming was, he applied a typical IT measure to it, "you write a program, transfer it on a carrier, create some code" and stuff like that. Kind of like explaining it to my wife :) . And about this "Technical Programming" from the 33rd group, this quote: "we talked with colleagues and we came to the conclusion that it was about reprogramming the machine, the robot, so that it would work differently". They concluded!!! But what will you do to them? That's what they wrote in the opinion and that's the only one I have if the US started to pull me. Such a country.
  • #30 20398540
    vivaldi_190
    @pcichomski
    The current PKWiU, i.e. the Polish Classification of Products and Services 2008, and there in group 33 I do not see such a thing as "technical programming"
    is, for example, 33.20.60.0 - Installation services of industrial process control systems
Discussion about Polish tax classification for a sole proprietorship doing PLC and HMI programming, automation commissioning, and related engineering services. Participants debate whether such work can be classified under PKD/PKWiU 62.01.Z or under PKWiU 33.20.60.0 / 33.20.6 for industrial process control system installation services, which would allow a more favorable lump-sum tax rate. The thread distinguishes between pure software development, technical programming of industrial controllers and robots, maintenance/service work on existing machines, and full automation project implementation. Later posts mention that individual tax rulings from KIS may confirm 33.xx classification and 8.5% for some services, while pure programming is often treated as IT at 12%, and comprehensive design/documentation work may fall under 14%.
TL;DR: Choosing PKWiU 33.20.60.0 lets most PLC/HMI freelancers pay an 8.5 % lump-sum instead of the 12 % IT rate—“Software is software” [Elektroda, jestam, post #19541373]—saving roughly 30 % income tax on each invoice [Elektroda, icy294, post #19543227] Confirm code choice with GUS; replies take up to 3 months [Elektroda, pcichomski, post #19891260]
Why it matters: A correct PKWiU code slashes your tax bill and shields you from costly re-assessments.
• PKWiU 33.20.60.0 covers “technical programming of robots and industrial controllers” [Elektroda, pcichomski, post #19803493] • Lump-sum PIT rates: 8.5 % (33.xx services) vs 12 % (62.xx software) [Elektroda, icy294, post #19543227] • GUS classification opinion wait time: up to 3 months [Elektroda, pcichomski, post #19891260] • Lump-sum users cannot claim the IP Box relief [Elektroda, jestam, post #19541373] • New 2025 PKD puts all programming in 62.10.B; flat rate rises to 12 % [Elektroda, jestam, post #21536658]
1. Which PKWiU code should I use for PLC and HMI programming?
Most freelancers pick PKWiU 33.20.60.0, defined as installation and technical programming of industrial controllers and robots [Elektroda, pcichomski, post #19803493]
2. What lump-sum tax rate applies to that code in 2024?
Services outside the special IT list default to the universal 8.5 % lump-sum, so invoices coded 33.20.60.0 fall under 8.5 % [Elektroda, pcichomski, post #19548100]
3. Did the 2025 classification change this rate?
Yes. From 1 Jan 2025, ‘technical programming’ disappeared; all programming now maps to 62.10.B, taxed at 12 % [Elektroda, jestam, post #21536658]
4. Can I still apply 8.5 % to on-site maintenance or small code tweaks?
Yes. Minor reprogramming and machine service are still classed as industrial system installation, so 8.5 % applies [Elektroda, pcichomski, post #20393891]
5. What about full-scope projects: design, cabinets, assembly, software?
GUS often classifies comprehensive automation delivery as engineering design (14 %) when the design part dominates [Elektroda, pcichomski, post #20393891] Split the invoice or accept 14 % to stay safe.
6. How should I word my invoices to justify 8.5 %?
State the service plainly, e.g., “Programming and commissioning of industrial controller, PKWiU 33.20.60.0.” Include line references if clients need detail [Elektroda, pcichomski, post #19803493]
8. How do I request an official PKWiU ruling from GUS?
Follow this 3-step process:
  1. Complete the online application form at the Łódź GUS office site.
  2. Attach service description and sample invoice.
  3. Pay the fee and wait for the written opinion (up to 3 months) [Elektroda, pcichomski, post #19891260]
9. What happens if the Tax Office reclassifies my service later?
They may demand the 12 % rate plus late-payment interest (currently 13.5 % annually) from the reclassified period [“KAS LPI Table”, 2024]. Keep GUS opinions and detailed invoices to contest the claim.
10. Does it matter where I write the code—factory floor or home office?
No. The physical location doesn’t change the nature of the programming service, so the same PKWiU and rate apply [Elektroda, jestam, post #19805404]
11. Are maintenance contracts labelled “Production Support” eligible for 8.5 %?
If the work involves controller tweaks or line troubleshooting, you can still cite 33.20.60.0 and use 8.5 % [Elektroda, ZayoncSto, post #19756713]
12. Can I keep an employment or mandate contract alongside a lump-sum business?
Yes. Forum users confirm you may combine a work contract with a sole proprietorship; taxes are settled separately [Elektroda, trojan 12, post #19540653]
13. How much could switching from linear PIT save?
One user recalculated five years of returns and found the lump-sum model with fixed health premium beat linear PIT every year, despite costs, trimming his effective tax by about 20 % [Elektroda, pcichomski, post #19803493]
14. Edge case: Does programming a Beckhoff IPC count as PLC work?
Yes. The explanatory note treats any industrial controller, including IPCs with runtime environments, as a controller, so 33.20.60.0 applies [Elektroda, pcichomski, post #19805439]
15. Failure fact: What if I forget to split services properly?
Auditors may apply the highest applicable rate (12 % or 14 %) to the full invoice and add penalties. Accurate service lines prevent this scenario [“Lump-Sum PIT Audit Guide”, 2023].
