Where is the eeprom data BIN.eep for the latest fusebit doctor?
bradcan 1710 2
  • #1 19545601
    bradcan
    I configuring an update 11 version of the fusebit doctor. I propose to load the firmware into a atmega328p.
    I read in the 'READ!.txt' file that I must also program the eeprom file BIN.eep. However, there is no such file.
    Should I use one from a previous version, or have I missed something?
    Thanks in advance.
  • #2 19552045
    miszczo997
    Help: 134
    Rate: 159
    And this file was not needed only in some earlier version? When I was doing my job, I do not remember that I was uploading something to the eeprom and everything worked as it should.
  • #3 19553374
    bradcan
    miszczo997 said "And this file was not needed only in some earlier version? When I was doing my job, I do not remember that I was uploading something to the EEPROM and everything worked as it should."
    Are you saying that EEPROM data is no longer part of the firmware?
    The actual code would be useful.
    The Polish forum is a different web site !:-(
