Atmega Fusebit Doctor v2.11 Fails to Verify Fuse on Atmega8A—Signature Read OK
osprisso 648 0
  • Suspect HVPP write verification failure on Atmega8A
    #1 21643510
    osprisso
    AVR Fusebit Doctor Reads uC Signature but fails to verify Write/Reset Fuse.!!!
    I built Atmega Fusebit Doctor from last update Firmwire v2.11 Board V2h on PCB. Atmega8A as Doc Chip
    Whenever I put my bricked (Due to wrong external clock fuse setting) Atmega8A uC into fusebit doctor's socket the green led blinks for about 1 seconds and then red led flashes.
    I got the following info in the terminal from Doctor;s RS232 output. I tested with another brand new Atmega8A chip but the same thing happens. I checked the PCB board. No shorts or bugs found on any lines. Measured both 12V and 5V on patient uCs Reset and VCC pin which applies accordingly during operation and found all transistors OK. Don't know whats wrong?
    NB: I built Atmega Fusebit Doctor for the first time about 10 years ago but that time everything worked fine and I recovered couple of Atmega uCs but somehow I lost that PCB board with everything while migrating to another city and forgot exactly which firmware version I used.
    For the bricked Atmega8A uC I get following info
    Welcome
    AVR Atmega fusebit doctor (HVPP+HVSP) version 2.11
    http://diy.elektroda.eu/atmega-fusebit-doctor-hvpp
    Usage in commercial/profit purposes not allowed
    MANUAL HVPP MODE
    Init programming... DONE
    Read signature... 1E 93 07
    Searching chip... no names in 8kB ver
    Read fusebits... L:87 H:99 E:00
    Should be... L:E1 H:D9 E:00
    Lockbits... DISABLED (BF)
    What to do?...
    1 - write fusebits
    2 - modify fusebits
    3 - set lockbits
    4 - chip erase
    5 - end
    Writing E1 D9 00... DONE
    Verifying... L:04 H:04 E:00- FAIL!
    Please try again...
    For new Atmega8A got the following info:
    Welcome
    MANUAL HVPP MODE
    Read fusebits... L:A1 H:99 E:00
    What to do?...
    1 - write fusebits
    2 - modify fusebits
    3 - set lockbits
    4 - chip erase
    5 - end
    AI: Can you provide details about the exact components you used in your build (e.g., transistor types, oscillator/crystal, and whether you made any substitutions from the original BOM)?
    No change, No substitution from the original BOM
    AI: What kind of power supply are you using for the Fusebit Doctor (voltage, current rating, and whether it’s regulated or has any noticeable ripple)?
    Transformer based 12V 1A DC regulated power supply through L7812 IC. Also used 12V DC 1A Travel Adapter.
