Lenovo ThinkCentre M710q: Install Windows, Access BIOS & Reset Chromium Amazon Passwords (90)
ziele1993 17463 7
  • Need BIOS access to reinstall Windows
    #1 19777134
    ziele1993
    I have a Lenovo ThinkCentre M710q, Chromium system converted to Amazon is installed on my computer. Is there any possibility to install Windows on it? I can't go into the BIOS at all.
    The system is booting up but there are some accounts but I don't have passwords for them, what could I do?
  • Bypassing secure boot by transplanting the drive
    #2 19777148
  • #3 19777162
    ziele1993
    I connect this disk to a second USB computer, it shows something like this:
    And when I turn on that computer without the disk, it is something like this:
  • Use MiniTool Partition Wizard to check disk lock status
    #4 19777182
  • #5 19777264
    ziele1993
    I installed this program and it sees this drive like this:
    Should I format it and install Windows on it?
    I just tried to enter the BIOS or boot menu but none of the key combinations work
    Yes, I saw that generally this PC is on Windows, only here I have such a system installed
  • Wipe GPT disk with zeros before Windows install
    #6 19784039
  • #7 19976282
    jeffbezos
    Whether the operation was successful. I want to know because I have the same computer too
  • #8 20149312
    Alrightythen
    Does it work? please tell
    Added after 4 [minutes]:
    @jeffbezos is that working? Please tell
The discussion revolves around installing Windows on a Lenovo ThinkCentre M710q that currently runs a Chromium-based system. The user is unable to access the BIOS to disable secure boot, which complicates the installation process. Several solutions are proposed, including removing the hard drive and connecting it to another computer to format it and install Windows. Users suggest using the MiniTool Partition Wizard to manage partitions and wipe the drive if necessary. The conversation highlights the challenges of dealing with locked drives and the potential need for hardware modifications if the installation fails.
