Challenges Installing WIN7 on LENOVO Ideapad 110-15IBR: Experiences and Workarounds
hunter999 6249 5
  • #1 16383382
    hunter999
    Rate: 45
    Hello, I bought a LENOVO Ideapad 110-15IBR laptop and I can't install WIN7 on it, but WIN10 installs normally and is currently installed in the laptop, but I prefer WIN7 and I'd rather have it than 10.
    What I did: botable pendriv from windows 7 x64 using Rufus program all 3 options I tested: BMR for UEFI and BIOS, MBR for UEFI and the last GPT for UEFI file system I chose FAT32.
    I set Lagacy and UEFI on my laptop (including disabling Secure Boot or something like that)
    And either the laptop hangs on "Starting Windows" or the message crashes that there are no drivers and so I choose them from the disk (I have Win10 installed and on C I have USB drivers from the manufacturer's website) for windows 7 x64 the window shows files but during uploading it crashes message that no device was found, etc. My hands are falling down so do to install win7 on this paw?
    Tonight I will try to run win7 from the disc because there is a DVD drive in it.
  • #2 16383461
    piwot
    Try another copy of the system, maybe the iso with windows 7 is damaged.
  • #3 16384241
    hunter999
    Rate: 45
    I checked 3 versions, including the one installed on my PC.
  • #4 16384838
    RADU23
    Help: 2428
    Rate: 1732
    hunter999 wrote:
    I chose the FAT32 file system
    Why not NTFS?
  • #5 16384921
    rtj71
    IT specialist
    Help: 474
    Rate: 353
    RADU23 wrote well, the pendrive should be formatted to NTFS. Instead of rufus use Yumi, this message also appeared to me, the system version was to blame, only the version with added drivers works.
  • #6 16385337
    hunter999
    Rate: 45
    Good job settled, I managed to put the system through a DVD drive (in the sense I fired the win7 disc), thanks for your help.
