AOC CQ32G2SE Monitor EEPROM Memory Dump (715G9500-MOA-B07-0H5K, No Stand-by LED)
adrianursu1976 1770 1
  • Missing enable signal with normal board voltages
    #1 19995920
    adrianursu1976
    Mark: AOC
    Model: CQ32G2SE
    Chassis (main board, components): 715G9500-MOA-B07-0H5K
    LCD Screen/Panel (if exist):
    More information: does not start, stand-by LED is off, voltage checked on the board
    The stand-by LED doesn't turn on. I have checked voltages on the main board 3.3v, 1.2v, 1.8v, 5v. On inverter board, signal for ENABLE is missing.
    Code main board is 715G9500-MOA-B07-0H5K
    I need a dump for eeprom
  • #2 20792805
    mateuszwargacki
    Hello, did you handle the batch of eggs? I suspect that I also had an EEPROM leak. AOC Cu34g2x monitor: the monitor turns on, the matrix is illuminated, but the logo is not displayed, and after a few seconds it goes to sleep. Under thermal imaging, you can see that the processor is starting. I am running out of ideas, and I have a question: did you find the dunk somewhere???
