LG W2234S-BN Monitor Not Turning On: Power LED Off, Capacitor Voltages, PCB & Inverter Issues
.yankee 11034 12
Why does my LG W2234S-BN not turn on or light the power LED even though the PC detects it, and what should I check or replace?
The PSU appears to be working, so the fault is most likely on the logic board/firmware side rather than the inverter or main power supply. The fact that a PC detects the monitor only means the EDID EEPROM can communicate, not that the TSUMU18ER main processor is fully operating [#8330378] Check that the 1.8 V and 3.3 V LDO rails are present, and also verify the quartz oscillator on the logic board [#8330378][#8345432] The most likely culprit is the main flash memory: one reply estimated a flash fault with 90% probability, and the original poster later confirmed the monitor worked after replacing the MX25L1005 [#8330544][#9219944] A compatible replacement flash such as EN25F10 was reported to work [#9222066]
  • Detailed power-supply measurements with inactive inverter
    #1 8330020
    .yankee
    I have a beaten monitor, as in the subject. I looked through the forum and read all the topics devoted to similar symptoms, but I did not find a solution.
    After connecting the power supply, nothing appears on the monitor, the "power" LED is off. I suspect that this is not the fault of the PCB with logic, because when connected to a computer, it is correctly detected (ie it correctly gives the available modes of operation, the resolution can be changed). You can not hear the inverter "cycling".
    Obviously, I took the monitor off, and with the open instructions I took measurements as far as I could. Here is what I measured:
    - capacitor voltages:
    - C804: approx. 305-310V
    - C806: 130V
    - C805: approx. 3.3V
    - C828: around 100V
    - on C805 and C828, the meter indicates 30-37 V when measuring AC
    - C817-819, C501, C528 and C815: around 18.5V
    - C820, C822-824, C816: about 5V
    - C807 (the one with IC802): 14.3 V
    - On the logic connector (CN801) there is 5V on the power lines.
    - on IC802:
    1 (BNO): 3.55 volts
    2 (COMP): 1.4 V
    3 (LATCH): 6.25 volts
    4 (CS): 0 V
    (5 = GND)
    6 (OUT): 0 volts
    7 (Vcc): 14 V
    8 (OVP): around 1.3 V
    - on IC801 (is the photomultiplier called?):
    - between 1 and 2: 1.1 V
    - between 3 and 4: 1.4 V
    - on IC803:
    - AR: 2.5 V
    - AC: 3.6 V
    - mass-level anode at the logic connector (CN801)
    - MOSFETs:
    - D804: short 2 legs; the center is around 18 volts
    - D805: as above, relative to the center approx. 5V
    - U501: DG = DS = 18.4 V
    - U502: DG ~ = DS ~ = 18 V (there is a difference of around 0.5V)
    - On IC 501 I measured, following the procedures from the manual
    - foot 9: 18.5V (Apparently, it should be 16V, but I do not know if this is not about the state turned on - how the power LED lights up.)
    - foot 8: 0V (Also something supposedly should be - as above)
    In addition, the tiles look fine, the capacitors are not bulged, you can not see any signs of burnout. Unfortunately, now I do not have the possibility to upload photos, but if someone suggests that they would be useful, I will get a :) camera :)
    Thanks in advance for all the help.
    WojtasJD
    Help: 2920
    Rate: 1587
    IC801 - optocoupler
    Initially, you can say that the power supply is functional.
    You can take care of the TSUMU18ER board
    See if there are 1.8V and 3.3V voltages
    The fact that after connecting the monitor to the graphics card causes its 'detection' in your case means only communication with EEPROM from EDID
    lisek
    Service technician RTV
    Help: 6357
    Rate: 6888
    In this monitor
    W2234S-BN
    procekTSUM18ER-LF
    eprom 24?02
    fleah 25lv010 / MX25L1005
    invertor on: mp1008es / + field 9971gh 9575gh
    power supply: 7n60 + ld7522p scaler
    you have a flash problem with 90%
    Below you have sucked in from a good one
    • lgw2234s-bn.rar (51.11 KB) You must be logged in to download this attachment.
  • #4 8333904
    .yankee
    WojtasJD wrote:
    IC801 - optocoupler
    The fact that after connecting the monitor to the graphic card causes its 'detection' in your case means only communication with EEPROM from EDID
    Thanks for the information :)
    I fumbled in googlu and I did not find the datasheet of this TSUMU18ER unfortunately. In the manual of the monitor, in turn, the logic circuit diagram is so vague that I do not know where these voltages should be :(
    Any hint?
    @lisek:
    Thanks for the batch! Somehow it takes a lot, I understand that it's a question of how to make a dump (on the net I found reels much smaller - probably partial?)
    So U103 is EDID flash, and U108 - flash main software?
    It would rather fit me - because if I had to flash, then from what I see, U108 goes for SPI, and U103 after I2C (I think SPI will be easier to assemble).
    (I ask you a lot of questions - excuse me, but I prefer to make sure than to do something stupid.) This is the last one: I can not put a load on this U108 without desoldering it from the PCB?
    And, still:
    If it communicates with EDID and changes its resolution, does it mean that the processor (TSUMU18ER) is operational (still :D )?
  • #5 8333972
    WojtasJD
    Help: 2920
    Rate: 1587
    There are not many LDO stabilizers, you can do it ...
  • #6 8334092
    .yankee
    Aaa ... So that's how :idea: got a hint, thank you (and it's nice to know that there is such thing as an LDO stabilizer ...)
    Thus, 3.3 V and 1.8 V are. So what's next?
  • #7 8334137
    pudzianowski
    Help: 82
    Rate: 127
    @ Fox:
    Is this a newer version with which there is no problem anymore?
  • #8 8342083
    .yankee
    @_Fox:
    Something does not suit me - he has 512kB, while flash MX25L1005 has 128!
    WojtasJD
    Help: 2920
    Rate: 1587
    Since it is 1.8V and 3.3V, you can check the presence of quartz legs
  • #10 8391040
    .yankee
    Okay, I think it's time to admit what I've recently figured out. In short, I suspect that it's actually the fault of the batch - but the bone eeprom (MX25L1005) apparently damaged itself by stupid repair attempts.
    But in turn: First of all, I could not stand it, and before WojtasJD suggested to investigate the quartz, I soldered SPI programmer after LPT (by Rayer) quickly. Being convinced that I will not be able to solder U108 anyway, I just soldered the cables on the board to it.
    Of course, nothing could be read, so I began to combine with desoldering, but ineptly - using a braid. With these treatments it is possible that I flooded the system on one side. It was not until the next day that I realized that it was possible to desolder it with the help of a needle pressed gradually under my feet.
    So I had a desoldered chip, and I was happy to see that Rayer's programmer can see him :) Joy did not last long, because after loading a new charge (from the base), when I read it several times, I received other discharges each time. In addition, the SPIPGM program detected the eeprom as a model with 64k instead of 128k.
    So, apparently, the :(
    Then Wojtas's post appeared and I made attempts to measure the quartz. However, I did not take an oscilloscope, because temporarily I have access to it (renovation). I tried the multimeter - and it's weird here, because it usually shows some nonsense, but sometimes with these measurements the power LED lights up in blue (!) And then it sometimes shows around the correct (?) 14 MHz. I also found in my "junk" some other, desoldered from somewhere quartz for this frequency - soldered in place of that and the same symptoms.
    And what to think about it now?
    PS I had such a doubt yet: in programmer according to Rayer I used around 160 instead of 150 R - could it have been something?
    [EDIT]
    Actually, the most important question now is whether you can replace the MX25L1005 with a different memory. I found 25LC1024 on tme, but she is on 20MHz - does that exclude her? Can it just run slower? (Would it mean a longer turn on the monitor or something else ...?)
    [/ EDIT]
  • #11 9219944
    .yankee
    Weee!
    Thanks all!
    You said it well - fault on the side of the flash.
    And I had a good feeling - you can successfully replace the MX25L1005 with a different bone with the right parameters. I managed to with something that costs something under PLN 3 instead of several dozen (like MX25 ...).
    The monitor works and works well :D
  • #12 9221566
    Piter.
    Rate: 10
    Can not you write what you replaced right away ?!
  • #13 9222066
    .yankee
    Piter. wrote:
    You could not write what you replaced right away ?!
    And yes and not ;)
    Ie. calmly - I do not want to hide what the bone is, but just as I wrote it, I did not remember it, nor did I have the opportunity to check it out.
    Now I saw: this flash is EN25F10 .
    I bought several experimentally and I could not program for a long time - the problem was that the only simple programmer cooperating with this bone ( SPIFlash ) tried to run from emulation under the [/url] (wine), and it did not work - it started, the program did not see memory. Well, I did not have a computer with Windows and an LPT port.
    In addition, this bone apparently can only be programmed once - so at least claims SPIFlash.
    Moderated By Dzimi:
    post has been corrected.
The discussion revolves around the LG W2234S-BN monitor that fails to power on, indicated by an off power LED. The user suspects issues with the PCB and inverter, as the monitor is detected by the computer but does not display any output. Various capacitor voltages were measured, revealing potential problems with the TSUMU18ER board and the EEPROM flash memory (MX25L1005). Responses suggest checking the presence of 1.8V and 3.3V voltages, and the user eventually identifies the flash memory as the fault. After replacing the MX25L1005 with an EN25F10 chip, the monitor successfully powers on and functions correctly.
