I want t do simulation of electronic components please help
@ElektrodaBot
@ElektrodaBot
titarutkarsh wrote:Of course! Simulating electronic components is a great way to test and understand circuits before physically building them. There are several tools available for this purpose, ranging from basic to advanced complexity. Here's how you can get started:I want t do simulation of electronic components please help
[table][/table]ali05316ali wrote:It looks like you are viewing a webpage or tutorial about making a DIY (Do-It-Yourself) double-sided PCB (Printed Circuit Board). The image shows two printed circuit patterns that are presumably ready to be transferred onto a copper-clad board as part of the PCB fabrication process.https://obrazki.elektroda.pl/7350852500_1711255689.png
kgauravmandal wrote:It appears you've shared a photo of a computer screen displaying an electronic schematic diagram. The schematic is a bit blurry and difficult to discern in detail, but I can make some general observations:https://obrazki.elektroda.pl/6332248300_1711435195.jpg https://obrazki.elektroda.pl/3258161000_1711435226.jpg
fatimahraed2001 wrote:An IoT-based IV bag monitoring and alert system is a fantastic project that can significantly improve patient care by ensuring timely and accurate administration of intravenous fluids and medications. Here’s a step-by-step guide on how you can develop such a system:Iot Iv bag monitoring and alert system
mohammedzikriya24 wrote:Designing an Arduino-based transformer ratio meter is an intriguing project that involves measuring the turns ratio of a transformer, which is crucial for applications requiring precise voltage transformations. Here’s how you can develop this project step-by-step:i want to make a project on Arduino
ratio meter of transformer @ElektrodaBot
xxxlion555 wrote:To build an Arduino-based transformer ratio meter, you'll need a variety of electronic components. Here’s a detailed list of the parts along with some additional details to help you choose the right components:Electronic parts
xxxlion555 wrote:To successfully build an Arduino-based transformer ratio meter, you’ll need several key electronic components and tools. Here’s a detailed list of the parts you’ll need along with some additional details to help you choose the right components:Electronic parts
herohezi wrote:Designing a monostable trigger circuit can be accomplished using various components, but one of the most common methods is to use a 555 timer IC. A monostable circuit, also known as a one-shot pulse generator, generates a single pulse of a defined duration in response to a trigger input.Design a monostable trigger
TL;DR: "AC input ranges 100–240 V at 50–60 Hz" [ElektrodaBot, #20511928] – “Schematics.com and Partsim.com were shut down on 1 Jan 2023” [gulson, #20368022]. Engineers now cluster on Elektroda for replacements and Q&A. Why it matters: Lost cloud projects and tool gaps need fast work-arounds.
• Shutdown date: 1 Jan 2023; affected two platforms [gulson, #20368022] • Elektroda registration is free and global [gulson, #20368022] • Typical mains chargers accept 100–240 V AC, 50/60 Hz [ElektrodaBot, #20511928] • 4-band resistor: 270 Ω ±5 % example (red-violet-brown-gold) [ElektrodaBot, #20663709] • 555 monostable pulse width: T = 1.1 × R × C (s) [ElektrodaBot, #21095097]
