Dump/Firmware for Qilive 600094062/Q43UA211B TD.MS6886.762 & CX430DLEDM Panel
Jorge Moreira 7071 8
  • #1 20487988
    Jorge Moreira
    Hi, Anybody have dump or firmware?
    Mark: Qilive
    Model: 600094062/Q43UA211B
    Chassis (main board, components): TD.MS6886.762
    LCD Screen/Panel (if exists): CX430DLEDM
    Thanks
  • #2 20616082
    robyx1965
    Rate: 15
    TV Smart Tech 43 Android. Si accende e rimane con lo schermo Smart Tech. Se avete un aggiornamento per la scheda madre TD.MS6886.762.
  • #3 20626684
    nesa2586
    Hello, do you know the service menu code for this TV?
    Thank you.
  • #4 20626690
    Jorge Moreira
    Sorry, I don't know.
    Best wishes
  • #5 20627185
    robyx1965
    Rate: 15
    >>20626684 ciao il codice del menu 0000 zero
  • #6 20628055
    nesa2586
    Thank you, I will try. If I understood, press 0000 then again zero to enter the service menu. Is that correct?
  • #7 20682027
    ciesla
    Help: 71
    Rate: 127
    Thank you.
    MENU 1147
  • #8 21152642
    hssin79
  • #9 21254570
    ramyfofo13
    >>20487988 thank you
The discussion revolves around the search for firmware or a dump for the Qilive model 600094062/Q43UA211B, which utilizes the TD.MS6886.762 main board and the CX430DLEDM panel. Users have reported issues with the TV, specifically that it powers on but remains stuck on the Smart Tech screen. Several participants have inquired about service menu codes, with responses indicating codes such as "0000" and "1147" for accessing the service menu. There is a repeated request for firmware updates for the TD.MS6886.762 motherboard.
