How to Reset WiFi on AUX Q-Smart PLUS AC Without Health or + Button?
pagolik 2238 0
  • CC code appears, but Wi‑Fi module still won’t pair
    #1 20636298
    pagolik
    I'll dig up the topic a bit, because I also have a problem with AC Freedom.
    I bought AUX Q-Smart PLUS air conditioning factory equipped with a wifi module.
    I have a remote control for it marked as YKR-L / 201E:
    To view the material on this forum you must be logged in.
    Everywhere in the instructions it is written that to reset the wifi module, you must either press the "Health" button several times, which I do not have. And if there is no this button, then "Cooling and + simultaneously". I don't have a "Cooling" or "+" button. When I press "COOL" and the up arrow at the same time for a different number of seconds, nothing happens - the temperature on the panel increases.
    I also found info somewhere to go down to 16 degrees and press the down arrow 10 times within 5 seconds. Then the air conditioner beeps a few times, the inscription "CC" appears on it, but whether it is a wifi reset, I have no idea. I can't add it to the app for anything. I tried on different wifi, on routers from phones, with security, without security, I tried with S20FE, with S23 Ultra, with Samsung A13, with Samsung S7 - totally nothing. After the stage of providing wifi data, confirming the wifi reset, the application connects for a minute or two and crashes the error of no connection.
    Maybe there is a problem with this way of resetting wifi? Anyone dealt with this topic on Q-Smart Plus? The module is physically installed, plugged into the USB under the flap of the indoor unit. The voltage meter shows 12V. Current rather low 0.01 to 0.07A. The module does not broadcast any wifi network. Plugged into the computer, it behaves as if it disconnected half a second after connecting (that characteristic sound from Windows) and so on, I don't know if it should be like this, or if the computer should normally detect it as some kind of wifi card or something similar.
    Deleted from topic: To view the material on this forum you must be logged in.
    by pagolik on 30 Jun 2023 18:06
