DT9205a Multimeter Wont Power On After Battery Replacement: Troubleshooting Guide
Hot_Amir 8223 54
Why won’t my DT9205A multimeter turn on after replacing the battery even though the new battery is correct?
If the battery, polarity, contacts, fuse, switch, and visible PCB damage are all okay, the next step is to check the continuity of the meter’s power circuit with another multimeter [#20784607] [#20784638] Measure directly across the battery contacts with the power switch on; the reading should be close to the battery voltage, about 9 V, and if it is much lower you likely have an open trace or bad component somewhere in the supply path [#20784638] If the meter later turns out to work on battery but not from an adapter, the likely fault is in the external power path such as the jack, diode, fuse, switch, or voltage regulator [#20864572] [#20865667] In-circuit tests of SMD capacitors or transistors can be misleading, so if a part looks suspicious you may need to remove it to test it properly [#20865775]
  • #1 20784601
    Hot_Amir
    @ElektrodaBot
    It is DT9205a. After I changed the
    battery, it wouldn't turn on. Its battery is new and correct. Which part of troubleshooting
  • Battery polarity, fuse, and switch checks for DT9205A
    #2 20784607
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hello user 4348391,
    I'm sorry to hear about your issue with the DT9205A multimeter. Let's try to solve your problem step by step:
    1. Check the Battery Polarity: Make sure that the battery is installed in the correct orientation. The positive (+) and negative (-) ends should match the indications inside the battery compartment.
    2. Check the Battery Compartment: Look for any corrosion or signs of damage in the battery compartment.
    3. Check the Fuses: It's possible that a fuse may have blown when you replaced the battery. If the fuse is blown, the multimeter won't turn on even with a new battery.
    4. Check the PCB: If everything else seems fine, you might want to inspect the Printed Circuit Board (PCB) for any visible signs of damage, such as burnt components or broken traces.
    5. Check the Switch: Lastly, check the function switch operation. Sometimes, dirt or a bad contact can cause the multimeter not to turn on.
    Please remember to take safety precautions while checking your device, especially when you're dealing with electronics. Don't hesitate to ask if you have any further questions or concerns.
  • #3 20784630
    Hot_Amir
    @ElektrodaBot I checked everything you wrote. Everything was fine, but the problem remains.
  • Check continuity of the DT9205A power circuit
    #4 20784638
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    I'm sorry to hear that the issue persists, user 4348391.
    At this point, it might be a good idea to check the continuity of the power circuit. You'll need another multimeter for this:
    1. Ensure that the power switch is in the 'on' position.
    2. Connect the probes of your working multimeter to the battery contacts inside the DT9205A.
    3. The reading should be close to the battery voltage (usually 9V for this type of multimeter). If it's significantly less, there might be a break in the circuit somewhere.
    4. If the voltage is correct, try measuring the voltage at different points along the circuit to see if you can find where the voltage drop occurs.
    Please be careful while doing these steps, as they involve potential risks. If you don't feel comfortable doing this, I would recommend taking your multimeter to a professional for repair.
    Let us know if you need more assistance or if you have any further questions.
  • #5 20784656
    Hot_Amir
    @ElektrodaBot
    Which one of the EC's foundations knows how to help me? How accurate is the voltage? What is the voltage of the display and can it help me? Send me the multimeter datasheet. Send it to me.
  • Asking for DT9205A datasheet and display voltage
    #6 20784658
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hot_Amir wrote:
    Which one of the Ec's foundations knows to help me? How accurate the voltage is. What is the voltage of the display and can it help me? Send me the multimeter datasheet. Send them to me.
    Hello user 4348391,
    I'm afraid I cannot send documents or files through this platform. However, I can guide you on how to find them:
    The datasheet for the DT9205A multimeter is usually available on the manufacturer's website or some online retailers who sell this model. You can find the detailed specifications and operational instructions there.
    To answer your question about the display voltage:
    - For most common digital multimeters like the DT9205A, the LCD display typically operates at low voltages, often around 3V to 5V, supplied by an onboard voltage regulator.
    - If you have the correct equipment and knowledge, you can test the voltage at the display's power input pins.
    Please remember that manipulating the internals of your multimeter carries risk and should only be done if you're confident about what you are doing. If you need further instructions or have any other questions, don't hesitate to ask.
    Let me know how you're progressing with the troubleshooting.
  • #7 20794494
    Hot_Amir
    @ElektrodaBot Can I replace the zebra LCD connector with a thin wire?
  • Thin wire replacement for zebra LCD connector is impractical
    #8 20794495
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Yes, it is technically possible to replace the zebra LCD connector with a thin wire, but it is quite complex and you may find it challenging if you're not experienced in detailed electronics work.
    The zebra connector is designed to make multiple connections simultaneously, which is why it's used for LCD screens. If you decide to replace it with thin wires, you would need to solder a unique wire for each of the many connections, which could be dozens depending on the LCD.
    Also, it's important to consider the electrical characteristics of the wire you are planning to use and its compatibility with the LCD panel.
    Can you tell me more about the specifics of your project? Which LCD are you using? Is the zebra connector damaged?
  • #9 20794497
    Hot_Amir
    Hot_Amir wrote:
    @ELECTRODABot
    DT9205a است. بعد از اینکه تغییرش دادم
    باتری روشن نمی‌شود. باتری آن جدید و درست است. کدام بخش از عیب‌یابی
    @ElektrodaBot
    @ElektrodaBot
  • #10 20794499
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hot_Amir wrote:
    It seems like your message was cut off. Can you please provide more details about your project? For example, what is the model of the LCD screen you're working with? And what exactly is the issue with the current zebra connector? This information will help me provide a more accurate response.
  • #11 20794502
    Hot_Amir
    @ElektrodaBot Why is a common zebra flat connector used to connect the top and bottom of the LCD?
  • Zebra connector placement on LCD rows and columns
    #12 20794503
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hot_Amir wrote:
    Why is a common zebra flat connected to the top and bottom of the LCD?
    Zebra connectors (also known as elastomeric connectors) are used to establish an electrical connection between LCDs and the circuit board. They are very useful due to their flexibility, durability, and ability to re-establish connections even after being disconnected, which makes them ideal connectors for LCDs.
    The reason a zebra connector is often connected at the top and bottom of the LCD has to do with how the LCD works. LCD screens are made of two glass panels, each covered with a conductor. The liquid crystal material is sandwiched between these panels.
    The top and bottom connections correspond to rows (horizontal) and columns (vertical) of pixels on the screen. When a particular pixel needs to be activated, the corresponding row and column are energized, causing the liquid crystal at the intersection to change orientation, thus affecting the pixel's brightness/color.
    So, in essence, the zebra connector helps to distribute electrical signals precisely across the LCD panel, enabling accurate control of the display.
    Is there a particular reason you're asking about the placement of zebra connectors? Are you facing any issues with your LCD display or its connections?
  • #13 20853022
    Hot_Amir
    Buff pin
    in Chase Digital Multimeter IC
    @ElektrodaBot
    Clarifying the function of the buff pin
    #14 20853024
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hot_Amir wrote:
    Buff pin
    The "Buff" pin you're referring to is likely a buffer pin on an integrated circuit (IC) within a digital multimeter. In the context of ICs, a buffer typically serves to isolate different circuit sections or to provide additional drive capability to enable a signal to drive a larger load without degradation.
    In a digital multimeter, which uses an analog-to-digital converter (ADC) to measure voltage, current, or resistance and then display it digitally, a buffer might be used in several places, such as:
    1. Input Buffer: It can be used at the input stage to prevent the loading of the circuit under test by the multimeter. This helps to maintain the accuracy of the measurement by reducing the effect the multimeter has on the circuit.
    2. Reference Buffer: It can be used to buffer the reference voltage of the ADC, ensuring that it remains stable and precise for accurate measurements.
    3. Output Buffer: It can buffer the digital signal to the display or the communication interface, ensuring signal integrity is maintained.
    If a specific part number or more context around the "Buff" pin is provided, I could give a more detailed explanation. Do you have the datasheet for the IC, or can you provide the part number and manufacturer? Do you need help with understanding the function of this pin in a particular circuit, or are there problems you’re encountering related to the "Buff" pin?
  • #15 20853025
    Hot_Amir
    @ElektrodaBot ic 7106
    Added after 43 [minutes]:
    >>20853024
    @ElektrodaBot IC 7106Is it possible that this ICT has 48 bases?
  • Clarifying whether the 7106 comes in 48-pin package
    #16 20853048
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hot_Amir wrote:
    ic 7106
    20853024
    The IC 7106 is a well-known integrated circuit used in digital multimeters and other digital measuring instruments. It is an analog-to-digital converter (ADC) designed for LCD (liquid crystal display) applications. The IC is typically encapsulated in a Dual In-Line Package (DIP), and its standard versions are usually 40-pin ICs.
    To address your query about the IC having 48 pins, the standard IC 7106 typically comes with 40 pins. If you are looking at a variant or a different package that has 48 pins, it could be a specialized version or a different IC altogether that might be similar to the 7106 but with additional functionality or interfaces. However, based on the standard datasheets and typical applications for the 7106, it is generally known to be a 40-pin IC.
    Could you provide more information about where you have seen this 48-pin version? Is it part of a specific multimeter model, or have you come across it in a datasheet or product specification? Additional details would be helpful to clarify your question.
  • #17 20854044
    Hot_Amir
    @ElektrodaBot My multimeter is DT9205a. The IC, which is coated with black resin, has 48 legs each side has 12 feet. Most multimeters use IC 7106 which has 40 bases. How do I find a 48 base? I measured a 72 kΩ SMD resistor. The code is not clear on it. What is the correct code?
  • 48-pin glob-top IC likely a custom 7106 clone
    #18 20854048
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Regarding the IC on your DT9205a multimeter, it sounds like it could be a clone or a custom version of the 7106 or an entirely different IC designed for similar purposes. Sometimes manufacturers use proprietary ICs or enhanced versions of standard ICs for their equipment. If the IC is coated in black resin and has no visible markings (a common practice known as "glob-topping" to protect proprietary components), it can be particularly challenging to identify the exact part number or find a datasheet.
    To find a replacement for an IC with 48 pins, you would typically need to know the exact part number or, at the very least, have detailed specifications and understanding of its functionality. Without this information, the search can be difficult. You might also consider:
    1. Contacting the manufacturer of your multimeter to request information about the IC.
    2. Searching through forums and electronics communities, as someone else might have encountered the same issue.
    3. Looking for service manuals or teardowns of the same multimeter model online, which might have more detailed information.
    Regarding the SMD resistor code, if it's not clear, there are a few common formats for SMD resistor codes, typically either three or four digits:
    - Three-digit code: The first two digits are the significant figures, and the third is a multiplier (number of zeroes to follow). For example, "723" would mean 72 x 10^3 ohms = 72 kΩ.
    - Four-digit code: This is used for precision resistors. The first three digits are the significant figures, and the fourth is the multiplier.
    If the code is unreadable, the most accurate way to determine the resistor value would be to measure it with a functioning multimeter. Since you've mentioned measuring a 72 kΩ resistor, if this reading came from the multimeter in question, and the multimeter is malfunctioning, the reading might not be accurate.
    Could you clarify how you obtained the 72 kΩ measurement, and what you mean by "the code is not clear on it"? Are you referring to the color code on the resistor or the actual SMD code printed on the resistor? If it's a printed code that's partially unreadable, could you provide the visible part of the code, and I can try to assist you in determining the value?
  • #19 20854104
    Hot_Amir
    @ElektrodaBot I measured this resistance with another multimeter. The code is used with the letter D or 0. I need to know if 72 kilos of ohm is correct or the amount of resistance is burnt. Please tell us if there is a 72 kΩ SMD resistor code that is in combination with a letter and a D or 0 in or starting it? Please send me all possible correct codes for this resistance.
  • 72 kΩ SMD code likely marked 7202 or 723
    #20 20854112
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    For SMD resistors, the code generally consists of three or four characters, where the letters are often used to denote the tolerance or temperature coefficient, not the value itself. However, in some cases, a letter can be used to indicate the multiplier as well.
    The standard SMD resistor code for a 72 kΩ resistor would typically be "7202" or "723," where:
    - "7202" translates to 72 followed by 2 zeros, meaning 7200 ohms or 72 kΩ.
    - "723" translates to 72 followed by 3 zeros, meaning 72000 ohms or 72 kΩ.
    Now, regarding the letter "D" or "0," there are a few possibilities:
    1. If the letter "D" is at the start or end of the code, it might indicate a tolerance or other specification rather than being part of the value.
    2. If "D" or "0" is in the middle, it might be part of a four-character code where the letter represents a multiplier. However, this is not standard, and "D" is not recognized as a standard multiplier in any common coding scheme.
    If the SMD code is, for example, "D720" or "0D72" and the measurement you obtained with another multimeter is 72 kΩ, it could be that the resistor is indeed 72 kΩ and the extra character pertains to something other than the resistance value.
    Unfortunately, without a clear set of coding standards that include the specific use of "D" or "0" in the context you've described, determining the exact code can be challenging.
    Since you've measured the resistor with another multimeter and got 72 kΩ, if the multimeter is reliable, the resistance is likely correct, and the resistor is not burnt out. Burnt resistors typically show a much higher resistance or an open circuit when they fail.
    Could you share the exact code as it appears on the resistor? Even if it's partially unreadable, the visible part might give some clues to its value.
  • #21 20854131
    Hot_Amir
    @ElektrodaBot says D98 code.
    or 098 or 860 or 86D from the above one code and vice versa another code. These four codes are readable.
  • Measured resistor reads 72 kΩ despite unclear SMD code
    #22 20854140
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hot_Amir wrote:
    says D98 code.
    or 098 or 860 or 86D from above one code and vice versa another code. These four codes are readable.
    Given the codes you've provided, let's analyze them to see if they match a standard SMD resistor coding format:
    1. D98 - This does not fit the standard numerical SMD resistor codes. If "D" represents a manufacturing code or tolerance, it's not part of the value. Without further context, this code doesn't directly translate into a resistor value.
    2. 098 - This could potentially be a code for a resistor, but it doesn't fit standard codes. Normally, the first two numbers represent significant figures, and the last is a multiplier, which in this case would be 0, which doesn't make sense. So this is likely not a correct value code.
    3. 860 - According to the EIA-96 standard, "86" corresponds to the 3-digit code for a 4% tolerance resistor, which would be 243 ohms. The "0" would indicate a multiplier of 1, so this would suggest a 243-ohm resistor, not 72 kΩ.
    4. 86D - The "86" might again refer to a nominal value following EIA-96, but "D" does not correspond to a recognized multiplier or tolerance in standard SMD resistor codes.
    Given these potential readings, none of them clearly indicate a 72 kΩ resistor value. It's also possible that the codes are from a manufacturer-specific coding system, or that the resistor has a custom code that doesn't follow the standard conventions.
    Since you measured the resistor with another multimeter and found 72 kΩ, you can generally trust that measurement, assuming the multimeter is calibrated and functioning correctly. It's also possible that the resistor is a non-standard value, or it has drifted from its original value due to stress or heat over time, assuming it is the resistor you are trying to replace from your DT9205a multimeter.
    If you are trying to find a replacement resistor and you are certain the original value is meant to be 72 kΩ, you can purchase a standard 72 kΩ SMD resistor for your repair. The code for a standard 72 kΩ SMD resistor would typically be "723" or "7202" as mentioned earlier, and you would choose the size and power rating appropriate for the multimeter's circuit.
  • #23 20854160
    Hot_Amir
    @ElektrodaBot Your answer may be 243 kilos correct, paralleled by a resistor or capacitor, and the result is 72 kilograms. Am I right? I haven't gone through it yet. Does it give a parallel rate to the capacitor?
  • Parallel resistor value calculated as 107.5 kΩ
    #24 20854165
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    The idea of combining components in parallel to achieve a specific resistance is valid in theory, but it works differently depending on whether you're paralleling resistors or combining a resistor with a capacitor.
    When you parallel resistors, the total resistance decreases and is given by the formula:
    $$ \frac{1}{R_{total}} = \frac{1}{R_{1}} + \frac{1}{R_{2}} + \frac{1}{R_{3}} + ... + \frac{1}{R_{n}} $$
    For example, if you had two resistors in parallel, one being 243 kΩ and another unknown resistor, and the total resistance you measured is 72 kΩ, you can use the parallel resistance formula to find the value of the second resistor:
    $$ \frac{1}{R_{total}} = \frac{1}{243 kΩ} + \frac{1}{R_{x}} $$
    Solving for $$ R_{x} $$:
    $$ R_{x} = \Biggl(\frac{1}{\frac{1}{72 kΩ} - \frac{1}{243 kΩ}}\Biggr) $$
    $$ R_{x} ≈ 107.505 kΩ $$
    So the second resistor would need to have a value of approximately 107.505 kΩ to result in a total parallel resistance of 72 kΩ.
    Regarding capacitors, they do not directly combine with resistors to give a "parallel resistance." Instead, capacitors and resistors form a time-constant circuit when connected in series, defining the charge and discharge time of the capacitor, known as an RC circuit. When a capacitor and a resistor are connected in parallel, they do not affect each other's resistance or capacitance but can affect the circuit's overall impedance at different frequencies.
    In your case, if you indeed have a 243 kΩ resistor and the total resistance measured is 72 kΩ, then it's likely that there is another resistor in parallel, not a capacitor. To confirm this, you would need to inspect the circuit and identify any components that are in parallel with the 243 kΩ resistor.
    If you have access to the circuit schematic or can visually inspect the board, it would help clarify the components involved and their configuration. If you find a parallel resistor, you can then calculate its value using the formula I provided above. If there is a capacitor in the circuit, it may be part of a filter, timing, or feedback network, especially if we're discussing a multimeter circuit where precise timing and signal conditioning are essential.
  • #25 20854224
    Hot_Amir
    [پسوند]20853024[/پسوند]
    Is it possible to connect to the Buff Stand and give the Buzzer the sound on and off?
    Added after 8 [hours] 1 [minutes]:
    @ElektrodaBot
  • Clarifying buzzer control and unknown part number
    #26 20854401
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    I'm not entirely sure what you mean by "Buff Stand" in this context. It sounds as if you might be referring to some sort of supporting circuitry for a buzzer. In general, buzzers can be activated (turned on and off) using various methods depending on the type of buzzer (active or passive) and the circuit configuration.
    Here's a basic explanation for both types:
    1. Active Buzzer: An active buzzer has an internal oscillator, so it only requires a DC voltage to be applied to make a sound. To turn it on and off, you can simply connect and disconnect the power supply, or use a switch, transistor, or microcontroller to control the power.
    2. Passive Buzzer: A passive buzzer requires an AC signal (like a square wave) to make a sound. To control a passive buzzer, you usually use a microcontroller or function generator to produce the desired tone and then turn the signal on and off to control the sound.
    To give you more accurate advice, could you clarify what you mean by "Buff Stand"? Also, if you're looking to control the buzzer, could you provide more details about the buzzer (active or passive), your power supply, and what sort of control you are looking to implement (manual switch, microcontroller, etc.)?
    Regarding the text "[پسوند]20853024[/پسوند]", this does not seem to be related to a known electronic component or standard notation. If this is a part number or model number, could you specify the manufacturer or provide additional context? It would help in providing a more precise answer to your question.
  • #27 20864568
    Hot_Amir
    @ElektrodaBot Digital multimeter with the adapter turned on for minutes and did not turn on if the adapter is intact. Which part is damaged? How can it be repaired?
  • Diagnostic checklist for multimeter power failure
    #28 20864572
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Hot_Amir wrote:
    Digital multimeter with the adapter turned on after minutes and did not turn on if the adapter is intact Which part damaged nose and repair?
    It seems you are dealing with a digital multimeter that fails to power on after some time when using an adapter, but the adapter itself appears to be working correctly. To diagnose the issue, we'll need to follow a systematic approach. Here's a step-by-step guide to help you troubleshoot the problem:
    1. Verify the Adapter: Double-check the output voltage of the adapter with another multimeter to ensure it is indeed outputting the correct voltage and that the polarity is correct.
    2. Inspect the Multimeter: Look for any signs of damage, such as burnt components, melted plastic, or a burnt smell which could indicate a short circuit or overheating.
    3. Check the Input Jacks: Ensure that the input jacks where the adapter connects are not loose or damaged, as this could interrupt the connection.
    4. Internal Fuse: If your multimeter has an internal fuse, check if it is blown. A blown fuse would prevent the multimeter from turning on. Replace it with the same type if necessary.
    5. Battery Condition: Some multimeters will not operate correctly if the internal battery is dead or low, even with an adapter. Check the battery and replace it if needed.
    6. Power Switch: Test the continuity of the power switch with another multimeter. The switch might be faulty and not making a proper connection.
    7. Voltage Regulator: If the multimeter has an internal voltage regulator or protection diode, check if these components are functioning correctly. A faulty regulator could prevent the multimeter from powering on.
    8. Capacitors: Look for any bulging or leaking capacitors on the multimeter's circuit board. These could be signs of capacitor failure.
    9. Printed Circuit Board (PCB): Examine the PCB for any cracks, broken traces, or cold solder joints that could be interrupting the power supply to the multimeter.
    10. Internal Components: If there's still no clear cause, other internal components might be at fault, such as the microcontroller, display, or other active components. This kind of repair would likely require a schematic and a deeper knowledge of the specific multimeter's design.
    To begin the troubleshooting process, it would help to know the model of the multimeter, the specifications of the adapter, and whether the multimeter operates properly on battery power alone. If you have another multimeter, use it to perform the voltage and continuity checks mentioned above. If you can provide additional information about the symptoms or any tests you've already conducted, it would be beneficial in narrowing down the problem.
    Remember to always take necessary precautions when working with electronics to avoid electric shock or further damage to the device.
  • #29 20864594
    Hot_Amir
    My multimeter only works on battery, and the voltage of the adapter is 9 volts, the same as the battery of the multimeter. I googled but couldn't find a multimeter datasheet for repair. How do I test the SMD capacitor with another multimeter? If the circuit is on and off, the multimeter with a compression chassis, not the switch, and connect. Which part should I follow?
  • Asking how to test the SMD capacitor and power path
    #30 20865437
    Hot_Amir
    >>20864572
    @ElektrodaBot
The DT9205A multimeter fails to power on after a battery replacement, despite using a new and correct battery. Troubleshooting steps include checking battery polarity, inspecting the battery compartment for corrosion, verifying fuses, and examining the PCB for damage. If these checks do not resolve the issue, continuity testing of the power circuit is recommended. Users also discussed the possibility of replacing the zebra LCD connector with wires, the characteristics of SMD components, and the identification of an IC with 48 pins. The conversation highlights the importance of understanding the multimeter's internal circuitry and the challenges of identifying components without clear markings.
TL;DR: If your DT9205A died after a battery change, start with two numbers: 9 V at the battery and about 6.7 V at the IC supply. As one reply put it, "trace the power path" with a second meter to find the break. This FAQ helps DT9205A owners isolate faults in the battery path, adapter path, LCD connection, and unknown resin-covered ADC chip. [#20875183]
Why it matters: A DT9205A that will not power on can have a simple supply-path fault even when the battery, fuse, PCB, and selector look normal.
Scenario Observed condition in thread Best next check
New battery fitted, meter stays off Battery reported new and correct Measure battery voltage through the power path
Works on 9 V battery only Adapter is 9 V but meter still fails on adapter Check jack, polarity, diode, and adapter-only path
LCD or zebra suspected User asked about zebra replacement and LCD contacts Inspect elastomer contact pressure and alignment
Resin-covered ADC chip unknown Reported as 40, 45, or 48 pins Trace V+, V-, Hold, BZ, and LCD pins
Key insight: The thread points to a supply-path diagnosis, not random part swapping. If 9 V reaches the meter but only about 6.7 V reaches the IC, follow that exact path until the voltage disappears. [#20875183]
  • The DT9205A in the thread uses a 9 V battery, and the same 9 V was also measured at the external adapter output. [#20864594]
  • One measured internal value was 6.7 V at the ADC IC power input, lower than the 9 V battery rail. [#20875177]
  • The resin-covered multimeter chip was described three different ways: 40 pins connected to the LCD, 48 pins total, and even 45 pins after recounting. [#20875007]
  • The user measured one SMD resistor at 72 kΩ with another multimeter, while a reply noted that code 860 could map to about 243 Ω under one coding interpretation. [#20854140]
  • The thread identifies the LCD zebra as a pressure connector; replacing it with separate wires would require many individual connections, not one simple jumper. [#20794495]
How do I troubleshoot a DT9205A multimeter that stopped powering on right after a battery replacement even though the new battery is correct?
Start by checking whether the full 9 V actually reaches the meter’s internal power path. If the battery is new and installed correctly, the next useful test is voltage tracing, not another battery swap. 1. Put the selector in an ON position. 2. Measure at the battery contacts inside the DT9205A. 3. Follow the voltage forward until it drops or disappears. One reply stated the reading at the battery contacts should be close to the battery voltage, usually 9 V. [#20784638]
Which parts of the DT9205A power circuit should I check first when battery polarity, battery compartment, fuses, PCB, and selector switch all seem fine?
Check the continuity of the power circuit first. The thread specifically moves to power-path tracing after battery polarity, battery compartment, fuses, PCB, and selector switch were all reported as fine. Use a second multimeter and verify voltage at the battery contacts, then at later points in the same path until the drop appears. This narrows the fault to a break, bad contact, or failed supply-path component instead of the whole board. [#20784630]
What is the normal battery voltage and internal supply voltage I should expect at different points inside a DT9205A multimeter?
Expect about 9 V at the battery and battery-input area, then a lower internal IC supply if the design drops it. In the thread, the battery and adapter were both described as 9 V, while the measured ADC IC power input was 6.7 V. That means the useful reference points are 9 V at the source and roughly 6.7 V at the chip in this specific unit. A sudden fall below those values marks the likely fault area. [#20875177]
How can I trace the power path in a DT9205A with another multimeter to find where the voltage drops or disappears?
Measure the same supply at several points in order until the reading changes. 1. Turn the DT9205A on. 2. Put the working meter across the battery contacts and confirm a value near 9 V. 3. Move step by step along the power path and find the first point where the voltage is much lower or missing. That first bad point is more useful than guessing at the IC or LCD. [#20784638]
Where can I find a DT9205A multimeter datasheet or service information for repair and pin tracing?
The thread did not provide a working DT9205A repair datasheet. One reply said the datasheet is usually found on a manufacturer site or seller pages, while the user later said they searched Google and still could not find a service document for repair. In practice, this thread supports manual pin tracing from known points such as V+, V-, Hold, BZ, adapter input, and LCD connections when no datasheet is available. [#20864594]
What is a zebra LCD connector, and why is it used between the LCD glass and the multimeter PCB?
"Zebra connector" is an elastomeric LCD connector that links the LCD glass to the PCB through many parallel conductive paths, using compression instead of soldered wires. In the thread, it was described as flexible, durable, and able to reconnect after disassembly, which is why it suits multimeter LCD assemblies. This type of connector helps carry many display signals at once between the board and the glass. [#20794503]
How could replacing a zebra LCD connector with thin wires affect the LCD operation in a DT9205A multimeter?
It can make the LCD unreliable or impossible to reconnect correctly. The thread states that replacing a zebra connector with thin wires would require a separate wire for each of the many LCD connections, potentially dozens. That raises the risk of wrong routing, weak joints, and signal problems. For a DT9205A, the zebra part is there because one compressed strip can handle many contacts at the same time. [#20794495]
Why are zebra connectors placed at the top and bottom of an LCD in some digital multimeters?
They are placed there to distribute many LCD drive connections across the glass. The thread explains that LCDs use conductors on both glass layers and that top and bottom connections relate to how signals are applied across the display structure. In practical repair terms, top-and-bottom zebra placement improves contact density and keeps the glass aligned with the PCB pads. If either side loses pressure, segments can fail even when the meter powers on. [#20794503]
What is the Buff pin in a digital multimeter IC such as the ICL7106, and what does it do in the circuit?
In the thread, Buff was treated as a buffer-related pin that isolates or drives part of the signal path. The explanation given was that a buffer in a digital multimeter IC can serve at the input, reference, or output stage to preserve measurement accuracy and signal integrity. The same reply links Buff to stable ADC behavior, especially around reference handling. That makes it relevant to buzzer or measurement control only if the surrounding circuit confirms that role. [#20853024]
ICL7106 vs the black resin-covered multimeter ADC chip in the DT9205A: what are the key differences in pin count, function, and compatibility?
The thread treats them as functionally similar but not pin-compatible. ICL7106 was described as the common LCD multimeter ADC and was said to be typically a 40-pin part, while the DT9205A chip under black resin was reported as 48 pins, then 45 pins, and also as 40 LCD-related connections. That means you should compare functions, not assume a drop-in replacement. A resin-covered clone can mimic 7106 behavior while using a different pinout and package. [#20854048]
How do I identify an unknown resin-covered multimeter IC when the package seems to have 40, 45, or 48 pins and no visible part number?
Identify it by mapping functions, not by counting pins alone. The thread recommends finding V+, V-, Hold, buzzer control, and LCD-connected pins, then comparing that map with known multimeter ADC families such as 7106 or 7107. One later post reports 6.7 V at the IC supply and about 40 LCD-linked pins, which are better clues than the conflicting 45- or 48-pin counts. Count errors are easy when resin and fine leads obscure the package edges. [#20875219]
What are the common SMD resistor codes for 72 kΩ, and how can I tell whether a marked resistor like D98, 098, 860, or 86D is actually 72 kΩ or a different value?
The thread gives 723 and 7202 as the normal 72 kΩ code patterns. It also says the measured resistor was 72 kΩ on another multimeter, but codes such as D98, 098, 860, and 86D do not clearly confirm 72 kΩ. One reply specifically interprets 860 under another system as about 243 Ω, not 72 kΩ. So the safe method is to trust the out-of-circuit measurement more than a blurred marking. [#20854140]
How do I test an SMD capacitor in-circuit with another multimeter, and when do I need to remove it from the board for a reliable reading?
You can do a quick in-circuit fault check, but you must remove it for a reliable value reading. The thread says in-circuit testing can show whether the capacitor is shorted or open, especially with resistance or continuity mode, but nearby parts can distort the result. If the meter shows a suspicious low resistance, that may indicate a short. If you need the actual capacitance or a definitive verdict, desolder one part of the capacitor from the board. [#20865775]
What does the M6 marking on an SMD transistor or MOSFET usually mean, and how can I test that part inside a multimeter power circuit?
In the thread, M6 is treated as a likely transistor or MOSFET code, not a guaranteed single part number. The advice given is to test it first in-circuit for obvious shorts using diode or resistance mode, then remove it if readings stay unclear. Check for a short between the main current pins and for normal junction behavior on the control pin. The same answer warns that surrounding components can hide the real fault unless the device is lifted from circuit. [#20866969]
When a digital multimeter works on its 9 V battery but not from a 9 V adapter, what components around the adapter input, jack, diode, regulator, or switch are most likely damaged?
The likely fault is in the adapter-only input path. The thread points to the adapter jack, polarity, internal diode, regulator, switch mechanism, and continuity from the jack to the board as the first suspects when the meter works on a 9 V battery but not from a 9 V adapter. One expert-style reply says, “Check the adapter jack and internal power path first,” which fits the battery-good, adapter-bad symptom exactly. That narrows the search to a few parts instead of the whole meter. [#20865667]
